Old 10-01-2015, 05:54 PM   #1667
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Hey guys
I could really use an assist! My car is in the Top 8 for PASMAG Tuner Battlegrounds. The top two get their cars displayed at SEMA! If I make it through this week, I have one more to get through before clinching a top 2 spot. Votes are done daily, and accumulate over the course of a week.
If you can help a guy out, click here: http://bit.ly/alexdbrz
If you want to help daily and win some stuff from my sponsors, click here to sign up for the daily email reminder http://www.toptierimports.com/wp/tunerbattlegrounds
You have to sign in with Fbook credentials, so I apologize because it's a bit labor intensive.
Thanks
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 2 Users Say Thank You to protpibe For This Useful Post:
Astroboy (10-02-2015), Draco_PR23 (10-01-2015)
Old 10-04-2015, 07:43 AM   #1668
Jonde875
Drives: GT86
HI!
I have question guys how you have installed the wideband afr sensor to your system and how do you get the data from it? Did you connect it to ECU from gauge 0-5V output(white), serial output(blue) or just disable second O2 sensor with ecutek program from ECU and let A/F be analog?
Jonde875 is offline   Reply With Quote
Old 10-05-2015, 06:25 PM   #1669
kbogarto
Drives: 2013 BRZ limited WRB
Originally Posted by Jonde875 View Post
HI!
I replaced the second O2 sensor with the wideband and wired it into the ECU behind the glovebox. James Martin had a thread on here a long time ago I used as a go by. You might be able to find it with a search. Good luck
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
The Following User Says Thank You to kbogarto For This Useful Post:
Jonde875 (10-06-2015)
Old 10-06-2015, 04:20 PM   #1670
Astroboy
Astroboy's Avatar
Drives: None
Anybody have any 1/4 mile times? Just curious
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 10-06-2015, 04:21 PM   #1671
Astroboy
Astroboy's Avatar
Drives: None
HI!
My pos innovative wideband would never work.... 😡
Old 10-29-2015, 03:41 PM   #1672
Jonde875
Drives: GT86
Here is a new happy AVO Turbo Kit owner!
The Following 3 Users Say Thank You to Jonde875 For This Useful Post:
Astroboy (10-29-2015), Draco_PR23 (10-29-2015), protpibe (10-29-2015)
Old 10-30-2015, 12:32 PM   #1673
Jonde875
Drives: GT86
Does someone know how change that AVO dumpvalve to 50% atmosphere I think it is fully recirculating now... is it better to be recirculating for car?
Old 10-30-2015, 12:37 PM   #1674
protpibe
protpibe's Avatar
Take the small plate off the side of the bov. It's held on with 2 screws. 100% recirc is better but not necessary
Jonde875 (10-30-2015), Sportsguy83 (11-02-2015)
Old 11-02-2015, 06:58 AM   #1675
Dammod
Dammod's Avatar
Drives: .
Prepare for some potential backfiring goodness!
"Some will follow your footsteps, easier than they will your advice."
Dammod is offline   Reply With Quote
The Following 2 Users Say Thank You to Dammod For This Useful Post:
Astroboy (11-03-2015), Draco_PR23 (11-02-2015)
Old 11-03-2015, 12:38 PM   #1676
Astroboy
Astroboy's Avatar
Drives: None
I'm thinking about replacing my turbo world bpv for an avo blow off valve and was wondering if it is recommended I get my vehicle re-tuned. Or will it be ok to purchase without re tuning the car
Old 11-05-2015, 01:43 PM   #1677
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
so for this stage 3 kit, i would imagine you are going to need to rebuild the engine with stronger rods and piston?
slyphen is offline   Reply With Quote
Old 11-05-2015, 04:06 PM   #1678
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
AFAIK you don't need a retune when changing a bpv
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
Astroboy (11-05-2015)
Old 11-07-2015, 04:46 PM   #1679
Flashfire88
Flashfire88's Avatar
Drives: Limited Silver
What draco said is right, only time you'll need a retune to run optimal is if you're running a MAF tune and you start to dump to atmosphere (assuming your current tune was internally recirculating).
-Avo @ 10.5psi-
Flashfire88 is offline   Reply With Quote
The Following User Says Thank You to Flashfire88 For This Useful Post:
Draco_PR23 (11-07-2015)
Old 11-09-2015, 01:37 AM   #1680
CharmanderFR-S
Drives: 2013 Lava Fr-s
Can you hear the turbo when driving? (Spool, wastegate, bov, etc.)
CharmanderFR-S is offline   Reply With Quote
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
