Old 10-14-2015, 12:34 AM   #6595
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question Header and Exhaust
Going with the following header and exhaust setup:
JDL catless UEL
JDL 2.5" overpipe
JDL 2.5" catted/resonated frontpipe
ARK DT-S
Would there be any benefit to going with a 3" overpipe and frontpipe?
Chad86 is offline   Reply With Quote
Old 10-14-2015, 03:06 AM   #6596
smudge
Drives: Supercharged GT86
JDL catless UEL
JDL 2.5" overpipe
ARK DT-S
For the 210? No not really
Bigger exhaust will always allow better flow but you won't notice anything on the 210
The 335 is a bit different hence why I'm looking at 3" exhaust options
smudge is offline   Reply With Quote
Old 10-14-2015, 03:08 AM   #6597
smudge
Originally Posted by stockysnail View Post
The plastic intake pipe for the 335 is the same as the 210 so it would be the same, or at least I was told it was the same.
Not sure who told you that but it's wrong. 335 pipe is different towards the charger as the elbow sits further back in the engine bay due to the larger design of the charger
Moto East makes a 3" intake, Perrin makes one too. Slapping a Toyota Tundra throttle body would be interesting to see if someone's willing since it has the same pins on the plug. Just need to take the time to get it to work.
Not on about 3" intakes. I'm on about 3" exhausts
Old 10-14-2015, 12:21 PM   #6598
Iamwu
Drives: 86
I had a belt snap on me recently and thought it was due my belt not being swapped to the shorter length that is recommended when upgrading pulleys. I ordered the gates K061010HD per recommendation here and was unableto fit it. I had friend hold the tensioner down with a breaker bar, and evenwith both hands stretching the belt, I could not get it over the pulley.
I have a 69mm pulley with a 70mm idler. Even if I wasable to somehow stretch the belt over, it just feels as though the tension would allow for no play whatsoever.
I just re installed a spare k061015 I had laying around,and it does feel like the belt is a bit looser than what would be ideal. Any thoughts?
Two thoughts I had:
1) Use K061015, 69mm pulley, but swap idler pulley to75mm.
2) Find a belt length that is sized between the K061015and K061010
Iamwu is offline   Reply With Quote
Old 10-14-2015, 01:17 PM   #6599
Chad86
Chad86's Avatar
Drives: Toyota GT86
I will be running my 335 with a 2.5` exhaust but was asking to know if there would be benefit or if it is just a waste due to bottleneck ING. Everything I've read has stated 2.5*is all that is necessary for a Supercharger unless going for really high output otherwise the engine will actually degrade in perfect with 3'
3' is mainly for turbo applications
Old 10-14-2015, 01:21 PM   #6600
smudge
I had a 2.5" system which got damaged just after the install of my 335 so I thought I might as well upgrade seeing as I need to replace half the system
The Following User Says Thank You to smudge For This Useful Post:
Chad86 (10-15-2015)
Old 10-14-2015, 01:52 PM   #6601
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Hi All,
We're pleased to announce our latest and final update to our Innovate/Sprintex tunes for the 210 blowers, version 9.0.
This version builds on 8.83 and offers the following improvements:
Increased top end power.
Closed loop fuel correction at WOT conditions, taken from our Flash & Go tunes.
This will be the last update we offer for the Innovate kits. As we've done in the past with our 8.65 and 8.83 releases, updates to 9.0 will be a $65 service fee for existing customers.
If you're interested in receiving this update, please email me directly at sales@delicioustuning.com.com
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
sato (10-14-2015)
Old 10-14-2015, 03:28 PM   #6602
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
Originally Posted by sales@delicioustuning.com View Post
Hi All,
Sincerely,
Zach
I'm interested in hearing more about the latest tune, what type of power increase at the top end are you expecting?
Also, why is this the final tune for you guys? I've had good luck with you guys and would like to know why you're pulling support for this SC.
PM sent
CarzCarzCarz is offline   Reply With Quote
The Following User Says Thank You to CarzCarzCarz For This Useful Post:
sato (10-14-2015)
Old 10-14-2015, 03:32 PM   #6603
DeliciousTuning
PM sent
Over 8.83, about 5-7whp more on top. Over 8.65, a bit more than 10whp gained up top.
We're very happy with where the tune is at this point. Coupled with our shop car removing its Innovate kit in preparation for something a bit more exciting, we decided it was a good stopping point that we were more than satisfied with.
Also, pm responded.
Sincerely,
Zach
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
CarzCarzCarz (10-14-2015), Dream20b (10-14-2015), sato (10-14-2015)
Old 10-15-2015, 01:15 AM   #6604
Chad86
Chad86's Avatar
Drives: Toyota GT86
Question
If I end up going 3" overpipe/frontpipe, will the 2.5" exhaust and midpipe just quiet things down a bit, especially being the ARK with additional resonators? Or will I want to go with something like the Perrin 3" to finish? I'm okay with fairly loud, just not WAILING loud.
Old 10-15-2015, 02:42 AM   #6605
smudge
No point in having half a system with 3" and the other half 2.5"
I'm opting for a resonated catback and resonated front pipe to keep things quiet-ish
Chad86 (10-15-2015)
Old 10-15-2015, 01:08 PM   #6606
Chad86
Chad86's Avatar
Drives: Toyota GT86
[QUOTE=smudge;242054like point in having half a system with 3" and the other half 2.5"
I'm opting for a resonated catback and resonated front pipe to keep things quiet-ish[/QUOTE]
Makes sense. Looks like I will take the same route. Doesn't seem to be too many 3 inch exhaust options. I'm looking at Perrin and Nameless now. How do you like the Perrin?
Old 10-15-2015, 01:12 PM   #6607
smudge
Nameless haven't got back to me about any of my enquiries over the last few days. Won't be purchasing any of their products then!
I don't have a Perrin...
Old 10-15-2015, 09:17 PM   #6608
DeliciousTuning
Also, pm responded.
Sincerely,
Zach
With the following parts you can be well above the 300whp mark (315-320whp) on a DynoJet Dyno.
Airaid Cold Air Intake (or at minimum a panel filter)
Delicious Tuning Flex Fuel Kit (on E85)
Delicious Tuning 69mm Pulley
Delicious Tuning 9.00 Tune
Header Back Exhaust System
We have a write up in D Sport Magazine (November 2014) on a slightly older tune, but with the new tune you can expect a bit more.
Cheers,
William Knose
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
