Old 10-15-2015, 09:06 AM   #29
smudge
Drives: Supercharged GT86
So, the 3" catback has been ordered
Header will either be custom or a JDL UEL with a 3" collector
Overpipe and frontpipe will most likely be custom made seeing as Nameless don't want to get back to my emails, website inquiries or PM's on here...shame
smudge is offline   Reply With Quote
Old 10-18-2015, 05:19 PM   #30
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
I'm in the same boat as @smudge running the Sprintex 335 supercharger.
I want to get the most out of my setup so I am considering running a full 3" exhaust. I don't mind loud, but I don't want my ears to bleed...
The two setup options I am considering:
2.5" setup
JDL catless UEL (for more low end power and subie rumble)
JDL 2.5" overpipe
JDL 2.5" catted/resonated frontpipe
2.5" ARK DT-S exhaust or 2.5" JDL D2 exhaust
3" setup
JDL 3" overpipe
JDL 3" catted/resonated frontpipe
3" JDL D2 exhaust
I would think the JDL exhaust is much lighter than the ARK, but I can't find a lot of information of users having experience with the JDL exhaust. I found they have different tip options and are running a Magnaflow resonator. JDL's quality is top notch and it might be best to run their full setup. Just not sure if it would refine the sound better with the ARK DT-S and avoid DRONE.
JDL exhaust has an option of JDL Tips or Standard Double Wall Tips, just not sure the difference and diameter, etc.
Looks like they might have a slash tip option which I would definitely go with if I choose their exhaust. Not sure if the JDL will DRONE.
Chad86 is offline   Reply With Quote
The Following User Says Thank You to Chad86 For This Useful Post:
smudge (10-19-2015)
Old 10-20-2015, 11:29 PM   #31
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I used rubber grommets I made from scrap and wedged in between the engine and the frame when aligning my three inch overpipe. I don't get rattles or anything at idle or down shifts. 1 tip is to leave the exhaust bracket by the transmission loose when aligning the over pipe. Have someone up front checking clearance as you raise or lower the exhaust from the transmission exhaust hanger bracket.
Fullblown Motorsports was kind enough to give me a flex pipe on my exhaust just passed the other pipe. With a tiny bit of force I was able to align everything perfectly.
Fullblown Motorsports doesn't advertise publicly but they do offer a over pipe all the way to axle back that is entirely 3 inch with v bands cheaper than nameless in the other competitors. I had 0 fitment issues...
You will not find this exhaust with over pipe and front pipe on the website you need to call them directly.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 10-21-2015, 08:59 AM   #32
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Anyone have any input on the three inch Xforce exhaust?
Seems like a bargain with a decent sound.
The Following User Says Thank You to Summerwolf For This Useful Post:
Chad86 (10-21-2015)
Old 10-22-2015, 01:18 AM   #33
Chad86
Chad86's Avatar
Drives: Toyota GT86
Cool
Decided on full 3" setup from JDL
JDL 3" overpipe
3" JDL D2 exhaust
Old 10-22-2015, 08:33 AM   #34
smudge
Bargain for a 3" system? Those 2 things shouldn't go together...I'd be worried about quality
Old 10-22-2015, 09:44 AM   #35
Summerwolf
Panda Trueno
Summerwolf's Avatar
Its Xforce....so their reputation is pretty established. I just don't think its popular or well known here in the states. They are a huge exhaust company in Australia.
http://www.rallysportdirect.com/shop...t-back-exhaust
Just don't know of anyone running it, and there are only a few threads here about it. Overall consensus seems extremely positive.
http://www.ft86club.com/forums/showthread.php?t=20744
More info from 2012.... lol
Old 10-22-2015, 12:21 PM   #36
kch
Senior Misanthrope
kch's Avatar
JDL 3" overpipe
3" JDL D2 exhaust
Nice! You should take some vids so we can hear what a full 3" JDL setup sounds like.
Old 10-23-2015, 01:06 AM   #37
Chad86
Chad86's Avatar
Drives: Toyota GT86
Cool
I'll get some videos up as soon as I can.
Full 3" JDL, Sprintex Supercharged!
Old 10-24-2015, 02:16 AM   #38
Chad86
Chad86's Avatar
Drives: Toyota GT86
Cool FT86 JDL turbo with 3" Full Exhaust D2
Found this nice clip of the D2
[ame="https://www.youtube.com/watch?v=uEnSkaroPqw"]FT86 JDL turbo with 3" Full Exhaust D2 - YouTube[/ame]
Another good one from John Red
[ame="https://www.youtube.com/watch?v=wbSP_Fh-cI0"]FT86 Diary #1 JDL AUTO DESIGN UEL HEADER - YouTube[/ame]
Old 10-24-2015, 07:23 AM   #39
smudge
I'm booked in to have a custom UEL manifold (2" primaries to a 3" collector in a 4-1 design) with a 3" overpipe and frontpipe on 9th November. Can't wait to have it all finished so I can get the map done!
Old 10-24-2015, 02:51 PM   #40
Chad86
Chad86's Avatar
Drives: Toyota GT86
I assume you are going this route to eliminate more bottleneck
The JDL UEL is:
1.75″ Primary Runners
Low Angle Merge Collector with 2.5″ Outlet
Old 10-24-2015, 02:57 PM   #41
Chad86
Chad86's Avatar
Drives: Toyota GT86
Question
Originally Posted by cjd View Post
I have a JDL over-frontpipe and D2 exhaust. Fit is great. Quality is their usual.
Only header I know that's 3" is Nameless.
I'd be surprised if a good 2.5" system is much of a bottleneck. I'm not really sure even today why I went 3" - even pondering a swap of the whole setup to get the car quieter.
C
So is it an issue running the full 3" JDL system, as their header is not a 3"
Old 10-24-2015, 04:19 PM   #42
smudge
The JDL UEL is:
Bigger bore just allows for more flow. Bigger the better
Raceseng Shock Tops Questions - 1" or 2" TrogDor the Burninator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-07-2014 10:12 AM
REQ: Looking for sound clip of Nameless 2.5" "No Muffler" Dual Exhaust Axleback jbsali Engine, Exhaust, Transmission 1 01-28-2014 07:22 AM
FS: j2 quad tip exhaust 2.75" NEED THIS GONE "price updated" FRSex Engine, Exhaust, Bolt-Ons 23 07-28-2013 10:07 AM
How many miles do you have on your "Turbo Kit" + Other's poll questions... NickFRS Forced Induction 40 05-10-2013 01:55 PM
How many miles do you have on your "Turbo Kit" + Other's poll questions NickFRS Forced Induction 0 05-01-2013 07:22 PM
