Old 10-27-2015, 12:39 PM   #1
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Question Winter Time Tire Fitment
Looking at picking up WS80 Blizzaks for my stock wheels.
What is the skinniest tire with the highest sidewall I can run without rubbing?
I am on an Eibach Prokit and a STi front lip, so I'm looking to run something like 205/55/17. I'm trying to run a higher sidewall measurement to gain some ground clearance. Would something like 195/60/17 even be a possibility?
Thanks in advance!
Bg8780 is offline   Reply With Quote
Old 10-27-2015, 02:50 PM   #2
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
That's going to be a very tall setup, much taller than stock. I can't say from personal experience, but I would expect it to rub; especially with the 1" drop from the ProKit.
I definitely wouldn't go narrower than 205 on the stock wheels. I went through winter in Chicago on stock wheels and stock sized WS80s this past winter, and the car performed amazingly. This year I decided to downsize to 16x6.5" wheels with a set of 205/55/16 WS80s. The setup is just slightly taller than stock, and I expect it to work even better.
If you want to go that narrow and tall, I'd downsize your winter wheels. I suppose that defeats the intended purpose to really raise the car up, but with such a mild drop you should be fine. Plenty of people out here ran lower than that last winter. Only one cracked STi lip, and that's because he went deep into some snow after spinning off course during a rallyx in the middle of a frozen lake.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
Bg8780 (10-27-2015)
Old 10-27-2015, 02:54 PM   #3
Bg8780
Bg8780's Avatar
Exactly the info I was looking for! Thank you! I'll pick up some 215/55/17 for the stock wheels and see how it goes.
Thanks again!
Old 10-27-2015, 03:05 PM   #4
adamg
Drives: brz
i had my car on stock series.blue wheels and 215/45/17 winter tires last year and lowered about 3" with sti lip, skirts, and rear splats.
had no problems
adamg is offline   Reply With Quote
The Following User Says Thank You to adamg For This Useful Post:
Bg8780 (10-27-2015)
Old 10-27-2015, 03:22 PM   #5
frslee
Just drive it
Drives: 13' FR-S
You can go with tirerack's recommendation of either 215/45/17 or 205/50/17.
frslee is offline   Reply With Quote
Old 10-27-2015, 03:23 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
.. i'd go for something like 205/50R17. It's just +2% so no much gains in ground clearance, bet it also will mean that it will be similar to stock 215/45/R17. 195 might be overkill, but 205 of just one step narrower sounds fine on stock wheels, especially because those will be winter tires, that benefit from narrower contact patch/higher weight/pressure per area.
At least that would be my choice for next winter, for this i'll burn stock-sized free winter tires that dealer had thrown in due car purchase being in late last autumn
Old 10-27-2015, 05:07 PM   #7
Shark_Bait88
Thanks again!
I'd go 215/45/17 or 205/50/17, per what other people have said. The 215/55 will still be pretty big.
Bg8780 (10-28-2015)
Old 10-27-2015, 07:48 PM   #8
Vten
Drives: Too heavy
I'm using blizzaks lm60 235/45/17 , no rubs ,17x9.25 et36 wheels, max drop on tein street flex coils.
Vten is offline   Reply With Quote
Old 10-27-2015, 09:30 PM   #9
gravitylover
I run 205/50/17 Conti EWC's on Outback wheels. Quite a bit more comfy ride than stock, phenomenal bad weather traction (wet or snow) and predictable cold pavement handling at all speeds. I do 110 miles a day five days a week with ~95 miles at highway speeds and the rest in NYC and the neighborhood I live in.
The Following User Says Thank You to gravitylover For This Useful Post:
Bg8780 (10-29-2015)
Old 10-27-2015, 10:31 PM   #10
cjd
cjd's Avatar
Drives: 2017 BRZ
I have 205/50/17 on a 7.5" (yes, wider than ideal) wheel and it's not bad at all.
I admit I'm very tempted to sell these (Pirelli Sottozero 3) and update to slightly wider Nokian WRG3, since that would fill the seasonal gap when my summer tires aren't up to snuff a bit better... The Pirelli is actually rather decent all around, but is softer feeling than the WRG3 - probably better in actual deep snow, but it's more sub-freezing temps and slush/wet/dry that I see here in Chicago.
I'd have preferred a 7" wheel but also wanted to have the option of leaving the BBK on the car with the intent to drive it only in an emergency... I really need a 3 car garage, but that's not happening in the city easily!
The Following 2 Users Say Thank You to cjd For This Useful Post:
Bg8780 (10-29-2015), Shark_Bait88 (10-28-2015)
Old 10-28-2015, 12:34 PM   #11
Shark_Bait88
Hell, I'd be happy with a one car garage! Even that's a lot to ask around the city. haha
Old 10-28-2015, 05:08 PM   #12
cjd
cjd's Avatar
Drives: 2017 BRZ
It's easier if you somehow swing a single family house... I don't have room for a lift though, so not all dreams become reality. I also only drive because I want to, though... Something nice about that.
The Following User Says Thank You to cjd For This Useful Post:
Fitment of Winter Tires on Stock Rims: X-Ice 3 215/55/17 hyper4mance Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 10-23-2017 12:17 AM
Need help on tire fitment white_frs_e46 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-03-2015 08:25 PM
Rim and Tire fitment XXR 530 zuurdeegfrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 03-19-2015 11:17 PM
Big brake upgrade + Winter fitment Mikeez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-09-2014 08:45 PM
Need help on tire fitment, Please! Rbmonroe Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-20-2014 02:52 PM
