Old 10-14-2015, 12:18 PM   #561
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Great #s Joe and Mike! Would you happen to have a graph with RPM instead of speed?
JDLAutoDesign is offline   Reply With Quote
The Following User Says Thank You to JDLAutoDesign For This Useful Post:
xxscaxx (10-14-2015)
Old 10-15-2015, 11:47 AM   #562
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Because the signal cut out it wouldn't be complete. For reference it spools fully by 4000 rpm, with the redline at 7400.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
xxscaxx (10-16-2015)
Old 10-17-2015, 12:08 AM   #563
Shit Luck
Drives: red frs
Ok so I am still struggling with my car...
It's the original kit with a Flash and Go tune... it stumbles and dies when I push the clutch in. At idle it's pulling 16-18in/hg of vacuum, all lines are clamped. I was told by delicious my Crawford aos could be the problem so I took it off and nothing changed.
I upgraded the bov spring like delicious recommends too.
The car is embarrassing to drive at this point and I am out of ideas.
Shit Luck is offline   Reply With Quote
Old 10-17-2015, 03:45 AM   #564
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
My car had an issue when it would die when I took it out of gear(Stopping at a stop sign), It ended up being a problem with the BOV spring being to weak so we swapped that out and it fixed that issue.
R2RO is offline   Reply With Quote
Old 10-17-2015, 01:51 PM   #565
Shit Luck
Drives: red frs
Already running the heavy spring...
Old 10-17-2015, 10:23 PM   #566
Shit Luck
Drives: red frs
I just put an 1/8 inch shim in the bov with the 12 psi spring and now it's not stalling....
I am sure this is horrible for the turbo though.
Old 10-19-2015, 01:43 PM   #567
xxscaxx
Drives: 2013 SWP BRZ
@Shit Luck what tune are you running from Delicious, is it the hybrid tune or the full speed density one?
xxscaxx is offline   Reply With Quote
Old 10-19-2015, 05:43 PM   #568
Shit Luck
Drives: red frs
It's the flash and go....
I am pretty much dome with those guys. They can't fix it or won't admit the tune is the issue. They are a joke.
Old 10-19-2015, 05:46 PM   #569
xxscaxx
Yes I know it's flash and go but they have two versions, a full speed density tune and a hybrid. I'd reach out and ask, if you are on the speed density only switching over to the hybrid will more than likely cure your stall issue.
Old 10-19-2015, 08:51 PM   #570
Shit Luck
Drives: red frs
Originally Posted by blueap2 View Post
@Shit Luck
I am running their Flash and Go tune and don't have any issues. Is it possible this is an install related issue?
Mine fired up and drove like a champ from the beginning.. Haven't even uploaded the latest revision of the tune..
It's been a year and I finally got the updated file... they have continued to blame random parts and ask for logs..
Everytime I do get a response from them the "log shows no issues"
Even when I data log the stall .
Old 10-20-2015, 01:32 PM   #571
JDLAutoDesign
Drives: 13 FRS
We have 3 local cars running F&G tunes and running 8psi BOV springs. Have you pressure tested the car for vacuum leaks?
Old 10-20-2015, 03:25 PM   #572
Shit Luck
Drives: red frs
I have spent all summer looking for leaks there are none. I even took off my aos because when I got my updated tune they said that was the issue. Runs the same no matter what.
I am not the only one having this issue. There have been many others with this issue as I have received plenty of pms saying so. Everyone has gone to another tuner and the problems went away.
Unfortunately I can't do that till spring due to a job loss issue.
Old 10-20-2015, 04:27 PM   #573
JDLAutoDesign
Drives: 13 FRS
I dont remember if you got the updated MAF pipe without the BOV. If not we can send you a new MAF pipe and BOV flange to have it moved to the IC. The softer spring works better with it moved to the IC
Old 10-20-2015, 05:13 PM   #574
Shit Luck
Drives: red frs
I am on the original stuff...
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
