Old 06-04-2012, 06:50 PM   #1
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
Lightbulb Spacers with Stock Wheels
So, these stock wheels have grown on me but their non-flushness is still unsatisfactory (IMHO). I feel they would look better being flush paired with the Eibach Pro kit that I will be ordering soon.
Can anyone think of any issues that would arise from throwing a spacer on the stock wheels? I assume handling would suffer if you used a larger spacer on the rears, plus it may look goofy?
Never replaced nor modified any stock wheel setup on my past miatas nor mustangs. They were all fairly flush!
Starscream15 is offline   Reply With Quote
The Following User Says Thank You to Starscream15 For This Useful Post:
Turbowned (06-05-2012)
Old 06-04-2012, 09:24 PM   #2
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Subaru 5x100 wheel bearings are known to fail. This will make them fail sooner.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 06-04-2012, 09:43 PM   #3
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Spacers = fail
86_ZN6 is offline   Reply With Quote
Old 06-04-2012, 09:50 PM   #4
OrbitalEllipses
Drives: Attitude
From heat and track day stuff; there still isn't a single report spacers destroying bearings anywhere near as fast as autocross or HPDE.
Consider this OP: do you want to pull 20 lugsstuds, replace them with longer ones, and use open-ended or extended lug nuts, AND spacers? Expensive-ish proposition and not one of my favorite jobs to do; though I concede, on a new car lug studs won't be AS much of a PITA to do.
Old 06-04-2012, 10:03 PM   #5
SuperSatinBrz
SuperSatinBrz's Avatar
Drives: 2013 SWP Limited Subaru BRZ
Spacers are not the way to go. The unnatural way of achieving a good offset. IMHO of course.
SuperSatinBrz is offline   Reply With Quote
Old 06-04-2012, 10:03 PM   #6
Cheddar
Saving them pennies...
I had the car on the lift today and was checking out the rims while checking tire pressure and I thought of the same exact thing.
They do sell 20mm+ spacers with its own set of studs already added to the spacer. My buddy had them on his 370Z stocks and no issues yet.
Cheddar is offline   Reply With Quote
Old 06-04-2012, 10:05 PM   #7
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Good to know! thank you!
Also as for the extended studs, I did this on my friends 2012 (may have been 2011) WRX and the fronts were very easy after we found the right bolt to pull those damn rotors off. VERY little bending of the heat shield is all it took. The rears on the other hand...I think you need to drill right into the heat shield to get an access point to push the new ones through. Hopefully this info is helpful to someone because I think a lot of the components are the same on the BRZ.
Old 06-05-2012, 03:46 AM   #8
OrbitalEllipses
Drives: Attitude
Conversion spacers are like this too; I wouldn't run them. Plenty do, though.
Old 06-05-2012, 01:23 PM   #9
Turbowned
Turbowned's Avatar
Replacing 20 wheelstuds, lug nuts, and adding spacers is cheaper than buying new wheels... I thought about doing the same thing until I can afford the Prodrive wheels I want.... they're like $800 ea.
Old 06-05-2012, 01:31 PM   #10
Starscream15
Thanks for all the reponses.
I will deal with the stock offset and look into a new set of wheels at some point.
I was thinking about Rota as an affordable option but after seeing so many pictures of broken Wheels, I'll probably save up for something better. Pot holes and road buckle are a common occurrence here in MN.
Sorry if I just went
225/45/17 on stock 7" wheels? ubersoph Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 04-09-2014 04:59 PM
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 03:07 PM
Aftermarket wheels on stock BRZ/86s yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 2 05-01-2012 02:52 AM
Which stock JDM wheels do you prefer? switchlanez Scion FR-S / Toyota 86 GT86 General Forum 40 02-08-2012 07:34 PM
Why are most stock wheels weak stance? #87 Other Vehicles & General Automotive Discussions 16 12-17-2011 05:15 AM
