Old 10-12-2015, 11:21 PM   #6581
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
We don't really have a break-in period on our blowers or systems. We run our units on a proper test bench before they ever leave the production facility. They are run in at speed up to operating temperature. They then pass muster or else they don't leave the facility.
If anything, the computers need time to relearn. That should restrain a greedy foot. Modern ECUs are rather paranoid and can store up to 50 drive cycles instead of 3-5 like years past. Some of you have probably noticed your car "waking up" a few miles down the road or the next day. An ECU reset can do wonders after mods. The computer gets a fresh outlook on life as opposed to a sudden change in expected measurements.
We do stick with the stock MAP sensor. Standalone ECUs let you do it your way or at least more intuitively. With reflashes, you have to do it "their way". They're just happier with the stock MAP sensor. We don't force you to change it or it would have been included in the system.
We use polymer materials in our systems for what we believe are very good reasons. One of those reasons is better temperature control. Our intake tube is also open enough to breathe well and thick enough to not collapse. The shape is simple and still a direct fit to the stock airbox. You do get more noise with a metal intake, which some folks do like. We take the quieter OEM-like approach.
Originally Posted by Chad86 View Post
Any specific brand better than others?
Also, I have been reading the forums and cannot find much information on upgrading the MAP sensor. Some say there is a boost limitation on the stock sensor and to upgrade, but this might be refering specifically to turbo, while others say stick with the stock sensor on supercharged applications specifically Sprintex. Lastly, I read a post the other day about there being a break in period for the Sprintex supercharger? This is the first I heard...
@SprintexUSA can you confirm?
I also have seen people using an aftermarket Aluminum Supercharger Suction Pipe. Are there any real benefits to using aluminum piping over the stock plastic tube?
Nameless had a pipe, but it is no longer in production. PREracing also makes one, but I am still waiting to confirm availability.
SprintexUSA is offline   Reply With Quote
The Following User Says Thank You to SprintexUSA For This Useful Post:
Chad86 (10-13-2015)
Old 10-12-2015, 11:54 PM   #6582
jwvand02
Drives: 2013 SWP BRZ Limited
Anyone notice a change in exhaust noise when you installed the SC? Mine has a poppy sound to it under load, almost like an exhaust leak but I can't find any evidence of one anywhere. I have an aftermarket UEL header, and stock exhaust, was thinking about maybe changing the over pipe to a catless one.
jwvand02 is offline   Reply With Quote
Old 10-13-2015, 12:03 AM   #6583
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Have you data logged your car since the install?
Sent from my XT1095 using Tapatalk
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 10-13-2015, 03:25 AM   #6584
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by smudge View Post
I believe the Nameless one was ceramic coated on the inside as well. When I enquired to if they still made one or if they ever did one for the 335 kit, I got no reply
Simply having the metal intake over the plastic would lead me to think it'd heat up quicker and push hotter air into the intake of the charger, making it less efficient
I have the Nameless pipe that they don't make anymore with double ceramic coating on the inside and outside. It feels a little hotter compared to the plastic one, so metal isn't recommended for the lowest heat levels as far as my non-scientific hand on the tube test goes. I like the metal tube regardless. Plus it has a meth injection bung on it if I ever go that route (unlikely).
Old 10-13-2015, 05:49 AM   #6585
smudge
Drives: Supercharged GT86
Shame they don't make them anymore, not that I've seen one at all for the 335
smudge is offline   Reply With Quote
Old 10-13-2015, 06:22 AM   #6586
tegunulgener
tegunulgener's Avatar
Drives: Dark Side
Cosworth? They do 3"
Sent from my HTC One M9 using Tapatalk
tegunulgener is offline   Reply With Quote
Old 10-13-2015, 07:50 AM   #6587
Kodename47
Kodename47's Avatar
Drives: UK GT86
He's on about the intake pipe.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-13-2015, 07:51 AM   #6588
tegunulgener
Drives: Dark Side
OK then he can get the exhaust and cut it :P
Old 10-13-2015, 07:52 AM   #6589
tegunulgener
Drives: Dark Side
I read some sort of catback somewhere that's why... Sorry
Old 10-13-2015, 10:01 AM   #6590
smudge
Slowly 3" catback now ordered but still researching on best manifold, overpipe and front pipe for the setup. Looks like custom may be the way forward
Nearly 1,000 miles done on the new engine and charger
There maybe? In reply to your question about how my progress is coming along?
Old 10-13-2015, 10:12 AM   #6591
tegunulgener
Drives: Dark Side
Yeah that's the one lol
Old 10-13-2015, 01:55 PM   #6592
jwvand02
Yes, had an issue with it running lean due to an intake leak, but once that was fixed no problems.
Old 10-13-2015, 10:27 PM   #6593
stockysnail
Just the tip
The plastic intake pipe for the 335 is the same as the 210 so it would be the same, or at least I was told it was the same.
Old 10-13-2015, 10:29 PM   #6594
stockysnail
Just the tip
Moto East makes a 3" intake, Perrin makes one too. Slapping a Toyota Tundra throttle body would be interesting to see if someone's willing since it has the same pins on the plug. Just need to take the time to get it to work.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
