Old 10-27-2015, 04:55 PM   #3109
CSG Mike
CSG Mike's Avatar
Originally Posted by MaximeT View Post
I got a tyre wear question.
Do you think you'll get more track miles out of an Hankook RS3 or out of the F200 hard race slick ?
Dunno the rating of the F200, but Michelin slicks are rated at 200km in race condition. That's the manufacturer specification and not the actual maximum mileage the tire can do.
I can get 500 km out of a rear set of a048r on the Lotus (same rear weight and power as the 86) with an enjoyable pace.
Would you use 215 or 235mm wide slicks (race size, not road size) with a Jackson Racing supercharger ?
I can't try both because one need 8" wheel and the other 9". So I need to purchase the right size wheel.
I may try different road going track tires, but race slick are 1300-1500€ a set out there. I can't afford to burn them in less than 400km.
The goal is to drive track days and no actual races. The tire will obviously be competitive for something like 20-50km
The wheels gonna be 949 6ul provided by CSG
A big thanks
Edit : my driving style is nice on tires.
That depends... are we talking hot lapping sessions, sprint races, or endurance races?
CSG Mike is online now   Reply With Quote
Old 10-27-2015, 04:58 PM   #3110
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
We are talking 20min hot lapping sessions. 5 a day.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 10-27-2015, 05:16 PM   #3111
CSG Mike
CSG Mike's Avatar
Have you considered entry level R-compounds? Nitto NT01 or Maxxis RC1?
Both can take 20 minute sessions well, and usually last between 5-8 track days depending on the setup and driver.
Old 10-27-2015, 05:24 PM   #3112
MaximeT
MaximeT's Avatar
They are sadly not available in Europe. We have easy access to a048r (but no a050r), r888 and r888r, and I just found a dealer for RS3.
If I search a lot, I might find Khumo v70 and Avon ZZR
We have access to the more street friendly ado8r and t1r too.
I just found Hoosier European prices. They are just plain stupid.
Old 10-27-2015, 06:08 PM   #3113
CSG Mike
CSG Mike's Avatar
In that case, try the RS3 or AD08R. It's easier to go sticker, than to lose grip.
Old 10-27-2015, 06:09 PM   #3114
MaximeT
MaximeT's Avatar
Thanks, I'll try both.
Old 10-27-2015, 07:23 PM   #3115
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
This applies to pretty much any production car though...
Not wrong, but there are some accessible exceptions like the Miata, RX-8, S2000, and others which have adjustable double wishbone/multilink setups from the factory where the cost of getting a sporty alignment does not include $100+ worth of hardware.
After all the bare barest minimum on the 86 is eccentric/undersized 'crash' bolts front and rear (<$50 part cost up to $80-$100 for name brand, maybe a half hour to a full hour+ billable install time, whether or not you do it yourself, I know I don't work for free). And really, you want a decent set of camber plates and LCA's so you're not second guessing your hardware which by my math really can't be done for less than $400, and the pretty stuff will put you up at $1k.
I love my 86 and had full intention on keeping it until it becomes a money pit, the problems are workable because the money and desire is there, Porsche makes struts work after all.
But Mazda showing new concept RX in 5 minutes...
ineedyourdiddly
Old 10-27-2015, 09:56 PM   #3116
CSG Mike
CSG Mike's Avatar
My s2k required $700 in hardware, not including labor, to get a proper sporty alignment.
Old 10-27-2015, 11:30 PM   #3117
At the end of the day, all except the most super of supercars are tuned to behave predictably when the uninitiated driver exceeds the stability envelope of the vehicle. It is supposed to be difficult to move the handling characteristics in the direction of performance. If it was easy and cheap, even more idiots would be eating guard rails than are now.
I like my insurance rates as they are.
Old 10-28-2015, 03:07 AM   #3118
strat61caster
Yup eating my words a bit as I unearth the deeper stuff, gotta get past the 'noob your car doesn't need any hardware for adequate camber' because the average guy is happy to run in the -1 to -2 degree range (mx-5 and s2k). Maybe I'd be happy with that on the 86 for now, but I jumped from ~0 to -1 to over -3 so guess I'll never know.
Given how hard it is to convince some people that an alignment will net them more performance than a set of $800 ebay coilovers, I think you're overestimating how many "idiots" would take advantage of adjustable alignment hardware.
Lesson learned, pay to play. I'll keep saving up for those LCA's.
ineedyourdiddly
Old 10-28-2015, 08:19 AM   #3119
VADERR
Completely Lost
VADERR's Avatar
Drives: 2015 CBS BRZ Limited
Going to TWS this weekend any pointers? CCW 2.9 btw.
VADERR is offline   Reply With Quote
Old 10-28-2015, 08:39 AM   #3120
DarkSunrise
DarkSunrise's Avatar
Haha doubtful. I'm at -1.5 deg and my tire wear is funky. The outer edge gets trashed first, then the outer edge of the center tread. All the tread blocks look slanted and I end up with > 2/32" variation across the tire.
The one saving grace is the factory square tire setup. You can "resurface" the tire by rotating it to the rear lol.
Don't worry - you made the right choice by jumping to the deep end first on camber.
2022 BRZ Build
2013 FR-S Build
Old 10-28-2015, 11:38 AM   #3121
strat61caster
Because these tires saw track time on all three up front because I am still wrapping my head around this 'rotation' thing I've got outer edge wear from not enough camber and inner edge wear from too much camber on the street, basically crowned it
But you're totally right, the rears have worn beautifully.
ineedyourdiddly
Old 10-28-2015, 11:43 AM   #3122
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Stay low on the oval, then move up high to scrub speed and give yourself a wider turn before going into turn 1.
Sent from my XT1095 using Tapatalk
ScionOfHorus is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
