Old 10-25-2015, 05:44 PM   #1569
Trust86
Drives: 2016 Halo FRS
what's the reason people run stretched tires? is everyone "stanced"?
or is it because they like the rims to take curb rash before the tire does?
not trolling. legitimate question.
Trust86 is offline   Reply With Quote
Old 10-25-2015, 05:57 PM   #1570
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I foresee this thread going down the tubes.
Sent from my XT1095 using Tapatalk
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 10-25-2015, 07:07 PM   #1571
churchx
churchx's Avatar
Drives: 2014 GT86
Trust86: stretching reduces sidewall flex. Origin was to stiffen in cheap/hackish way sidewall in normal (cheap) street tires to make sharper turn in/steering by amateur drifters/touge drivers (hmm, wasn't it called "hipari"?). Cheap/hackish way to do that, at expense of smaller contact patch, risking separation of tire from rim, easier to damage wheel sides, heavier wheels (weight increases not just from diameter but also from width). But later it become overhyped, at some scenes seemed cool, and most often then not was done for looks. These days with better tire choice for any taste with any sidewall stiffness and more modern suspensions i see no reasons to do that with practical sense. Why get cons if you can get wished result in normal ways?
The Following 3 Users Say Thank You to churchx For This Useful Post:
civicdrivr (10-25-2015), Clipdat (11-05-2015), DAEMANO (10-25-2015)
Old 10-25-2015, 10:35 PM   #1572
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Originally Posted by Chanpion View Post
I can't prove it on the BRZ setup but generally, a thinner tire in the front will have better turn in. Physics wise, think of it as these two examples, two wheels far apart and twowheels close together. Now imagine the distance between the two tires in these two examples as the width of a single tire. When 2 wheels are far apart, one wheel does all the turning while the other wheel creates understeer. Now for example two, place these two wheels close together in the middle. They both act together to turn instead of one creating understeer/ one wheels slower than the other. Now squish this theory into a single tire. Larger the tires, the greater the travel circumference between the inner and outer side of the tire.
That's why some people run a staggerred setup with thinner tires in the front for better turn in and entry speed. This is my best shot at a simple physics lesson.
So physics wise, a skinner tire may be faster. There's so many variables though. So whoever you quoted may actually be right.
In my experience a wider tire will improve turn-in. I think you're mistaking 'easier' for 'better' and that may be your preference but for me that's not the case.
The car has more lateral grip and thus negates under-steer better with a wider tire. Yes, the momentum of a wider tire may be higher and therefore turn-in requires more effort and accordingly turn in on a skinnier tire may be 'easier' due to lower momentum but for my money that not does not mean 'better'.
I've gone from 215/45/17 to 245/35/18 back to 215/45/17 and now on 255/35/18 in the three years I've owned my car and for me, on balance for spirited back country road driving, wider tires provide a much improved driving experience through grip and stability primarily.
The downside is tram-lining and a reluctance to return 'on center' but I got used to these and just enjoy railing corners at speeds that are far in excess of what I've experienced (and are comfortable doing) on skinny road tires.
Edit: running staggered tires will not reduce under-steer, it will increase it.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
The Following 6 Users Say Thank You to Metabrz For This Useful Post:
AznKirby (10-26-2015), civicdrivr (10-26-2015), Clipdat (11-05-2015), DustinS (10-26-2015), jbailey8748 (10-31-2015), winsometang (10-25-2015)
Old 10-26-2015, 05:24 AM   #1573
Metabrz
001 of 012
Metabrz's Avatar
iPhone pics
The Following 4 Users Say Thank You to Metabrz For This Useful Post:
DustinS (10-26-2015), Hicklinc (02-25-2018), Jive Turkey (10-26-2015), Leonardo (10-26-2015)
Old 11-05-2015, 08:41 AM   #1574
mrlamjo
Drives: 86
TOYO R888 - 265/35/18
Camber - F: -3/R: -2
mrlamjo is offline   Reply With Quote
The Following 8 Users Say Thank You to mrlamjo For This Useful Post:
civicdrivr (11-05-2015), Figo (11-09-2015), Hicklinc (02-25-2018), Metabrz (11-05-2015), NotSoJDM (11-05-2015), Pekingduck (11-07-2015), PeterFRS (12-05-2015), SlammedSilly (12-03-2015)
Old 11-05-2015, 10:12 AM   #1575
Bamsterman
Drives: 13' Scion FRS
Hopefully soon enough I'll be a part of this thread...well, I actually already bought the wheels. Just need coilovers and tires. Lol
Bamsterman is offline   Reply With Quote
Old 11-07-2015, 11:14 PM   #1576
Pekingduck
Drives: 4 wheels
I had similar and it look like I would have to run to aggressive alignment setup, but now I am regretting getting rid of it.
Pekingduck is offline   Reply With Quote
Old 11-09-2015, 08:27 AM   #1577
mrlamjo
Drives: 86
LCA is all that is needed
Old 11-12-2015, 12:49 AM   #1578
showoff3civic
Drives: 2015 BRZ
Ambit 18x9.5 +38
Dunlop Spec star II 265/35 18
front: -1.7
Rear: -1.5
St Coilovers
Front Fenders pulled 10MM
showoff3civic is offline   Reply With Quote
The Following 5 Users Say Thank You to showoff3civic For This Useful Post:
brandonblt2 (12-15-2015), Hicklinc (02-25-2018), Metabrz (11-15-2015), Mtl86 (03-11-2016), sactownbwoy (11-12-2015)
Old 11-12-2015, 11:58 AM   #1579
sactownbwoy
sactownbwoy's Avatar
Drives: 2014 BRZ Limited
Originally Posted by showoff3civic View Post
Ambit 18x9.5 +38
front: -1.7
Rear: -1.5
St Coilovers
I see you are running Star Specs. So few people run them. I have them also, 255/40, and I love them. Your setup looks nice
sactownbwoy is offline   Reply With Quote
Old 11-12-2015, 12:00 PM   #1580
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I used to run them as well but switched to the PSS. They weren't bad but they didn't last long.
Parting out HERE
Old 11-12-2015, 12:19 PM   #1581
Bamsterman
Ambit 18x9.5 +38
front: -1.7
Rear: -1.5
St Coilovers
Exact set up I want. Already have the wheels. Was it needed to pull the front fenders, or was it more of a precaution?
Old 11-12-2015, 12:31 PM   #1582
JoeHK
JoeHK's Avatar
Drives: Raven Toyota GT86
18x9.5 ET44 + 255/35/18
Got my wheels & tires installed today
Squared setup is as follows: 18x9.5 ET44 (Rota RKR) with 255/35/18 Hankook Ventus V12. Also, my car is lowered around 35mm on Bilstein B14's
Toyota Corolla E12 Hatchback (2005) - GONE
Toyobaru GT86 ハチロク - CURRENT
JoeHK is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
