#15 | |
Mine seems to be the opposite however, It was colder today than yesterday. Yesterday it made the noise, today it did not. I did not drive the car today, just went out in the garage and let it sit running idle for about 10 minutes to see if it would replicate the sound again, and of course it doesn't. I know cars aren't indestructible, I just hate having these types of issues when I'm not even at 50k miles. Most clutches/clutch components last up until at least 100k. At least in my other cars they have. |
#16 |
Drives: '13 FRS - STX
They don't engineer that part, they buy it from Exedy to my knowledge. I believe they can pay for a better part, but Subaru doesn't want to pay for it. Say a $10 upcharge gives you a bearing that outlasts the clutch material, Subaru has built or will build at least 200,000 86's, that's a cool $2 million in their pocket for picking the cheaper bearing.
#17 | |
With automatically adjusting hydraulic clutches, a spring in the slave cylinder maintains an ever-so-slight pressure on the assembly so the TO bearing spins all the time. It normally lasts just fine because there's no real load on it. When it's beginning to fail, the bearing sticks in the at-rest position. The squeak goes away when the extra force of depressing the clutch forces it to turn with the pressure plate fingers. Still, by the time it reaches that point, there's a bunch of heat and wear on the pressure plate fingers while it's squeaking, and way more when the blown bearing is spinning. OP needs to jump on it like yesterday while he only needs to replace the TO bearing. Any longer and he'll be replacing the pressure plate and the transmission front cover (snout).
#18 | |
Whether it's a bad release bearing (TOB), a broken or loose clutch spring, a bad front bearing, a warn or dry clutch fork, a separated clutch disk or a warped pressure plate ...... it should be fixed. So, like said up above, the time (labor) is the expensive part. While they have it opened up, they might as well replace the clutch, pressure plate, throw out bearing and clutch fork. Sorry about that ....... ![]() humfrz |
#19 | |
![]() My brain's "throw out bearing" got stuck back in the day (pre 1980s) when they shouldn't spin all the time. Thanks, @Ultramaroon for bringing this old coot into the present century .... ![]() humfrz |
#20 |
Interesting enough I was going through my paperwork on the car and was looking at the warranty. According to the paperwork on "power train" warranty under the transmission clause, the bearing(s) are covered.
Ive read on here that the dealerships do not cover the throw out bearing? Has anyone actually fought this? The reason I ask is because any other bearing on the car is covered. The throw out bearing is not really a "wear" item like the clutch or brakes. The wheel bearings are covered, the engine bearings are covered, etc. Just curious before I spend $$$ out of pocket that I don't necessarily have to spend. |
#21 | |
Drives: Firestorm 2013 FR-S
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
#22 |
I'm honestly surprised they haven't put out a recall on these cars yet, I've read countless threads about the throw out bearing now. Lesson learned on buying a first year car.
I take that back, apparently 2014's and 15's are having the same issues. I just hope the warranty holds true and it does get replaced. I'll find out later this week. |
#23 |
Drives: 2017 CWP BRZ Performance Package
I have this issue, but to a much lesser extent. Clutch makes a socket wrench noise when being depressed. I also have some weird screech noises during start up.
Taking the car in this sat for a 18k maintenance, and will bring it up. |
#24 |
Drives: White GTS then Black GTS
What is the solution to this? I think my 2015 GT86 also have the exact same problem.
| Clutch pedal loud squeak | Neekowahhhh | Issues | Warranty | Recalls / TSB | 617 | 09-18-2024 01:54 AM |
| Clutch squeak inside bell housing? | hukdizzle | Issues | Warranty | Recalls / TSB | 18 | 07-18-2015 11:54 AM |
| Clutch Squeak | CatDaddysBBQ | Issues | Warranty | Recalls / TSB | 4 | 07-14-2015 06:44 AM |
| Clutch pedal squeak. | merino_frs | Engine, Exhaust, Transmission | 1 | 08-25-2014 01:00 AM |
| Squeak noise from engine. | Fish | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 05-08-2014 01:06 PM |
