Old 06-03-2012, 09:18 PM   #169
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
nice to meet cha
Scooby South is offline   Reply With Quote
Old 06-03-2012, 09:37 PM   #170
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Let's get a pic with all 4 wheels!!
- The Ancient BRZ Sacrament
by Zaku
The Following User Says Thank You to Guff For This Useful Post:
Fly Guy (06-04-2012)
Old 06-03-2012, 10:45 PM   #171
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Something that makes me nervous is the fuel cut off. Would rather it bounced and not just cutt off and bogs down. My automatic tc would bounce off 2nd gear. But today I hit the rev limiter and it fuel cut off and boged down. Going to make things interesting where you don't want to get into 3rd
Edit. Someone said it jumps back to 7000rpms and that may have been what I felt today? We will see this up coming weekend for sure.
feldy is offline   Reply With Quote
Old 06-04-2012, 09:01 AM   #172
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
you are my hero!!! whata perfect fit and look!
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 06-04-2012, 11:44 PM   #173
Scooby South
Conedancer
First tour and Pro Mod...
Old 06-05-2012, 01:20 PM   #174
Mavrik
Been following this thread and on NASIOC.
Have you run your BRZ with those wheels with the TPMS light on? Can you turn off all the driver assists still?
I'm likely going to get a autocross/BRZ dedicated set of rims and tires on mine for next year but this year Starspecs and BBS rims off my 2.5RS. Obviously they don't have sensors.
Mavrik is offline   Reply With Quote
Old 06-05-2012, 01:25 PM   #175
Getagrip
Getagrip's Avatar
Drives: SWP BRZ
Wondering the same thing. You could drop the pressure in one of the tires to 29-30 psi and wait for the light to come on after driving and then try to disable the nannies and see if it works.
SWP BRZ
Getagrip is offline   Reply With Quote
Old 06-05-2012, 02:46 PM   #176
Scooby South
Conedancer
I will know for sure this weekend... My Scooby Tech Friend can't find any connection between TPMS and Traction control... I am running my BBS w/ 235/40/17 RE-01r's with no sensors ...and will report back..as the Sensors will be in the 17x9 wheels with the 245's... which I am not going to run and RUIN without some sort of Camber that I can Rely on.... So the RE01's get the nod this weekend..
Bill
Old 06-05-2012, 02:51 PM   #177
Scooby South
Conedancer
Need an opinion...
I have Subaru 4 pots on my Daily Driver...*the Speedwagon as I refer to it...the plan was to use the BRZ wheels on the speedwagon ...problem is...the BRZ wheels don't Fit over the Brakes... soo the delima is: move the 4 pots over to the BRZ...and stock 2 pots to the Speedwagon so the wheels fit and life goes on... or just get another set of cheap daily wheels that fit the brakes and sell the BRZ Wheels to someone???
the Plus side: I would have 4pots on the BRZ...
and stainless lines
Better brakeing??? I already know Better pads...and new Rotors as well
THOUGHTs???
Old 06-05-2012, 07:20 PM   #178
Vanguard
Drives: Ford F-150 (not for long)
My knowledge on swapping calipers for classing is fuzzy...Is that an ST* legal mod? If it isn't, I wouldn't touch it because the street prepared class can be a serious money pit!
Vanguard is offline   Reply With Quote
Old 06-05-2012, 08:40 PM   #179
Scooby South
Conedancer
From 14.6
Brake calipers and mounting brackets may be replaced provided they bolt
to the standard locations and the number of pistons is equal to or
greater than standard. A functioning emergency brake of the same
type, operation, and actuation as OE must be present.
yes..Legal in ST
Old 06-05-2012, 09:02 PM   #180
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Try for a while with the stock brakes. With a car under under 2700 lbs you likely dont need 4 pots. Stock brakes with High Performance pads should be more than adequate.
We run stock brakes on the GXP with EBC Yellow Stuff pads, and with 315 tires we have more issues with brake lock-up and ABS than we do with a lack of braking power.
Sccabrz192 is offline   Reply With Quote
Old 06-05-2012, 09:38 PM   #181
Scooby South
Conedancer
for Reference...
Old 06-05-2012, 09:39 PM   #182
Scooby South
Conedancer
I hear you...Gotta admit...they are sexy tho...
Bill
Subaru/Scion warranty and autocross Ribface Tracking / Autocross / HPDE / Drifting 55 06-17-2015 08:30 PM
Will you Autocross your 86? Ribface Tracking / Autocross / HPDE / Drifting 131 06-22-2012 05:48 PM
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
FR-S at a CA Autocross oneday Scion FR-S / Toyota 86 GT86 General Forum 57 03-26-2012 03:38 PM
