Old 10-09-2015, 04:49 PM   #1779
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Originally Posted by vroom4 View Post
Fourth place car at nationals this year is feals on custom spring rates.
Yeah, and that guy was a hack too!
jprice130 is offline   Reply With Quote
Old 10-09-2015, 06:02 PM   #1780
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Huh, never heard of Feal before, looks rather similar to Fortune Auto 500, also available with custom spring rates and matched dampers for a similar pricepoint ($1.2k-$1.6k)
ineedyourdiddly
Old 10-09-2015, 08:40 PM   #1781
Racecomp Engineering
Originally Posted by smg1138 View Post
It seems like KW V3's are a popular option, but the newer spring rates look way too soft.
They are soft, so you should check out RCE Tarmac 2s.
- Andy
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
Porcupint (10-09-2015), ScionOfHorus (10-26-2015), smg1138 (10-09-2015)
Old 10-10-2015, 07:23 AM   #1782
rx3
By how much would springs rates need to increased if an STX car was running on R-comp tires instead of street tires? Is there any rule of thumb?
(I know this is sort of OT).
rx3 is offline   Reply With Quote
Old 10-10-2015, 11:05 AM   #1783
AFRichZC6
AFRichZC6's Avatar
Not really a rule of thumb. They say suspension tuning is a dark art. I'm only in C Street, but I think this is how I'd go about it.
You'll want to know how much load is being placed on a particular corner of the car (through testing/trial & error with temperature probe), then do either one of two things to help maintain maximum contact patch (even wear and heat across tire): (1) Dial in more negative camber or caster or (2) increase spring (or sway bar) rate enough to prevent camber loss as the camber curve changes through compression. Those would be the big changes. Tire pressure goes without saying.
With increasing spring rate, you may work the tire too hard (you may lose too much mechanical grip). With more spring, you may want to adjust damping. With more bar, you may lose too much wheel independence. With increasing negative static camber, you may lose some braking/acceleration traction due to loss of contact patch (when you're not cornering). With increasing negative caster, you may lose some response in transitions or turn-in.
AFRichZC6 is offline   Reply With Quote
Old 10-11-2015, 07:28 PM   #1784
vroom4
And a ginger, that's good for at least -0.5s in the bad direction.
vroom4 is offline   Reply With Quote
Old 10-14-2015, 03:32 PM   #1785
ksconekiller
Drives: Subaru BRZ
STX car for sale here in the classifieds:
http://www.ft86club.com/forums/showthread.php?t=96220
ksconekiller is offline   Reply With Quote
Old 10-15-2015, 01:55 PM   #1786
renfield90
The Stig's German cousin
I skimmed about a third of this thread (seriously) but didn't see much in the way of setup advice. I've got a pretty good idea of what shocks/springs and power mods I want but what are most people doing for sway bars?
Are there any good STX build threads someone can point me to?
Old 10-15-2015, 02:19 PM   #1787
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
I would start by looking here: http://www.ft86club.com/forums/showthread.php?t=30303
It was started some time ago and it has some good information. You could find some build threads from it as well or at least people to look for.
Shneegle is offline   Reply With Quote
The Following User Says Thank You to Shneegle For This Useful Post:
renfield90 (10-16-2015)
Old 10-17-2015, 08:34 AM   #1788
48Spoons
Drives: Ultramarine FR-S
Sadly not much. I went through this last year when looking what to get for my STX build. Mostly looked at what spring rates and alignment settings people were using and then based my build off of that.
For a summary:
Spring rates seems to be around 400-500, I personally run 440 all around, which was what ground control suggested for autox.
Camber is -3.3-3.0 in the from and -2.0-1.7 in the rear. Toe seems to vary by driver preference. I'm at -3.1f/-1.9r and no toe.
Not really sure what people doing for bars though. I'm running the strano front with stock rear and the car feels great.
48Spoons is offline   Reply With Quote
The Following User Says Thank You to 48Spoons For This Useful Post:
renfield90 (10-18-2015)
Old 10-17-2015, 08:19 PM   #1789
RedBRZ80
Drives: 2013 Red BRZ
For a summary:
I think your right in the money. I'm 400 lbs square with -3F -2R no toe. Still DD as well. White line FB stock rear. / tried a rear bar but I don't like crazy loose.
RedBRZ80 is offline   Reply With Quote
Old 10-31-2015, 01:04 PM   #1790
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Those of you running SPC or Whiteline stamped rear LCA's...what are you getting for rear camber?
justinco is offline   Reply With Quote
Old 10-31-2015, 02:32 PM   #1791
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Whatever camber you want for STX really. I've been at -2 for months now
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
Old 10-31-2015, 05:19 PM   #1792
48Spoons
I have the SPC once, currently set to -1.9. might if i can get a little more next year.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
