Old 06-04-2012, 08:55 PM   #29
Mavrik
Drives: 2013 Subaru BRZ
Originally Posted by RandyP View Post
So, were you completely stopped when you pressed the button? How many seconds before the two red indicators appeared? I'm just starting to play with mine, but it seems the "sport mode" is useless for autox in the dry.
"Sport mode" aka VSC is pointless in the dry.
I was completely stopped, e-brake up, waiting in grid when I was pressing the TRAC OFF button. I had read earlier that it could not be switched off when in motion.
TRAC OFF indicator appeared the moment I pressed the button but the second light didn't appear until roughly 8 seconds later.
I tried today to see if you can have VSC and TRAC OFF at the same time. But when TRAC OFF with all driver assists turned off is active, it seems VSC is no longer on. It turned off on its own.
Mavrik is offline   Reply With Quote
Old 06-04-2012, 08:58 PM   #30
simpleisbest
Senior Citizen
Drives: Scion FR-S
Originally Posted by RiskyTrousers View Post
I took the car out yesterday with a friend who also picked up an FR-S. I ran mine completely stock while my buddy ran with 225 Star Specs, -2.4 camber up front and -1.6 out back.
Can I ask how your friend achieved his camber settings? Was that with the stock alignment bolts?
simpleisbest is offline   Reply With Quote
Old 06-04-2012, 09:48 PM   #31
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
He used specialty performance bots up front and maxed out the "camber correction" tolerances in the rear.
RiskyTrousers is offline   Reply With Quote
Old 06-04-2012, 10:33 PM   #32
Vanguard
Drives: Ford F-150 (not for long)
The H&R bolts? Something else?
-2.4 up front is AWESOME, but for stock purposes it won't work. I highly doubt the subie/scion bolts get you anywhere close to that.
Vanguard is offline   Reply With Quote
Old 06-04-2012, 10:45 PM   #33
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I noticed the fuel cut off as well. So weird. You have to hold both buttons down till they both say off. I still put it in sport mode. When in sport mode the trans holds gears longer! However I still leave it on sport when doing Manuel mode with the paddles. That fuel cut off is wicked though. Wonder if Mts can bounce or if they cut fuel as well.
feldy is offline   Reply With Quote
Old 06-04-2012, 11:19 PM   #34
RiskyTrousers
I think they're called SPC camber bolts. I think they maxed out at -2.9 but he backed it off to -2.4
Old 06-04-2012, 11:45 PM   #35
EMguy
... the super annoying fuel cut. When you hit redline the engine slowly goes down to about 7k, it doesn't just bang off the rev limiter like normal.
Was this an automatic, or manual?
EMguy is offline   Reply With Quote
Old 06-05-2012, 12:18 AM   #36
RiskyTrousers
Manual.
Old 06-05-2012, 11:11 AM   #37
Mavrik
My manual does fuel cut when the driver assists kick in with VSC SPORT on.
I never got right to the redline on my autocross runs so I couldn't tell you how it felt for fuel cut at that point.
Old 06-05-2012, 01:43 PM   #38
MTeator
First 86
The fuel cut at redline is terrible no matter what nannies you have turned off or on. Was hoping it would be more like my MR2.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 06-05-2012, 07:14 PM   #39
Vanguard
I bet the fuel cut can be tuned out. The big question is if it will cause serious damage...
Old 06-12-2012, 09:58 PM   #40
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Car felt good for sure. I sucked driving it.. and yeah, that soft fuel cut sucks ass.
Link to videos/me talking about how much I suck. http://www.ft86club.com/forums/showp...&postcount=120
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-12-2012, 10:48 PM   #41
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Well...had my first event this past weekend. Car drove well but I have noticed some things:
- it seems that when on the power in a straight line...it feels different than on the power in the corners...Situation: going thru the slalom, with all Traction Control off...the car didn't want to accelerate...like it was boggy.... now in a straight line...it feels fine.. I am not thoroughly convinced that there still is some kind of electronic/ECU device *Yaw Sensor maybe, holding the car back..
The car transitions really well..and the BRAKES are fantastic...for stock... its easy to stab brake and kinda steer with the throttle if you have to... it just rotates soo well..
-Traction control is the DEBEL...nuff said
-the lack of Camber is going to be this cars downfall, I feel... I understand the engineering of what they did...but damn, give us a little something to play with
-the Torsion Rear Diff seems adequate for now.. but I am already looking at putting a OS GIKEN 1.5 way diff in it as soon as I know for sure what ST class its going to.
-It really needs a tune...that dead/Flat spot in the lower RPM band really kills the momentum of the car...I am sure an aftermarket tuner will be to fix this.. but as she rides stock...it sucks.
-The car is Quick, Nimble and super fun... my codriver and I Paxed in the top 21...and Raw time in the top 24...out of 104... theres things that I feel will need ALOT of development...and some none at all.
-its a point and Shoot type car...it will pretty much go where you steer it..the gearbox seems adequate for now..but don't leave the traction control on..as you will BOG the launch...no matter what RPM you think your going to leave at...
-car is easy on the eyes on course..
-Quick note on Fuel....Fuel started at 1/4 tank...after 13 runs...6 ea normal...and 1 rerun for timing...never had a fuel issue. the fuel light never came on... we did some testing in parking lot the night before the event...Fuel light was on...and basically drove in sweeping circle for about 5 mins. at speed...like a G'force circle....Never hiccuped once... so as long as you don't run out...I would say 1/4 tank or less is a good starting point for the Fuel..more than that...is just extra weight....We did have a 5 gallon jug on site in case we needed any from the runs..which looks like that will be become std practice....but never needed it...ended up putting it in for the drive home..
more as I think of it..
Bill
Scooby South is offline   Reply With Quote
Old 06-12-2012, 11:52 PM   #42
Mitch
form follows function
Drives: RIP '13 BRZ
Thanks for the fuel tip especially. I'll target a quarter tank for autocrossing until lower is proven.
Mitch is offline   Reply With Quote
Bored to death, give me some movie names! 82mm 4g63 Off-Topic Lounge [WARNING: NO POLITICS] 36 03-07-2013 03:02 PM
Autocrossed FR-S at Scion FR-S First Drive Event in Baltimore! jackoskate Scion FR-S / Toyota 86 GT86 General Forum 69 05-08-2012 07:45 AM
Which would you give up? ant08 Scion FR-S / Toyota 86 GT86 General Forum 45 03-31-2012 04:32 AM
Let's give $1 to the first total'd FRS owner miata Scion FR-S / Toyota 86 GT86 General Forum 55 01-06-2012 11:00 AM
Give Sabine Schmitz the FT86 for some Nürburgring action Andy Scion FR-S / Toyota 86 GT86 General Forum 13 10-21-2011 02:51 PM
