Old 10-08-2015, 05:22 AM   #113
Rafi@RR-racing
Rafi@RR-racing's Avatar
Drives: Toyota GT86
Originally Posted by ck-GT86 View Post
Would it be okay to run the stage II up front with BP20's, and keep my rear brake setup of: Centric blanks with Carbotech XP8's?
Need to mention that I'm supercharged too.
@Rafi@RR-racing
.ck
Sorry I missed your question! Yes, if you are tracking the car, when keeping the stock rear brakes, we recommend going to a more aggressive pad in rear compared to front, based on our testing, that works well. We have Winmax W5's for stock rears in stock, and they will complement the BP20 fronts.
But in our experience, the best solution is to upgrade the rears IF the car is being tracked. BTW, in about 2-3 weeks, we will announce a new rear 4 piston kit. The new design allows us to offer front and rear 4 piston upgrade for about $1600, and allows for much more rear bias.
Rafi
-Rafi
Rafi@RR-racing is offline
The Following 2 Users Say Thank You to Rafi@RR-racing For This Useful Post:
ck-GT86 (10-08-2015), ravisraval (10-08-2015)
Old 10-08-2015, 10:25 AM   #114
Rookie84
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
Rafi
-Rafi
BP20 works well with racing pads in the rear stock brakes? I thought HP Plus or similar dual-purpose pads were the usual recommendation for stock rears to work with your BBK up front with BP 20 pads. Can you elaborate?
BTW, are there still no plans to release rear BBK with e-brake functionality for people that drift?
Rookie84 is offline
Old 10-08-2015, 11:04 AM   #115
Rafi@RR-racing
Drives: Toyota GT86
We tried the BP20 and BP30 fronts with W5's OEM rear pads, and it works well on the track, a bit noisy for the street. HP Plus works well street and track, but doesn't have as much heat capability as the W5's.
Yes, in about 3 weeks we have a new rear kit, it will retail for about $800, it will use STi rotors and Wilwood 4 piston calipers, with a significant rear bias shift compared to OEM or STi Brembos.
Rafi
MaximeT (10-08-2015), Rookie84 (10-08-2015)
Old 10-08-2015, 11:23 AM   #116
Rookie84
Rafi
Sounds nice! So the new rear kit retains stock e-brake functionality or not?
I think for my purposes (occasional HPDE and drift days participation), I can get away with upgrading the fronts only but if you plan on making rears with e-brake functionality retained so I can use them while drifting, I wouldn't mind upgrading the rears as well..
Rookie84 is offline
Old 10-08-2015, 11:46 AM   #117
Rafi@RR-racing
Drives: Toyota GT86
Yes, sorry for not making that clear. Because we are using STi rotors, the e-brake is fully functional for drifting. We don't recommend using STi rear brembo calipers because they screw up the bias on the 86 bigtime!
We are also coming out with a lower cost 4 piston front kit. The combined cost of our 4 piston fronts and 4 piston rears will be less than the ST40 kits.
Adding the additional rear bias with our new rear kit will improve braking more than using ANY crazy expensive front kit.
Rafi
The Following 3 Users Say Thank You to Rafi@RR-racing For This Useful Post:
DAEMANO (10-11-2015), MaximeT (10-08-2015), Rookie84 (10-08-2015)
Old 10-08-2015, 12:19 PM   #118
Rookie84
Rafi
Thanks for the clarification! I'll be looking forward to the release!
EDIT: 1 more question. Will your new rear BBK work with your current 6-piston stg. 1 or 2 fronts?
Rookie84 is offline
Old 10-11-2015, 08:54 AM   #119
Rafi@RR-racing
Drives: Toyota GT86
Yes, it will work with any of our front kits, and should even work well with our competitors front kits. The 86 seems to really benefit from more rear bias.
Rafi
The Following User Says Thank You to Rafi@RR-racing For This Useful Post:
Rookie84 (10-11-2015)
Old 10-11-2015, 04:35 PM   #120
jiaim
Drives: Enthusiast
eager to see the 4 + 4 solution !
jiaim is offline
Old 10-15-2015, 04:16 PM   #121
Rafi@RR-racing
Drives: Toyota GT86
Wishing our friends at Gear One Performance well... on October 24th, they will be competing in a 12 hour SCCA Enduro event at VIR with our Stage 4 fronts and Stage I rears.
The Following 4 Users Say Thank You to Rafi@RR-racing For This Useful Post:
Alan (10-22-2015), Blizzard (10-15-2015), DAEMANO (10-16-2015), Pat (10-15-2015)
Old 10-16-2015, 09:40 AM   #122
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Need to get these guys to do Spec86 Cup....
AZP Installs is offline
Old 10-16-2015, 10:07 PM   #123
ravisraval
Drives: 2013 FRS
Just got the stage 1 kit from Neal@The Racer's Line.
With a 5 mm spacer it clears RPF1 17x9 +45.
ravisraval is offline
The Following User Says Thank You to ravisraval For This Useful Post:
The Racers Line (10-16-2015)
Old 10-16-2015, 11:18 PM   #124
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
The Racers Line is offline
The Following User Says Thank You to The Racers Line For This Useful Post:
ravisraval (10-16-2015)
Old 10-18-2015, 05:26 AM   #125
Rookie84
Rafi
Rafi, sorry to bother you but here's another question. Will your 4 piston kits have better wheel clearance than your 6 piston kits? I really wanted to run your stage 2 kit but it doesn't fit RPF-1 17X9 +35 without spacers which are the wheels that I want to run :p
Rookie84 is offline
Old 10-18-2015, 03:01 PM   #126
Rafi@RR-racing
Drives: Toyota GT86
Our new 4 piston front kit will not clear RPF1 17x9+35. It will easily clear the 17x8+45 version for the BRZ (this is due to the dish on the 17x9's which is not so good for caliper clearance).
That said, a couple years ago we built a Turbo 86 with this exact setup as our new 4 piston kit and it fit 17x9 RPF's with just a 3mm spacer. With such a minimal spacer you don't even have to change the studs, you get enough thread engagement.
That said, it is a bit of pain that you have to use a spacer, BUT, the upside is that the new 4 piston kit uses the thick 0.8" pads.
Rookie84 (10-18-2015)
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 07:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 04:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 11:31 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
