#645 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
#646 |
Drives: JAWS
@Nigelr32 what is the MFG date on your door panel for your 2014? Curious as I have a '14 manufactured in 08/13, wonder if I have these changes or not.
#647 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | sato (10-13-2015) |
#648 |
Sideways and Smiling!
Drives: Scion FR-S
So is anyone posting to this thread running an element tuning built motor?
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
#649 |
#650 |
Drives: CBS brz limited
Element didn't build my motor but im running their "big valve head" package on my built motor
Sent from my SGH-T999 using Tapatalk |
| The Following 2 Users Say Thank You to BRZGM3 For This Useful Post: | chaoskaze (10-20-2015), Darryljr11 (10-14-2015) |
#651 | |
Drives: '14 GT86 project, '13 GT86 DD
My car was built 12/13 mate.
| The Following User Says Thank You to Nigelr32 For This Useful Post: | JB86'd (10-14-2015) |
#653 |
Drives: FR-S Whiteout
That's pretty smart.
Intent > Content
cowardice is the mother of cruelty. |
| The Following User Says Thank You to solidONE For This Useful Post: | sato (10-15-2015) |
#654 |
Drives: GT86
Does anyone know if it is safe to remove stock oil pressure switch? I need a place where to put analog oil temp sensor. I have extra oil pressure in galley plug. I also have Perrin oil cooler and I am not a fan of putting another oil plate.
So, is the stock oil pressure sender just for the dummy light or is it used by ECU to anything else? Can I remove it without consequences? I found some threads here where people removed it, but I just want to be sure. Thanks. |
#655 | |
Resident Gear Head
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
| The Following User Says Thank You to celek For This Useful Post: | GT86_PRAGUE (11-20-2015) |
#656 |
The FA20 has two switches on the oil gallery. either one measures temp and one measures pressure, or one is the light and one is pressure. The stock ECU definitely reads oil pressure, not sure about oil temperature.
#657 |
Drives: 2014 BRZ SCCA STU endurance car
I'm fairly certain it's the other way around. The switch right by the filter is for the light and then there's a temp sensor right next to it.
| The Following User Says Thank You to Gear_One_Performance For This Useful Post: | celek (11-20-2015) |
#658 |
Drives: 2015 BRZ
The stock pressure switch is to the left as you look at the block. All it does is switch on the dash light at around 2.5 psi. Does not go to the ECU. The sensor on the right is temperature, and it does go to the ECU.
| The Following User Says Thank You to LS1M For This Useful Post: | GT86_PRAGUE (11-22-2015) |
| FA20 Engine component photos | Crawford | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 89 | 02-22-2016 03:31 AM |
| FA20 Engine component photos | Crawford | Engine, Exhaust, Transmission | 46 | 01-26-2015 06:19 AM |
| Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. | FRSport.com | Engine, Exhaust, Bolt-Ons | 0 | 01-10-2014 01:33 PM |
| FA20 Le Mans Race Engine | SilverSkyline210 | Engine, Exhaust, Transmission | 11 | 11-18-2013 12:24 AM |
