Old 10-16-2015, 05:51 PM   #3067
CSG Mike
CSG Mike's Avatar
Edit: @CSGMike AD08R is an 'easier' tire to drive than RS3? I assume the RS3 has a bit more durability to it which explains why you prefer it?
It's a peakier tire; the window of opportunity for good laps in a session is smaller. Additionally, the AD08R heat cycles less dramatically than the RS3. The RS3 drops off pretty hard as you use it.
CSG Mike is online now   Reply With Quote
Old 10-16-2015, 06:03 PM   #3068
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Which tire is peakier?
ineedyourdiddly
Old 10-16-2015, 06:50 PM   #3069
CSG Mike
CSG Mike's Avatar
RS3
Old 10-18-2015, 07:08 PM   #3070
FRed-S
FRed-S's Avatar
Drives: 2015 Scion FR-S
SCCA class for FR-S
Hi, I'm new to this stuff and I'm registering to take an Autocross class but the application needs the SCCA Autocross Class for my vehicle and I don't know where she would be. The car is mostly stock. Just a full Aero Kit, ACUtek tune and drop in TRD air filter. Does anyone know what class my car fits into?
Thanks, and sorry if this has been gone over before.
FRed-S
FRed-S is offline   Reply With Quote
Old 10-22-2015, 06:00 PM   #3071
Campo
Campo's Avatar
Drives:
You get this figured out yet? There's a decent number of guys autocrossing here in Phoenix. Maybe check in the All Arizona thread.
Tapatalk - because smoke signals would be too easy.
"Fuck, you've gone completely sideways, man."
~Raoul Duke
Gas is pretty cheap considering you're buying liquid explosive dinosaurs.
Campo is offline   Reply With Quote
Old 10-22-2015, 11:39 PM   #3072
u/Josh
Drives: GBS Limited 6MT
Are the twins eligible for NASA TTE if I run skinnier than stock tires? I know the base class is TTD and you can get points back for running skinny tires, but is anyone doing this?
u/Josh is offline   Reply With Quote
Old 10-23-2015, 08:52 AM   #3073
OkieSnuffBox
Drives: '23 BRZ Limited
^Go readup on the NASA TT forums. Lots of info there.
Old 10-23-2015, 08:56 AM   #3074
cjd
cjd's Avatar
Drives: 2017 BRZ
Not sure this is the thread but tune means STX. Areo may be your undoing, very little is ever permitted (factory only in STX). It's probable locally no one will object, and you'll be slow for a while (especially without a proper alignment) so start there.
Old 10-23-2015, 10:32 AM   #3075
ka-t_240
SCCA classing is very picky with mods. Thinks you think are basic/not major can be huge for classing. Is there anything else done(wheels/tires/interior removal/exhaust with out cats/ect).
You are in at least STX. Post up what you mean by full aero kit as that will likely be the issue.
ka-t_240 is offline   Reply With Quote
Old 10-23-2015, 10:43 AM   #3076
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
There was discussion about this over in the C-Street autocross thread. He likely belongs in SM due to the aero kit (assuming it's not an RS model anyway) but nobody locally will care since the kit's weight will offset any marginal gain at autocross speeds. The tune though puts him in STX no matter what since that actually makes a very noticeable difference.
Old 10-23-2015, 12:20 PM   #3077
FRed-S
FRed-S's Avatar
Fraid not. Just what I stated. Stock everything else. Just Aero, Tune and TRD air filter.
Sent from my XT1254 using Tapatalk
FRed-S
Old 10-23-2015, 12:48 PM   #3078
ka-t_240
What is your "aero"
Old 10-23-2015, 03:21 PM   #3079
Campo
Campo's Avatar
Drives:
What is your "aero"
Yeah this. ^^^
The stock spoiler is considered "aero" in NASA TT because it's not on the base car.
~Raoul Duke
Old 10-24-2015, 07:54 PM   #3080
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Getting too hot for XP10s? This is after 4 30 minute sessions at Shenandoah Circuit at Summit Point. I can't compress my braking zones any, I'm already bumping ABS occasionally and trail braking as much as I can. Stock tires are definitely limiting me a bit in that regard. I'm not using the pedal dance (obviously, since I have ABS). I'll have to snap a pic of the pads sometime this week after I get home. I've got another 4 sessions tomorrow. The brakes feel great, tons of bite and zero fade, but they feel a bit "gritty" and there's some bits of what appears to be pad material smeared on the surface.
Sorry for the crappy pics, I thought my phone focused on the rotor, I guess not.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
