#29 | |
Drives: GTS 86
In all seriousness, you can ceramic coat this and be done with it! Why would a manufacturer try to do that and limit it self in terms of design (efficiency etc) just so can accommodate such an insignificant aspect of a header.
#30 |
Drives: 85.5 Porsche 944, '15 mustang GT PP
ceramic coating a header leads to less temperatures in the engine bay than the stock with heatshield. there is a thread on here somewhere that showed ceramic coated (uel I believe) vs stock header+heatshield, and the ceramic is a good bit cooler in the engine bay.
| The Following User Says Thank You to Chad11491 For This Useful Post: | Infinity (06-28-2016) |
#31 | |
Drives: FT86
catless headers tend to run a bit cooler due no cat restricting flow and holding heat |
#32 |
Drives: 2013 Black FR-S
yes
#33 |
Drives: '13 BRZ | '04 E55
I hear more valvetrain noise with the ACE versus the OFH, and the pitch has changed due to the UEL/EL.
| The Following User Says Thank You to NotSoJDM For This Useful Post: | solidONE (10-19-2015) |
#34 |
Drives: FR-S Whiteout
I was able to wring out 160-165ftlb of torque on E85 with this "other" header, but it's nowhere close to 150 at 3k. The power does not start to build up until 3500~3600, hitting 150 at 4000.
Is it the extra length of the secondaries that allow it to do this? Also, I've experimented with different size front pipes. Let me just say there is a very good reason why ACE headers went with a pregnant 3" FP.
Intent > Content
cowardice is the mother of cruelty. |
#35 | |
Mentat
Drives: 2013 Scion FRS 6MT
#36 |
#37 |
Drives: 13 BRZ, 18 STI
Can you elaborate? I've been wondering why they went with that design.
Racecar spelled backwards is racecaR, because RacecaR
#38 | |
Edit: Here you go @TorqueMan777 Stock FP vs 63mm FP vs 70mm FP ![]() It's not quite a 3" diameter, but I've no doubt the even larger pipe will have a similar result as I got with my 70mm pipe. and E85 vs 91 petrol while I'm at it
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 10-22-2015 at 04:10 PM. |
| The Following 2 Users Say Thank You to solidONE For This Useful Post: | 8686 (10-23-2015), Hostile_Kittens (07-10-2016) |
#39 | |
Drives: MR Spyder/GT86
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter |
#40 |
Drives: frs
I want to see it with E85
#41 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Teseo (07-07-2016) |
#42 |
Drives: 2016 GT86 N/A
ACE basic tune
| PLM Header Review | Cross | Engine, Exhaust, Transmission | 7 | 05-26-2016 05:46 PM |
| Driveway Labs Type II Diffuser (PRODUCT REVIEW) | Ammonia | User/Vendor/Sponsor Reviews, Feedback, Comments | 7 | 08-07-2015 04:49 PM |
| Tomei Type 80R Review | pnig | Engine, Exhaust, Transmission | 5 | 05-31-2015 11:15 AM |
| My BC Racing ER Type coilover review | Bodyrollin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 09-23-2013 05:15 AM |
