#155 |
Drives: UK GT86
Out of interest, where do you get the base tune from? I've been looking through the install guide and the FA20 site and it mentions to download it from the site but not actually where.
.: Stealth 86 :.
#156 | |
Drives: '13 BRZ | '04 E55
The kit is supplied with a binder containing installation instructions. The first page of that binder provides an email address to email requesting a tune file given information from ECUTEK dongle and your cal ID. Sent from my iPhone using Tapatalk
| The Following 2 Users Say Thank You to NotSoJDM For This Useful Post: | Kodename47 (10-05-2015), menikmati (09-14-2016) |
#157 | |
Drives: anything you let me
#158 | |
#159 | |
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
Edit: never mind it doesn't look like it would work. That gold bar looks like it sits further back than the factory crash beam so you'd have no room for the LTR in this kit. You'd be better off with something like the Drift Armor bar for added clearance. Sent from my iPhone using Tapatalk
#160 | |
#161 |
So something kinda funny nobody has brought up...
The Cosworth kit requires a different thermostat as well as full header back exhaust to make only a couple more hp than this kit. Looking over the E-force kit documentation, there is no thermostat and the published dyno results were on stock exhaust components. Is the difference in kits the efficiency of the E-force blower, the tuning, or both? I run Edelbrock components on both my Vettes and have been extremely happy with them. They are made in the USA and they stand behind their products. Warranty or not (my car would be subject to less than 2yr/24k due to age and mileage), the kit seems like a steal. All in they are roughly $4k cheaper than the Cosworth solution for similar gains. My only real complaint is that I would like to see a canned tune option for those of us able to use 93 octane. Then again, if you run the 91 tune with 93, you're fairly certain it'll run like a top even in hot conditions. It would also be nice to see them pair up a separate OC option for the kit with components from their Russell branch. Also quality components I've used often. |
| The Following 2 Users Say Thank You to Uplink For This Useful Post: | Edelbrock LLC (10-05-2015), NotSoJDM (10-06-2015) |
#162 | |
Since I replaced my front bumper (thanks to a semi tire blowout) this kit was the first time I've had to have it off since. The only reason I can think of to pull it again would be for an oil cooler, so you may want to add that to your list. Sent from my iPhone using Tapatalk
#163 | |
![]() Oh, do you know if the stock snorkle is ever used again? Instructions don't mention reinstalling it or the diffuser shield with the new airbox. Unfortunately, about 3 months ago I installed the HKS snorkel, a K&N filter, and Perrin silicone intake tube. It's a shame to think about over $400 in upgrade parts not being reused. |
#164 | |
I did not reuse the stock snorkel. The new airbox tapers outward into a larger opening than stock. Sent from my iPhone using Tapatalk
#165 |
Drives: UK GT86
It doesn't look like it should be used.
.: Stealth 86 :.
#166 | ||
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
I've asked them about having an oil cooler offering (knowing about Russell performance), and they said it is on the cards right now, they just need to prove to the higher-ups that this is a viable business plan. I would just voice your "want" for an OC as much as you can and hope for the best. |
#167 |
The other reason I brought that up is, the guys at Perrin said they were noticing intake airflow issues on the road without the diffuser panel that fits under the snorkel so they put it back.
According to the instructions, this kit does not replace that diffuser either. Curious if they didn't do airflow tests both ways or if the vacuum created by the blower overcomes any possible turbulance. |
#168 |
The Fail Boat
Drives: CWP S.B.
I'm pretty sure we can take out the windshield washer fluid reservoir to help with some weight. That thing is a heavy giant all the way up front. 😛
I'm no owner but likely to be one one day..
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
