Old 03-25-2015, 08:44 PM   #71
Dimman
Kuruma Otaku
Dimman's Avatar
Dude, I'd do it if I could find a cheap enough roller. Full JGTC Speed is what dreams are made of.
And no actually, I'm here because the topic is awesome, but I'm keeping a keen eye on a number of y'all too haha. Keep it civil and it's all good!
Now back to 3S stuff!
When looking for the weight I saw a rough spec list of that NA motor. Guy is in Melbourne, but I can't find active posts by him since ~2012. Goes by Celica RA45.
Pulled from another forum:
new beams head with quads of 50mm and 2 stage etc new cams which are 14.65mm of lift and 263 duration at 50 thou 1.5 teeth of vvti .std beams cams have 3 teeth of cam pulleys of movement
new exhaust 13.8 mm of lift 259 duration at 50 thou 1.5 teeth of vvti
redesigned head changed port .valves and new different quad throttles ,end result picked up power from 4000 right through to 9000
also torque has increased as well ,torque now starts to drop off after 8000 earlier head torque had dropped from 7000
Some translation and details from other posts: 50mm ITBs, 2 stage fuel injection with 400cc standard port injector and 1000cc 'showerhead' injector on the outside of the throttle butterflies. This concept is from bikes and its purpose is very similar to the D4-S. A simpler, less Eco friendly version. Motec ecu. 14.5:1 CR. Power to 9200rpm. I've seen claims of over 200kW to the wheels and 340 crank HP. I think on E85.
Wild.
Because titanium.
Old 03-25-2015, 08:47 PM   #72
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
That sounds absolutely glorious.
- The Ancient BRZ Sacrament
by Zaku
Old 03-25-2015, 11:13 PM   #73
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by Jaden View Post
Any engine with a newly designed head, VVT and direct injection can be made to pass modern smog requirements.
Jaden
So you're saying, change the pistons and head. That's most of the engine, and the majority of the R&D (combustion chamber, ports, valvetrain), why not just make a new shortblock too so you can use the engine for another 10 years?
@Dimman holy smokes, 14.5 CR and E85? That sounds like a beast. 340hp crank is a lot even for 9200rpm, I would have guessed around 300hp with E85. Maybe the 3S combustion chamber responds really well to those high comp pistons. But it begs the question, why not do that to a K20? You don't need a Motec, the stock ECU will be just fine with Hondata.
Old 03-26-2015, 12:12 AM   #74
Dimman
Kuruma Otaku
Dimman's Avatar
He is running 8 injectors in a sort of DIY D4-S. Maximize combustion quality.
The reason for the BEAMS was for swapping it into an old RWD Celica or Corolla from the sounds of it. Plus it's in Aus and there seems to be some patriotic duty for them to use domestically developed standalones in their projects. Maybe they're cheaper there?*
I've been looking for more info on the numbers but most is old and archived stuff. Guy's name is apparently Glen Booth and I've found references to him making swap parts to put BEAMS into AE86 Corollas, but not much activity past 2012.
* Note grammatically correct their/there/they're usage in close proximity. Do I get some kind of internet award for that?
Heh...
Because titanium.
Old 03-26-2015, 05:37 AM   #75
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Some parts are cheaper on this side of the world, some are more expensive. Most guys here prefer to run standalones. They're just better for so many reasons. Especially for conversions.
My Link G4 in the ae86 cost me $1800NZD
My Motec in the gt86 cost me $3200NZD
My TRD 2way diff cost me $750NZD
My work meister wheels I got for $2400NZD
Anything made in Aus, NZ, or Japan, we get cheaper than the states. But anything you want from the states, you get raped in the ass, with conversion, shipping, import duty.
I just bought a perrin 3" rear muffler. Just the muffler. Cost $1800NZD by time it got to me.
My part shop max angle kit, it hasn't arrived yet, but it will be close to $3k NZD by time it lands.
So positives and negatives.
Anyway, beams stuff..
Here's a vid of my ae86 when the beams was first put in. Internally it was stock. Just had ITB's and a tune and it made 200whp.
