go_a_way1
Old 10-16-2015, 01:15 PM   #925
RWDfun
RWDfun's Avatar
Drives: 2015 Asphalt FR-S
I found where I saw that set up. Watch [ame="https://www.youtube.com/watch?v=bz0NAGQpGKU&list=PL9bOASiij5XzqwU3XhllrxSu TWniZWOW-&index=28"]this movie[/ame] since 7 minute.
These guys actually have gotten this idea and blueprints for this setup from Yoichi Imamura.
RWDfun is offline   Reply With Quote
Old 10-16-2015, 02:11 PM   #926
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Originally Posted by RWDfun View Post
I found where I saw that set up. Watch since 7 minute.
That car also has an engine swap, widebody kit, gutted interior, and who knows what else. @philstar was looking for something a bit more amateur-grade. I imagine transplanting a power steering rack would be very expensive and invasive, requiring you to move a lot of stuff out of the way to make room. Of course anything is possible with enough $$.
Mind if I ask why you want to swap it out? I have no complaints with the electronic steering.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
Old 10-16-2015, 05:14 PM   #927
RWDfun
RWDfun's Avatar
The complain is steering feedback and ability to move steering wheel while transition (with hydraulic power steering system front wheels change directions and rotate steering wheel if you leave it of course) with electric system (our case) we have electric motor and this motor doesn't allow to rotate steering wheel w/o hands.
Old 10-22-2015, 04:44 PM   #928
philstar
philstar's Avatar
Drives: Argento FR-S
That makes sense, I knew it had to do with our rack being electronic but didn't know much more. But yes, steering feels pretty dead and i don't feel connected to the car especially on transfers compared to when I drive other cars. I manage but its definitely something I want to look into in the future.
philstar is offline   Reply With Quote
Old 10-22-2015, 07:22 PM   #929
Chillemall
Drives: Raven FRS
I have struggled with the above problem a bit too. At Grissom AFB (which is super fun and I hope Drift Indy gets some days there next season too) The second transition felt like i was just along for the ride. No matter what i did steering wise, the car just had its own idea of what it wanted to do.
The only thing that seemed to give me any more control was grabbing some hand brake until it felt like the car was settling in. Then dump clutch in 3rd and continue with the rest of the course.
if you think it's bad drifting.. try having the car get all wonky when your dong 90-100 on Gingerman's back portion, in the wet. I still have mud and grassed caked into places only a power washer will get out.
Chillemall is offline   Reply With Quote
The Following User Says Thank You to Chillemall For This Useful Post:
Skidrcn (10-27-2015)
Old 10-23-2015, 02:21 AM   #930
RWDfun
RWDfun's Avatar
Need help with choosing correct spacers for stock wheels.
Recently bought Megan Racing Rack Ends Inner Tie Rods, think about 20mm or 25mm. Don't want to move wheels too out of and use different sizes for Front/Rear.
Worry about 20mm, is that enough to prevent rubbing in max lock?
Size:  17.8 KB Name:  22222.JPG
Also what do you guys think about brands?
What REAL difference between eBay Hubcentric spacers made 6061 T6 Forged Aluminum for only $125 (4 spacers) and 2/3 times more expensive eibach, H&R or ICHIBA V2 etc.?
Thanks
Old 10-26-2015, 03:58 PM   #931
Shady195
Drives: '13 10 Series FRS #1203
Maybe it's because this is the first car ive properly drifted with, but I don't feel this way at all. I find the steering to be very responsive compared to some other cars i've messed around with. There may be a little less feedback or rather "fight" in the wheel than a hydraulic rack or even no power steering at all but the 2 other people i've let drive my car (one drifts an AE86, and the other a 240SX) both said my car feels extremely responsive and it makes them want to get one (both are also very good drivers)
Shady195 is offline   Reply With Quote
Old 10-27-2015, 07:51 PM   #932
Chillemall
Drives: Raven FRS
Attachment 123349 Attachment 123357
Thanks
I have these inner tie rods. I paired them with Whiteline's roll center correction ball joint, and bump steer corrected outer tie rods. I origionally ran a 17x9+35 wheel with 215/40/17's. it would rub at full lock when the suspension would compress. (i was also way too low)
I raised the car a bit, added 15mm spacer. (so now 17x9+20) Now I don't rub and prolly have a tad bit more angle.
hope this helps!
fatpwr (11-04-2015)
Old 10-27-2015, 08:36 PM   #933
RWDfun
RWDfun's Avatar
hope this helps!
Yes sir! Thanks for your answer.
That's exactly what I need
Also, what do you think will be with et25 (10mm spacers)?
Old 11-04-2015, 11:35 AM   #934
Shady195
So how many here have an Angle kit from PBM or Drift Knuckles?
I'm looking at getting an angle kit for next year. As of right now my FRS is still pretty much a daily driver, however that may change come the end of this winter.
However keeping in mind this may still need to be a compliant car on the road, im leaning more towards the drift knuckles setup right now. It's not a crazy amount of angle, but its plenty more than what we have stock and I'd imagine it would not be as noticeable on the street.
The PBM Kit has a crazy amount of angle, but I'm worried it would be garbage to try and drive on the street.
Just looking for those with experience with either kit and maybe even still DD their car.
A couple pics from my last event of the year. First time ever out with another car.
Old 11-05-2015, 07:42 PM   #935
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I'd just get the drift knuckles setup or just get tie rods. Either way, you'll be left with the same amount, since you're limited by other aspects of the suspension. MAX is cool, but expensive, and it's overkill for stock power levels anyways. You won't even really be able to keep up the wheel speed to utilize the kit at higher speed. You'd really just have the benefit of extra lock if you screw up.
I say tie rods. $80. Buy two sets, just in case you ever snap one at an event. Gives plenty of angle for lower power levels.
PSM and even Wisefab can easily be driven on the street.
Old 11-05-2015, 10:14 PM   #936
Shady195
Appreciate the response dude.
While I was just going to go with tie rods. I feel like i will still be craving a bit more from it. The knuckles seem to give quite a good ammount of angle. A bit more than an S13 but not crazy like a PSM/Wisefab.
After riding/driving and tandeming with S13/S14's its clear that the FRS lacks from the great angle they do right off the batt
Old 11-28-2015, 02:57 PM   #937
2014scionfrs
2014scionfrs's Avatar
Drives: 2014 Scion FR-S
link not working?
Originally Posted by diss7 View Post
Have made the group into a public page so a lot of the people who just want to follow others can do so.
This can be found here - https://m.facebook.com/Gt86driftclub
There is still a closed group for private chat among actual drifters. If you want to apply to join that, you'll have to PM me.
link not working? is it closed?
2014scionfrs is offline   Reply With Quote
Old 11-28-2015, 03:58 PM   #938
2014scionfrs
I read on the 1st page it says that tire pressure should be under 40psi hot. 33-35psi cold
ive been running 30 in the front and 50 in the rear for 2 seasons now with great response! any opinions on this?
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
