Old 11-02-2015, 07:08 AM   #1
shern
Drives: 2015 fr-s
Reverse lockout is stiff
Hey guys so i have a problem and idk how to fix it, hoping one of you guys can help me out So whenever I lift up my reverse lockout to go into reverse it gets stuck, i am able to put it in reverse but when i take it out of reverse and put it in neutral the lever doesn't fall back down it stays up.
shern is offline   Reply With Quote
Old 11-02-2015, 11:14 AM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
maybe something sticky lub? i would disassemble lock and see what happens.
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
shern (11-02-2015)
Old 11-02-2015, 02:14 PM   #3
stevesnj
stevesnj's Avatar
If you have the stock shift knob just pry down the grey plastic collar and you'll see white plastic which is the plastic slipper for the lockout lever to slide against. Get some spray lithium grease and spray a little between the white slipper and the inside of the lockout lever.
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
humfrz (11-03-2015), shern (11-02-2015)
Old 11-02-2015, 04:36 PM   #4
shern
Drives: 2015 fr-s
thanks man this is going to be helpful but also when i lift up the lever it slightly turns to the right :/
Old 11-02-2015, 05:22 PM   #5
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Then you might want to check the lockout pin, it may be loose? defective or something as from memory it shouldn't be moving/rotating while raising it.
fumanchu1 is offline   Reply With Quote
The Following User Says Thank You to fumanchu1 For This Useful Post:
stevesnj (11-03-2015)
Old 11-02-2015, 07:50 PM   #6
shern
Drives: 2015 fr-s
yeah man rn im dissembling it and the white plastic things are a little crocked so I'm gonna heat them up and re instal hopefully all works well!
Old 11-03-2015, 01:02 AM   #7
Now, WHAT could go wrong with that ......
Old 11-03-2015, 01:22 AM   #8
"WTB - stock shift lever"
Old 11-03-2015, 09:44 AM   #9
shern
Drives: 2015 fr-s
Maybeeee How much
Old 11-03-2015, 11:37 AM   #10
Maybeeee How much
Uh oh. Don't give up.
Old 11-03-2015, 12:01 PM   #11
shern
Drives: 2015 fr-s
hahha i took it apart last night and the shifter is a little twisted i think :/
Old 11-03-2015, 02:27 PM   #12
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
$50 plus $300 for snh.
Old 11-03-2015, 04:08 PM   #13
shern
Drives: 2015 fr-s
sorry 300 is to much lol
The Following User Says Thank You to shern For This Useful Post:
Packofcrows (11-03-2015)
Old 11-03-2015, 05:21 PM   #14
You mean the slippy tape, or is there more wrong? Apologies if my joke came off sounding serious. I don't have a spare.
Did you get the roll pin out of the lockout knob ok?
Stiff to engage 1st/reverse from a stop after clutch install mhiscott Engine, Exhaust, Transmission 94 07-19-2020 07:11 PM
wtb oem reverse lockout Vincenttam Want-To-Buy Requests 0 02-09-2015 05:41 AM
Reverse lockout? MrMarinakos Cosmetic Modification (Interior/Exterior/Lighting) 0 04-28-2014 08:47 PM
FS: raceseng reverse lockout red White0utFrs Interior Parts (Incl. Lighting) 3 04-12-2014 01:15 PM