[ame="https://www.youtube.com/watch?v=__fWrW7_mDU"]AE86 3sge Beams @ Ruapuna Christchurch NZ 21/12/12 - YouTube[/ame]
Glenn is definitely still active on forums and such. I've seen him post only a few weeks ago on oldschool.co.nz
Manji is offline   Reply With Quote
Old 07-25-2015, 02:06 PM   #76
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by Dustin@Dynosty View Post
Was going to post up some details once its finished being turbo'd, has been running around NA for a while now, all my pictures are on my work cpu, but feel free to check me out on instagram: dustinatdynosty #FR3S #dustinsnewproject
We will be selling swap kits once we have everything finalized.
Whatever came of this?
Old 07-25-2015, 02:53 PM   #77
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Seconded. So many completed swaps... So few kits.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 10-22-2015, 02:51 PM   #78
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I'm interested since this is my favorite motor essentially and would like to know what it's up to!
JazzleSAURUS is offline   Reply With Quote
Old 10-23-2015, 09:51 PM   #79
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
This is how the frs should've came.
hmong337 is offline   Reply With Quote
Old 10-25-2015, 07:47 AM   #80
dcfis
Drives: nono
Originally Posted by geezer86 View Post
Yeah I know the 3S is old timey but the 4th Gen is fairly advanced.
I doubt the COG would move up all that much, I think I could live with it.
It looks like it fits under the hood in the Dynosity swap as does the larger trans.
Being a 4AG fan I was watching the development of the 86 with baited breath.
And then they pull the rug out. A wha? A Subaru? A truly WTF moment for AE86 fans.
So now there's a F'n Subaru in the driveway where there should be a GT86 not a Scion.
But I digress, I suppose I'll just have to get the new Lexus and spare myself the swap abuse. But I am a repeat swap offender and will likely find myself back in swap prison by next fall.
Some pics of my 4AG AE86 drive train MGB GT I also Have a Porsche VW/914 with 4AG power.
What new Lexus is that?
dcfis is offline   Reply With Quote
Old 10-26-2015, 09:17 AM   #81
JazzleSAURUS
I think it would of been cool to offer a 3S in the Toyota, and an FA in the Subaru so you could pick which was more relevant to the heritage, but I'm also an EJ fan....for some reason.
Old 10-26-2015, 09:26 AM   #82
CxG
Drives: Pearl White '13 ZN6
Any word on swap kits for this just yet? From what I've gathered the FA20, 3SGE, 1UZFE, and LSx engines all weigh about the same. With the LSx being the only one that current has a complete swap kit available. I'm displeased that it's this hard for a Toyota purist to not commit sacrilege while trying to go for a cost effective, straightforward swap on a daily driven car. That and the fact that you can get some serious power out these babies with some boost just nakes me want this swap kit to exist even more.
Anybody know a good 6SPD that'll bolt up to the beams engine or would an R154 with a rear differential swap out if the IS300 be more drivable?
Anybody think of going with a 2ZZ and stroker kit keeping it all engine?
Sent from my D5803 using Tapatalk
CxG is offline   Reply With Quote
Old 10-26-2015, 03:47 PM   #83
CxG
It hasn't been too bad thus far, since it was/is not a popular motor state side there is very little aftermarket support but after I am done, we will have a source for just about everything you need to build them NA or Turbo. Yes the HKS timing belt took a while to get in but other than that everything else has been under 2 weeks. And I doubt anyone is swapping this motor or any other motor on a daily driver, this is my toy car so if it has to sit a while for this reason or another, no big deal.
I'd like to do this swap to a daily driver lol that's why I'll wait for that kit
Old 10-26-2015, 04:08 PM   #84
CxG
High beams DjDATZ Cosmetic Modification (Interior/Exterior/Lighting) 8 09-10-2014 07:49 PM
3000k HID low beams WolfsFang Cosmetic Modification (Interior/Exterior/Lighting) 26 08-21-2013 09:41 PM
24 Watt LED DRL/Hi beams! Ironsquid Cosmetic Modification (Interior/Exterior/Lighting) 23 05-20-2013 02:45 PM
High Beams DC-FRS Cosmetic Modification (Interior/Exterior/Lighting) 13 01-12-2013 10:44 PM
High beams?!?! gmanculb Cosmetic Modification (Interior/Exterior/Lighting) 12 10-02-2012 04:51 PM
