Pat.Thornton
Old 10-22-2015, 05:07 PM   #323
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
So, is the consensus still that this hasn't been fixed for sure? I've got the same issue where it squeaks when the clutch pedal is depressed. It also honks from time to time. I thought initially because of the warm weather but it's been getting cold here in the mornings and it still doing it.
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 10-22-2015, 09:11 PM   #324
ZZT86
ZZT86's Avatar
Drives: BR86
I did the clean & lube thing almost 2 months ago (see post @ foot of p13) and it's still fine, cold or hot doesn't matter. Time will tell.
ZZT86 is offline   Reply With Quote
Old 10-23-2015, 11:53 AM   #325
ap5512
ap5512's Avatar
I want to give the grease a try but not sure where in this thread the directions are?
I need to know the following things:
- where/what exactly needs the greasing (clutch fork?)
- location (pics?) of the parts needing to be greased
- what all I'll need (jacks, tools?)
If there is a DIY for this or someone posted instructions, please share the link. THanks.
The Following User Says Thank You to ap5512 For This Useful Post:
bhbnuckle (06-28-2016)
Old 10-30-2015, 11:59 AM   #326
cmihaylov
Just got off the phone with the dealership, and they will be replacing the clutch, fly wheel, pressure plate, the clutch fork, and the throwout bearing. The service guy told me that Subaru knows about this, so if you have the same problem and are still under the powertrain warranty, don't hesitate to take it to your dealer.
cmihaylov is offline   Reply With Quote
The Following User Says Thank You to cmihaylov For This Useful Post:
gonzo (11-05-2015)
Old 10-30-2015, 05:08 PM   #327
gravitylover
^^ If you can get something written that confirms this it would surely help.
The Following 3 Users Say Thank You to gravitylover For This Useful Post:
gonzo (11-05-2015), kuczynskika (10-30-2015), zonda (10-30-2015)
Old 11-03-2015, 08:34 PM   #328
ZZT86
ZZT86's Avatar
Drives: BR86
TSB ?
Old 11-04-2015, 09:13 PM   #329
Brndn704
Brndn704's Avatar
I second this!
Brndn704 is offline   Reply With Quote
Old 11-05-2015, 10:37 PM   #330
gonzo
Drives: frs
If the bearing is bad, at idle, in neutral, if you're not on the clutch, you'll hear the bearing.
Even with a bad bearing, the car should run for quite a while, but it's better to get it replaced sooner, rather than later. The bearing is cheap, but the labor is $$$.
I thought that the bearing isn't moving unless the clutch pedal is depressed? How can it make noise if you're not on the clutch? Something (throwout bearing?) is making a noise only when my pedal is depressed. A year ago it started with the squeaking at the bottom of the clutch pedal's travel.
gonzo is offline   Reply With Quote
Old 11-05-2015, 10:48 PM   #331
gonzo
Drives: frs
Originally Posted by mokinbird87 View Post
how many petitions was needed for a recall to happen again? I mean, what do I do when I run out of the powertrain warranty?
Add myself and a friend to the list. Can we get a list going? Once we hit 200 I'm sure a well worded letter to Toyota/Scion/Subaru executives (CEO and what not) will help with dealer denying it's a defect. They made my friend pay $500 or told him to come tow his car to another autoshop, lol. They blamed it on his aggressive driving and pointed to the "hot spots" on his clutch.
I'm taking mine in in Dec. Pray for me.
Old 11-05-2015, 11:23 PM   #332
gonzo
Drives: frs
Originally Posted by Brndn704 View Post
I second this!
Third. My friend and I have the same problem.
Old 11-06-2015, 12:15 AM   #333
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Been experiencing an issue where with the clutch depressed upon start up it makes a clunk. Then when sitting at idle, pressing the clutch makes the same sort of clunk noise. Anyone have any idea?
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 11-06-2015, 02:13 PM   #334
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Looks like the 2015 wrx has a similar issue.
http://www.clubwrx.net/forums/transm...=1446836979879
and
http://forums.nasioc.com/forums/show....php?t=2679951
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 11-06-2015, 02:37 PM   #335
lancie
lancie's Avatar
Drives: brz wrb
Same issue. Resolved waiting 30sec/1min before starting in 1st gear
lancie is offline   Reply With Quote
Old 11-06-2015, 04:00 PM   #336
Tt3Sheppard
Has anyone tried using Lithium grease on the clutch rod that is above the gas pedal that goes into the firewall. I can't remember if this had some grease on it when I purchased the car.
[ame="https://www.youtube.com/watch?v=V1N2mHA3blQ"]Clutch pedal noise squeak sound Subaru Series Part 13 WRX STi fix solution slave cylinder - YouTube[/ame]
This location ^
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
The Following User Says Thank You to Tt3Sheppard For This Useful Post:
jcw99 (11-09-2015)
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 08:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 02:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 04:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 06:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 01:00 AM
