Old 10-04-2015, 08:23 PM   #1765
justint5387
Drives: 4 wheels
Originally Posted by smg1138 View Post
Anybody else here running the Whiteline 20mm adjustable front bar? If so, what stiffness setting are you using? I've got mine on full stiff right now and it was pushing pretty hard today. I'm probably going to set it to soft soon and see how that feels. I think with the stiffer front spring rate of the RCE Yellows, full stiff setting may be overkill.
There is no definite answer, every car is different with shocks, spring rate, Camber, tires, and also the surface you are running on
justint5387 is offline   Reply With Quote
Old 10-04-2015, 09:00 PM   #1766
Thorpedo
The SquadWhisperer
Yeah way too many variables.... Camber/toe in front?
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 10-05-2015, 11:25 AM   #1767
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I mostly do daily driving and autocross on weekends. I've had some issues with too much oversteer in Autocross, so have been trying to make it more neutral. Hence the reason I added the front sway bar recently to induce some understeer. However I think on full stiff it's pushing too much, so I'm going to set it on soft soon to see how that feels. I'm just trying to get it as neutral as possible basically.
Current Setup:
RCE Yellow Springs w/ Stock Shocks
Whiteline 20mm Adjustable Front Sway Bar
Stock 14mm Rear Sway Bar
-2 Camber & 0 Toe (front and back)
Enkei RPF1 17x9 +35
Hankook RS3 V2 245/40/17
smg1138 is offline   Reply With Quote
Old 10-05-2015, 02:49 PM   #1768
cjd
cjd's Avatar
Drives: 2017 BRZ
Current Setup:
Enkei RPF1 17x9 +35
Can you get more camber up front? That will help. Though it may be too much with the swaybar. Probably more in back too, but front definitely needs it.
Old 10-05-2015, 02:53 PM   #1769
smg1138
smg1138's Avatar
I may be able to get a little more. I'm using camber bolts, so probably not a lot though. Next time I'm at Firestone I'll see how much more they can get.
Old 10-05-2015, 06:21 PM   #1770
cjd
cjd's Avatar
Drives: 2017 BRZ
Ahh, that may be max with bolts. Camber plates an option? Yeah, they're pricey but... better tire wear and overall response on the flip side.
Old 10-05-2015, 06:30 PM   #1771
connorlug
Drives: #1553 10 Series FRS
Hey guys, after spending the season struggling to compensate for my terrible ST coilovers trying to be more competitive, I'm fed up and ready to move to some new coilovers, what I'm stuck on is spring rates. What is everyone in here running? I was thinking 8kf/9kr.
connorlug is offline   Reply With Quote
Old 10-05-2015, 07:08 PM   #1772
conedodging
conedodging's Avatar
Drives: '14 BRZ
I'm on KWv3 with 400lb/in (slightly over 7k) on all 4 corners.
I've heard of setups using 450lb/in all around, but I can't say I've ever heard/seen anything going above that, for STX.
conedodging is offline   Reply With Quote
Old 10-05-2015, 07:36 PM   #1773
redlined600
redlined600's Avatar
Drives: Fr-s
I run 450f/500r. I suspect if I were trying to be nationally competitive I might even go a little higher.
redlined600 is offline   Reply With Quote
Old 10-05-2015, 10:18 PM   #1774
48Spoons
Drives: Ultramarine FR-S
I'm running 440/440 and the car feels great.
48Spoons is offline   Reply With Quote
Old 10-06-2015, 06:37 AM   #1775
Thorpedo
The SquadWhisperer
Current Setup:
Enkei RPF1 17x9 +35
Get more neg camber up front and try a little toe out.
Old 10-06-2015, 09:58 AM   #1776
connorlug
Originally Posted by vroom4 View Post
I'd go down to 7/7 or 7/8 If you like a loose car.
Thank you everyone for the info, seems like everyone is around the same general area.
Old 10-06-2015, 10:54 AM   #1777
smg1138
smg1138's Avatar
I'm going to see how much more camber I can get out of my bolts. I won't be getting camber plates until next year more than likely.
I set my Whiteline sway bar to soft last night and it feels perfect now.
Old 10-09-2015, 03:39 PM   #1778
smg1138
smg1138's Avatar
What are you guys running for coilovers in STX? Right now I'm still on stock struts with RCE Yellow springs. Will be upgrading to coilovers next spring more than likely though. It seems like KW V3's are a popular option, but the newer spring rates look way too soft. The Feal 441's look great on paper, but you know what they say about things sounding too good to be true. Any of you guys have experience with those?
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
