#15 | |
Drives: WRB Limited BRZ
#16 |
Senior Misanthrope
#17 |
#18 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
#19 |
Senior Misanthrope
So as not to derail this thread too much:
I picked a UEL header because the rumble makes me happy. I'm not building a race car, so I don't care that EL headers produce more power in the high revs. OP, you should listen to video clips of various exhausts and see what sound you like best. |
#20 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | wparsons (10-16-2015) |
#21 | |
It's not EL vs UEL for where the power is made, it's 4-1 vs 4-2-1. A 4-2-1 header will have better midrange gains, while a 4-1 will have better top end gains. That all assumes it's probably designed, and not just cobbled together with no thought to runner diameter, steps and runner length. Personally I want no part of a header that is designed to give unequal backpressure, scavenging and heat to half the engine vs the other.
#22 | |
Mr.Fujitsubo
Drives: 2018 STI
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review ![]() |
#23 |
Not Bаnned Anymore
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Mr.Impreza (10-17-2015) |
#24 |
Drives: 2013 FR-S Argento
Honestly I'm not sure - it's a complicated thing, as a good tune for that specific header is important. Just look at the recent thread where the guy gutted the cat on his stock header and re-tuned. What makes a good header is way over my head - I just rely on aggregate dyno results of people who have tested various headers. The Tomei headers certainly look nice, maybe in the same league as the openflash headers, but I haven't seen any dyno results (with good custom tunes) to compare. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to bfrank1972 For This Useful Post: | Mr.Impreza (10-17-2015) |
#25 |
Drives: FT86
You got to look at your end game.
Pick a sound UEL - boxer rumble EL - normal 4 cylinder sound UEL - generally better gains in low/midrange, sacrifices a few hp top end EL - not so good low/midrange but few more HP top end Tomei, JDL, openflash Gruppe-s ect are your average priced headers and plenty of flash & go or canned tunes available from ecutek and OFT guys for these Then you have P-tuning and Nameless and ACE the higher priced headers ACE header is probably the pick of the bunch as it combines benefits power/torque) of the normal EL/UEL header (it an EL header so no boxer rumble though). The ACE produces good gains entire rpm range. Rub is its expensive and you will need a custom tune to get the max benefit as I dont think anyone is offering flash & go or canned tunes for ace header (or P-tuning or nameless) If your just street driving and staying NA then probably just get a UEL header and a flash and go or off the shelf tune from ecutek or OFT guys If you going turbo then most kits will require you to run a different exhaust manifold (header) to connect up to turbo, some can use original header but very few. supercharger kits you can use your original header. , nameless might be an issue for some kits due to its design. |
| The Following 4 Users Say Thank You to steve99 For This Useful Post: |
#26 | |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Both types will help increase power, but it's really the tune that makes the biggest difference. I wouldn't expect big gains with only an exhaust. Don't be fooled into thinking otherwise. Like some of the dudes say - consider future plans too... Turbo? Then don't do a header now. SC, then sure. NA, then sure. Have fun and post pics of what you do in the end?! |
#27 |
Drives: 2014 GT86
Nameless .. if you think of Cossworth's as Nameless (there are some changes though), then it has canned Cossworth's tune.
#28 | |
Mr.Fujitsubo
Drives: 2018 STI
| Gaskets & Headers question | Bach415 | Engine, Exhaust, Transmission | 16 | 06-30-2015 05:27 PM |
| Question about the Fa20club UEL headers | Chuck. | Engine, Exhaust, Transmission | 7 | 04-22-2014 08:30 AM |
| Turbo Question regarding Headers | Admired | Forced Induction | 13 | 10-16-2013 08:27 AM |
| Question about the design of Borla EL Headers... | Kiske | Engine, Exhaust, Transmission | 4 | 07-26-2013 11:54 AM |
| question for guys with headers | Xdragonxb0i | Engine, Exhaust, Transmission | 22 | 04-22-2013 12:49 PM |
