Old 10-15-2015, 11:57 AM   #1
GT86NZID
GT86NZID's Avatar
Drives: GT86 '14, F10 '15 & AMG GTS '16
Will AMG brake calipers fit on our cars?
Will it fit?
Someone is selling a set of AMG calipers that came out of his 2013 SLS.
Looking to get them bcs its on a good deal and will get a separate new bigger rotors with 5x100 hubs.
GT86NZID is offline   Reply With Quote
Old 10-15-2015, 12:15 PM   #2
jadewbj
jadewbj's Avatar
Short Answer is NO. Long answer is yes anything is possible with money and fabrication talent. I had EVO calipers installed on my car with a set of STI rotors. This took some real work and the calipers are basically the same as an STI caliper which bolt right up.
Not sure the savings you are getting on the calipers would be worth it unless you are an amazing fabricator.
http://jademotorsports.com/stop-like-right-now/
jadewbj is offline   Reply With Quote
Old 10-15-2015, 01:41 PM   #3
vividracing
vividracing's Avatar
^I'd second this. It would probably take more fabrication than it's worth. Especially when you consider that there are big brake kits out there that are designed specifically for the FRS/BRZ platform.
vividracing is offline   Reply With Quote
Old 10-15-2015, 01:47 PM   #4
8R6
8R6's Avatar
Drives: FRS
how much exactly is this "good deal" we're talking about for this? chances are, you can probably get a set of brand new bbk set up for a similar price and that have been tested and proven to be effective for our cars. i dont get this whole caliper swapping thing that's been going on.
it's a total show mod that actually increases possible danger to the driver, car, AND OTHERS on the road.
8R6 is offline   Reply With Quote
Old 10-15-2015, 01:52 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
know how to fabricate a bracket and reproportion brake valving and bias?
If yes, you can buy it.
If not, you should not.
SkAsphalt (10-16-2015)
Old 10-15-2015, 04:51 PM   #6
Rafi@RR-racing
Rafi@RR-racing's Avatar
Drives: Toyota GT86
Originally Posted by GT86NZID View Post
Will it fit?
The answer is absolutely NO. They have huge caliper pistons in order to stop a 4000lb car. Even if you fabricate custom rotors and adapter brackets, you would also have to change the master cylinder. With the increased piston area volume your ABS would not work properly either.
Rafi
Rafi@RR-racing is offline   Reply With Quote
The Following User Says Thank You to Rafi@RR-racing For This Useful Post:
Painted brake calipers meeskee2 Cosmetic Modification (Interior/Exterior/Lighting) 20 04-15-2014 06:19 AM
Painted Brake Calipers woode Cosmetic Modification (Interior/Exterior/Lighting) 20 12-23-2013 12:58 AM
Painted Brake Calipers Roborat Cosmetic Modification (Interior/Exterior/Lighting) 67 12-01-2013 05:51 AM
Painting the Brake Calipers Wasta Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-26-2013 09:12 AM
86 brake calipers Hardrock4445 Cosmetic Modification (Interior/Exterior/Lighting) 19 03-17-2013 10:04 PM
