Old 04-10-2015, 12:49 PM   #15
Gunman
Drives: 2019 Mazda Miata RF
Originally Posted by wparsons View Post
What are those weights based on? Including the wheel? Which wheel? A 215/45/17 MPSS is 21lbs and a stock Primacy is 21lbs (both according to tire rack).
Crap...sorry, tire weight came from the michelin website, and I was adding OEM and aftermarket wheel weights, I will edit the post to reflect ONLY the tire weight.
Old 04-10-2015, 12:58 PM   #16
wparsons
wparsons's Avatar
Someone asked for this in a PM, so I'll add it here too...
225/45/17 ZII's compared to stock:
Same ZII's compared to 205/50/17 Barum Polaris 3 snows:
Stack of 4 stock tires compared to 4 225/45/17 ZII's, both un mounted:
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
D_Thissen (04-14-2015), Mr.Impreza (10-01-2016)
Old 04-10-2015, 02:07 PM   #17
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Originally Posted by football751 View Post
Hmm, hadn't considered going to a smaller tire. Why would you recommend going a size smaller? Keep in mind this is just my DD with a lot of time spent at 70+ mph and no track time currently.
With a smaller diameter tire you are dropping the CG whatever ~1/2 the diameter difference is and the engine doesn't have to work as hard to rotate the smaller diameter tire/wheel. This translates to a little more planted ride, a little bit more responsiveness from the throttle, and a little bit quicker acceleration. You give up theoretical geared top speed due to the smaller diameter, but that is a non-issue with a drag limited vehicle with too little power and too high a gearing to even get to the theoretical top speed to begin with. Actual top speed with a smaller diameter tire would probably be higher than on stock sized tires due to engine being a little more 'efficient' in its power delivery... would need GPS to verify of course since speedometer will artificially read high.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
Old 04-13-2015, 12:40 PM   #18
football751
Drives: n/a
Thanks for the replies everyone! Decided to stick with the stock size MPSS, should get them installed this week.
football751 is offline   Reply With Quote
The Following User Says Thank You to football751 For This Useful Post:
Old 11-03-2015, 09:41 PM   #19
FRed-S
FRed-S's Avatar
Drives: 2015 Scion FR-S
Originally Posted by Vracer111 View Post
Stick with the factory 215 width unless you want a more expensive, heavier, and less responsive steering but the same grip tire in a 225... if it were an 8" wide rim it would be a different matter and the 225 width would probably be more preferable with it's 8.2" tread width. Also, the 225/45-17 size will have your speedometer off on the high side, meaning you will actually be going faster than what the speedometer shows (by a few MPH at Hwy speed) and your acceleration will be a little bit slower...
Personally I would go with a different size MPSS though for even better performance improvements over the stock tire size... 205/45-17.
I'm going with the 225's in the same tire as above. I did a bit of research and at 65mph the difference is less than 1 mph with the slightly bigger tire. I can't wait to get rid of the stock Prius tires lol. Big difference in grip and handling is a plus.
Sent from my XT1254 using Tapatalk
FRed-S
FRed-S is offline   Reply With Quote
FS: STOCK RIMS AND TIRES bhbnuckle Canada Classifieds 1 03-31-2014 10:02 PM
stock rims and tires bulldog11267mad Wheels and Tires 1 08-20-2013 10:58 AM
Wtb: stock rims only no tires whitefrs Wheels and Tires 1 04-25-2013 12:16 AM
WTB: OEM Stock rims and tires HATED1 Wheels and Tires 4 08-29-2012 03:23 PM
