Old 10-24-2015, 09:46 PM   #15
02.ACCORD.DUDE
Car N00B
Drives: Honda Accord (2002)
Just about any winter tire will work equally well just stay away fro "performance" snow tires. I went with 16/205/55 on steel rimes and they worked well.
Thanks one more question, at what size will I run into the issue of the rim not clearing my calipers (is there a way to check?)?
I'm 99.7% sure I'll be fine with the ones in my cart right now, but was just curious as I've had a few people tell me to make sure.
02.ACCORD.DUDE is offline   Reply With Quote
Old 10-24-2015, 09:55 PM   #16
What are you looking at?
Old 10-24-2015, 10:06 PM   #17
02.ACCORD.DUDE
Car N00B
http://m.tirerack.com/tires/TireDeta...S&autoModClar=
Goodyear ultra grip wrt, just trying to see if there was any reason they might not fit
Old 10-24-2015, 10:13 PM   #18
Those will be perfect.
Old 10-24-2015, 10:32 PM   #19
stevesnj
stevesnj's Avatar
What county in Jersey? Camden Cnty. here
My 2016 Build thread
Old 10-24-2015, 10:44 PM   #20
02.ACCORD.DUDE
Car N00B
Hunterdon (Central)
Old 10-25-2015, 06:21 PM   #21
02.ACCORD.DUDE
Car N00B
Still haven't hit submit on my cart yet... Because I'm wondering if I really need the steel wheels, my current stock rims are a bit scraped up as they are...
Other than durability do steel wheels make much of a different for winter driving (added weight / traction?)?
Also I pulled this from the tirerack website for one of the local "recommended installers":
1. Can't I just install mounted/balanced tires from tirerack as you would a spare?
2. Is this saying this particular dealer charges $5 per mounted/balanced tire to install? They quoted me at $20...
Old 10-25-2015, 07:47 PM   #22
Akari
Drives: 2013 DGM BRZ
Yeah, if you have new wheels/tires then you can just pull the old ones off, put the new ones on and torque your lugs properly. Sounds like that $5/ea is for exactly that service if you don't want to do it yourself.
The wheel itself makes really no noticible difference. Typically I put snow tires on my OEM rims and then summer tires on a better wheel.
Akari is offline   Reply With Quote
Old 10-25-2015, 08:27 PM   #23
02.ACCORD.DUDE
Car N00B
Thanks, if it seems like I confirm and then re-confirm and re-confirm again everything it's probably because I am (unintentionally)... This car is kind of my crash course in car maintenance / care.
Looks like all that's left for me (for real this time) is to figure out is whether to run stock rims in winter or get steelies... Will probably end up flipping a coin at this rate
Old 10-25-2015, 10:13 PM   #24
02.ACCORD.DUDE
Car N00B
I put my order in today, ended up going with the 205/55R-16 Goodyear Ultra Grip Ice WRT.
With the steel rims it came out to $782 - but I should be getting a "rebate"* of $110 eventually...
*It's a Goodyear VISA so presumably you can only use the car at Goodyear, not entirely sure what I'd spend the $ on, most likely as an emergency fund I guess in case I get a flat / need a new rim, TPMS, etc.
Thank you everyone for the help, Thursday is going to take forever to get here...
Old 10-30-2015, 08:45 PM   #25
Old 10-30-2015, 09:24 PM   #26
RustySocket
Slow Learner
RustySocket's Avatar
Drives: 15 Halo FRS
This is what happened to me a couple of weeks ago in my truck. Made a nice mess of the rear quarter panel as well.
I'm damn glad I wasn't pulling my travel trailer on the freeway when it blew. BTW, no previous sidewall damage. Once everything is fixed, new tires, and damage will be close to 3500$
RustySocket is offline   Reply With Quote
Old 10-31-2015, 03:01 AM   #27
Thanks Rust. I am going to save this pic and your story for the guys that think they can't go just a little further on a damaged tire. I have blown a couple but they were in the pre cellphone/camera days so had no pics.
Stock Motor is Toast (Spun Rod Bearing) DFW-FRS Issues | Warranty | Recalls / TSB 78 02-13-2018 11:56 AM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 01:44 PM
Tire Blown - Recommended Tire Repair Shop? chermo12 CANADA 3 07-27-2015 11:20 AM
Tire compound vs Tire size Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-22-2015 10:55 AM
Dai Yoshihara's 2014 Falken Tire/Discount Tire Subaru BRZ FD Reveal SnapOv3st3r BRZ Photos, Videos, Wallpapers, Gallery Forum 62 04-15-2014 02:26 PM
