#43 |
Drives: Scion FR-S 2013 Raven
Basic tech info: spring rates, rear suspension, motion ratios, and you.
If you think this is amazing from scratch just keep it like this.
Or if you want a little drop maybe yes RCE yellow can do a good job without sacrificing too much the handling. Correct me if am wrong but I think RCE yellow make the car feel more neutral vs OEM. This is my feeling also on Mach V springs.
o= FR-S =o |
#44 |
Drives: Subaru BRZ, Nissan 240sx
Thanks for the thread!
| The Following User Says Thank You to Nissota For This Useful Post: | Racecomp Engineering (04-16-2015) |
#45 | |
- Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | chaoskaze (04-30-2015) |
#46 |
Drives: 2015 Subaru BRZ Limited 6MT
#47 |
Yes.
#48 |
Drives: 2015 FRS
So if I just want to lower my car around an inch, as I love the driving dynamics, would the RS-R S/Down do me well? Or would I also need to upgrade other areas of the suspension as well like sways, LCAs, ert?
#49 | |
Only a good set of springs and an good alignment will be fine to start. No need LCA for around one inch, I don't have LCA and am dropper 1" 3/8... Of course adjustable LCA are better, but this is to fine tune your alignment. You can run only lowers springs without any problems don't worry...and if you want, in the near future you have always the time to upstage others suspensions depend on what you will need concerning the handling of this car.
o= FR-S =o |
| The Following User Says Thank You to Mikepage For This Useful Post: | KidRed (09-21-2015) |
#50 |
Drives: 2015 FRS
^ Cool thanks. I've had coilovers before, but not sure if I want/need them if I really have no current plans on dropping below 1 1/2".
#51 | |
Drives: 2013 Subaru BRZ Limited LR
Also thanks for the list, some great reading! |
#52 |
Site Moderator
Drives: Stuff
Vendors? Probably few. Some manufacturers will.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#53 |
Drives: GTS 86 auto
I love our 2013 GTS86 auto but at 70+ years of age the wife in particular hates the hard ride. Can anyone advise on modification to make it like (for instance) a Golf GTI which seems about the right amount of suppleness for our taste please.
I am thinking trying different springs first then dampers but have no idea about rates.
GTS86 Auto (Australia)
#54 | |
Bilstein B6 will ride well too, but a little more "sport" in comparison. If ride quality is your main goal, I would stick with OEM springs. BUT the new version of the Ohlins coilovers would also work well, at quite a bit more cost. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | notout86 (04-17-2018) |
#55 | |
Drives: 2018 BRZ Limited, 2017 Sportage
| The Following User Says Thank You to rvoll For This Useful Post: | notout86 (04-17-2018) |
#56 | |
Drives: GTS 86 auto
| MotoIQ: Tech Look at FR-S Underside - Suspension, Chassis, Brakes, Differential | oneday | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 93 | 09-22-2017 10:47 AM |
| Is anyone going to motion car show? | Pekingduck | Southern California | 15 | 05-20-2012 11:46 PM |
| Weird GT 86 factory spring rates in GT5? | Spec-Al | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 36 | 03-27-2012 02:30 PM |
| TRD 86 MSB (Motor Sports Basic) Race Packages Announced | switchlanez | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 03-27-2012 08:31 AM |
| Crazy idea... the Rear Seat info ? | MRZ415 | Scion FR-S / Toyota 86 GT86 General Forum | 78 | 01-27-2012 12:19 PM |
