Old 10-05-2015, 10:37 AM   #169
bababooey
Drives: BRZ SWP Limited -6MT
installed cnt recently. in cabin noise is slightly louder than stock (stock front pipe & muffler). behind the car the tone has got a bit meaner but still not obnoxious. took 4 hours solo but im not totally familiar with my way around a garage. that included using a lift, and a 10/15 minute drive to heat it up a bit, lift it again to tighten it all back down. had to loosen the passenger motor mount to lift engine an inch or so to get the stock op out. no amount of tetris could get the pipe out w/o either jacking or removing the shield. had a bit of a tough time getting one side of the header flange on the bolts at first try, likely because of the angle one person has lifting the thing in place while keeping the gaskets lined up on the studs on both sides. screw driver to wedge the stubborn side on.
after install no noticeable exhaust leaks while it was on the lift. no CEL's after about 250 miles, mostly highway. I hope im out of the woods as far as the CEL's go. butt dyno indicates a bump in power over stage 1 OFT. certainly a bump over stock configuration. paired with top speed overpipe since you gotta unbolt all that hoopla anyways. i typically run 93 so theres likely a few more hp to be had from e85.
im satisfied (for now?)
EDIT:: I need to sort out the data channels to log and post em up to confirm things are within safe limits (OFT).
bababooey is offline   Reply With Quote
The Following User Says Thank You to bababooey For This Useful Post:
GT86Dan (10-05-2015)
Old 10-06-2015, 10:48 AM   #170
erbaker67
erbaker67's Avatar
Drives: 2015 FRS RS1, 93 Supra
Originally Posted by drewbot View Post
Alright, so there's this header, and this 1320 performance header I keep seeing on Facebook.
Anyone here can comment on the 1320?
Also would like to know the difference if any. Look very similar to me.
erbaker67 is offline   Reply With Quote
Old 10-06-2015, 10:50 AM   #171
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Only thing I could find was this
http://www.ft86club.com/forums/showthread.php?t=95068
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
erbaker67 (10-06-2015)
Old 10-06-2015, 11:04 AM   #172
erbaker67
erbaker67's Avatar
Seems like 1320 is a good brand as well and for the additional cost of shipping, 385 is a great price for a great product. Thanks @drewbot!
The Following User Says Thank You to erbaker67 For This Useful Post:
drewbot (10-06-2015)
Old 10-26-2015, 07:16 PM   #173
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
I can comment. There is a freaking 4-5 week wait time : (. I may get the CNT just because I am stupid impatient. I was going to go SBD turbo, but I may delay it a month or two so I can get a header and play with it.
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 11-05-2015, 08:15 PM   #174
Strife26
Strife26's Avatar
Originally Posted by WhiteFRS69 View Post
at this point
skip both and look into the Gruppe-s header
been kinda following it, getting some nice reviews
I like the gruppe, but it is 2 3/8". I am on the fence there because I was looking for 2.5" to match the rest of my exhaust. I doubt it matter much being that its 1/8" difference.
I am looking at OFH 1320, Gruppe and CNT but I am not sure which one is best. I have the OFT already...
Old 11-05-2015, 08:19 PM   #175
steve99
Drives: FT86
most turbo kits including sbd one have a turbo specific manifold, hence your header will need to be replaced with turbo kit.
Strife26 (11-05-2015)
Old 11-05-2015, 08:23 PM   #176
Strife26
Strife26's Avatar
Yup. I think I'm gonna wait a while, see how a header plus tune goes. If I still have a need for more, I'll buy the Turbo and sell the header. Thanks!
Sent from my HTC One M9 using Tapatalk
The Following User Says Thank You to Strife26 For This Useful Post:
steve99 (11-05-2015)
Old 02-04-2016, 12:20 AM   #177
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Anyone have audio on this with stock headerback?
Old 02-04-2016, 09:05 AM   #178
bababooey
no audio but i can tell you it is only slightly louder than stock at start up. the brumble comes out when free revving. but ive never arranged a heavy foot drive by while standing on the side road to listen.
Old 03-21-2016, 01:40 PM   #179
ort895
ort895's Avatar
still no dyno sheets?
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 03-21-2016, 09:00 PM   #180
FRSBRZGT86FAN
I'd liken it to whatever the Borla UEL is most likely putting out with an OFT stage 2 uel tune, I have yet to install it and it's waiting patiently at a friends house for May to come round the corner so I can install it when I'm not busy. The collector is the same sort of mess the borla has only a bit neater and the tubing is about the same size I believe.
@DAEMANO do you have any stock vs cnt dyno numbers?
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
DAEMANO (03-21-2016)
Old 03-21-2016, 09:47 PM   #181
ort895
ort895's Avatar
Originally Posted by FRSBRZGT86FAN View Post
I'd liken it to whatever the Borla UEL is most likely putting out with an OFT stage 2 uel tune, I have yet to install it and it's waiting patiently in my basement for May to come round the corner so I can install it when I'm not busy. The collector is the same sort of mess the borla has only a bit neater and the tubing is about the same size I believe.
Gotcha, I'll be running everything aftermarket except catback so I'll post results
Old 03-21-2016, 11:35 PM   #182
DAEMANO
Time Traveller
I only have stock vs. CNT+OP+FP+Phantom Supercharger. Not very helpful for this thread unfortunately. I will say that the header has been great with no issues since installed. I DEI wrapped it and also reflect-a-gold(ed) my oil pan to keep the heat out of the engine oil.
Borla Unequal Length Header Review and DIY F1point4 DIY (Do-It-Yourself) Guides 92 05-10-2021 04:06 PM
Tomei unequal length header Thatguyjeremy Engine, Exhaust, Transmission 5 02-11-2015 03:15 PM
WTB: FA20Club Unequal length header Chrisposey Want-To-Buy Requests 3 09-03-2014 02:59 PM
****Rev Works 4-1 UEL (Unequal Length) Header - $699!**** Rev Works Engine, Exhaust, Bolt-Ons 206 08-01-2014 05:10 PM
Unequal Length Header Noise fuse614 Engine, Exhaust, Transmission 55 07-30-2014 11:06 PM
