Old 10-14-2015, 12:51 PM   #71
Originally Posted by pantdino View Post
Legally the repair facility has to give a dollar amount estimate and call the owner if the repair will exceed that amount. If it wasn't in CA or the owner trusted the shop and paid that's another matter.
That is for the repair. Does it apply to diagnostic work as well? Pretty hard to estimate how long it will take to figure out what is wrong.
Old 10-14-2015, 01:02 PM   #72
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
If they worked solid for 2 days then yes.
There are guys on here that have been slapped with that bill. If I remember right one was in California.
tcoat remembers all....
BlueSky is offline   Reply With Quote
Old 10-14-2015, 01:09 PM   #73
Not all. If I could remember the dude's name I would have posted the thread since he got taken to the cleaners with a blown engine. The other one I know paid huge for a diagnostic tear down had the thread pulled because he was headed down the legal road.
Old 10-14-2015, 01:20 PM   #74
BlueSky
BlueSky's Avatar
tcoat doesn't remember all....
all joking aside
I hope @kmac_brz gets everything sorted out
Thanks for keeping us updated, this keeps me busy at work
Old 10-19-2015, 12:16 AM   #75
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
Ok so if adding some pissy LED's can fry the BCM (Whatever that stands for!) then what areas of the wiring are safe to dabble with. I added some gauges and tapped in to an unused fuse in the fuse block under the dash to power them. Does that put me at risk of frying my BCM at some stage? What about the Tach wire I've tapped in to run a shift point indicator? Is this just related to the fitting/changing of LED lights? The bill for the OP could realistically add up to thousands!!
Bodalenko is offline   Reply With Quote
Old 10-19-2015, 04:52 PM   #76
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
I wonder how the Body ECU can cause this when the steering lock actuator is not connected to it.
Scenic Driver is offline   Reply With Quote
Old 10-19-2015, 05:00 PM   #77
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
The transponder key system is.
jawn is offline   Reply With Quote
Old 10-19-2015, 11:15 PM   #78
pantdino
Drives: Firestorm 2013 FR-S
Yes, it would apply to diagnostic work as well.
Other than electrical diagnosis, where you're just checking where current is or isn't and what relays work, diagnosis usually involves removing and disassembling things.
So the shop would have to call the owner and tell him to continue the diagnostic steps they will have to remove the head, timing chain cover, or whatever and quote the owner a price for that.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 10-19-2015, 11:16 PM   #79
pantdino
So base level cars can't have this problem?
Old 10-19-2015, 11:17 PM   #80
jawn
jawn's Avatar
Every key is a transponder key.
Old 11-17-2015, 12:16 PM   #81
kmac_brz
Drives: 14 WRB BRZ
Sorry it took so long to respond, I finally received the car back last week. New BCM/BIU and had to have the steering lock replaced l, I was told it was stripped due to me "banging the wheel off the locks"
kmac_brz is offline   Reply With Quote
Old 11-17-2015, 02:33 PM   #82
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Because the Certification ECU needs a CAN signal from the BCM.
But on the cars with an actual key, the steering lock is actuated by a mechanical linkage. You will be able to unlock the wheel. Not able to do much else, but...
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 12:15 AM
Steering wheel locked no start kmac_brz Issues | Warranty | Recalls / TSB 1 07-08-2015 10:35 PM
scion frs steering wheel air bag and steering wheel Jhon19lopez Interior Parts (Incl. Lighting) 7 01-04-2014 06:04 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
Steering wheel shaking after dealer visit today stratodyne Issues | Warranty | Recalls / TSB 19 08-09-2013 09:51 PM
