Old 08-29-2014, 06:57 PM   #113
Squishy86
Squishy86's Avatar
Drives: Your Car
Squishy86 is offline   Reply With Quote
Old 02-26-2015, 10:32 PM   #114
xkwizt
Drives: 86 GT
Lowered 1" on Eibach Pro Kit springs. 235/40/18 tyres.
xkwizt is offline   Reply With Quote
Old 02-27-2015, 12:49 PM   #115
JGalp
Drives: 2015 CWP BRZ Limited
^^^ didn't need LCA, or anything else? all stock + lowering springs??
JGalp is offline   Reply With Quote
Old 04-11-2015, 07:06 PM   #116
Rookie84
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
Hey, guys. I want to run 18x9.5 with 245/35/18 square and I wanted to confirm whether I need to run spacers in front. If I do, will 3mm be enough? I'm on completely stock suspension at the moment.
Rookie84 is offline   Reply With Quote
Old 04-27-2015, 01:52 AM   #117
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
18x9.5 +40, on coilovers. Any idea if 235/40 will work in the front? Do I need alot of camber or will it be ok at full lock? Thinking the car will get lowered an inch. It all depends once I figure my wheels out.
Jolt182 is offline   Reply With Quote
Old 04-28-2015, 07:34 PM   #118
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
235/40/18 will depend on your ride height. With that being said lowering 1 inch with full lock you should be fine, but with load at full lock not 100% sure.
Touge Factory is offline   Reply With Quote
The Following User Says Thank You to Touge Factory For This Useful Post:
Jolt182 (04-29-2015)
Old 06-23-2015, 10:52 PM   #119
xkwizt
Drives: 86 GT
No LCA, no spacers. All stock + lowering springs. No rub, no issues.
Ive never been at full lock underload so i dont know if it will rub.... maybe a track day might tell me more but i keep it on the street mostly.
Old 07-01-2015, 01:17 AM   #120
DonkeyKonga
Drives: Slow Car
Figured I'd contribute to this thread as well, so I dug up some old pictures.
DonkeyKonga is offline   Reply With Quote
The Following User Says Thank You to DonkeyKonga For This Useful Post:
swarb (07-01-2015)
Old 07-01-2015, 01:26 AM   #121
swarb
@DonkeyKonga nice setup, what tire size/brand?
Old 07-01-2015, 01:39 AM   #122
DonkeyKonga
Drives: Slow Car
Thanks! They are Bridgestone S04's in 235/40/18 all around
Old 11-05-2015, 02:01 PM   #123
ivan001100
Drives: xsara
i have a question, i bought enkei nt03+m 17x7.5 et35, but i haven't lug nuts? who's the favourite lug nuts to this wheels???
ivan001100 is offline   Reply With Quote
Old 11-09-2015, 01:23 AM   #124
Richytort
Drives: Scion FR-S
It's like saying what kind of gas should I fill with. Doesn't matter. It's all on preference. I use muteki lugs.
Some people go with aluminum lugs. Those should be torqued at a lower torque setting.
Richytort is offline   Reply With Quote
Old 02-10-2017, 01:51 AM   #125
Dan37BRZ
Senior Citizen
Drives: 2015 WRB BRZ
Here's my contribution. SBC finish NT03Ms on WRB, wrapped in Michelin Pilot Super Sports 245/35ZR18. SPC camber bolts with Bilstein PSS B14 coilovers.
Dan37BRZ is offline   Reply With Quote
Old 04-22-2017, 11:48 PM   #126
tougetuned
Drives: '15 BRZ, '05 Evo 8
Awesome thread and all I see is great fitment. I have a question if anyone can help. I have a set of nt03's in 18x9.5 +40 from my evo so the bolt pattern is 5x114.3. I want to fit them to my brz lowered on swift sport springs. I will be using a 15mm 5x100 to 5x114.3 conversion spacer and 245/35r18 tires. Knowing that the effective offset will +25 I'm confident that they will clear the factory spring perch after tons of reading, lol, but I was wondering what is the maximum amount of camber I could run to minimize the poke up front but still clear the spring perch. The tire calculator tool makes it appear that -1.4deg of camber (approximately max that can be achieved with camber bolts) will make it sit pretty close to flush, but will this still clear the perch? Thanks in advance for the help.
Evelyn: 2005 Evo 8
Elsa: 2015 BRZ Series Blue
Roxanne: 2011 R6
Raven: 2008 R1
tougetuned is offline   Reply With Quote
Wheel Directory: Enkei RS05RR 18x9.5 +43 FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 129 09-22-2019 10:39 PM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Wheel Directory: Enkei Tenjin 18x8.5 +45/18x9.5 +45 Sciby Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-10-2014 12:53 AM
Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 PradiG Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 12-12-2013 03:15 AM
