#15 |
Drives: 2015 BRZ limited 6MT
Idk my exact speed when it happened. I was paying attention to the road more than the speedo. Regardless of how fast I was going i saw >8500 on the tach :/
#16 |
Boosted Member
Drives: 2013 Subaru BRZ
Option 1:
Pull the motor, pull the heads, inspect everything. Option 2: Do nothing. Not sure what you are looking for us to tell you? Whether the car seems fine or is acting up, the above are pretty much your only two options regardless. If it hit 8500rpm under minimal load, I wouldn't be too concerned about it personally. Only you know things like if you let the clutch all the way out, how fast you were actually going, etc.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
#17 |
HELP! accidental overev!
I'm pretty sure the clutch was out all the way for a sec or half a sec max. I was at 7400 when I accidentally down shifted into 3rd. Would a compression/leak down do anything for me as far has piston head damage and bent valves?
Man I'm paranoid as fuck Last edited by nfaj; 09-22-2014 at 09:30 AM. |
#18 |
Drives: 2014 BRZ MT (Sold); 2006 V70R
If everything feels fine, you're probably fine. Aside from the balance of the internals, the only issue I can see that prevents higher revs is stuff like valve float causing the piston to contact the valves. Not sure if this is even an issue on our cars or not.
In short, if everything seems fine, you're probably okay. Not much you can do to inspect without a LOT of work that's probably not worth is. ECU most likely already recorded the over-rev as well. Lastly, I suggest you learn pronated/neutral/supinated hand position shifting instead of "fake gated shifting." You'll be much less likely to miss a shift that way.
'14 BRZ LTD MT DGM
#19 |
@aznatama Thanks for the advice! Is there anyway to reset the Ecu to erase that over rev log? Disconnect battery maybe?
#20 | |
'14 BRZ LTD MT DGM
#21 |
Drives: 86
First post here
It happened to me two days ago on the track. It was my first trackday, second turn of the day. The main straight finishes almost exactly at the end of 4th gear. I'm very used to downshift to decelerate on street, and therefore I've downshifted to 3rd when I was barely starting to brake. Revvs jumped over 8.5k rpms. I've changed asap to neutral, but a good second passed before I've corrected.The car seems to be fine, I've babied it for 2 full laps, listening to sounds etc... Since the car was pulling fine I've pushed and I've attained my record lap just 5 minutes after the miss shift. It's however 2 nights that I can't sleep: I really love my car and I'm worried it will result in a major engine failure sooner or later. Video: https://vid.me/G2cJ |
#22 |
Drives: 2015 Scion FR-S
You would be that guy to post this. Is the cat driveable? Check the block.
#23 | |
Thanks
#24 | |
#25 |
Omg guys I put 87 octane fuel in my car! What should I do
| The Following User Says Thank You to raven1231 For This Useful Post: | drewbot (10-10-2015) |
#26 |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Give up on life, the car is totalled. You should just give it to me.
Sent from my Nexus 5 using Tapatalk |
| The Following 2 Users Say Thank You to Bobblehead For This Useful Post: | drewbot (10-10-2015), MisterSheep (10-13-2015) |
#27 | |
Drives: 2013 FR-S 6MT Whiteout
I've just seen too much asshattery on the interstates lately to have much pity. |
