, dpfarr
Old 09-30-2015, 06:12 PM   #127
JohnnyP
Drives: 2013 Whiteout Scion Fr-S
81 lbs! , I knew that manifold was heavy, but sheesh, no wonder they want two people lowering that thing during install. Good to know either way.
Looking forward to your impressions (both install and driving).
After reading through the install guide a couple of times (better safe than sorry), I'm not intimidated much. The one step I originally overlooked when it was posted here weeks ago was flipping the clutch line fitting at the slave cylinder to allow for more clearance. I was planning on installing the ACT clutch we're running this weekend anyways so it all works out in that sense, I can just do it now.
Having seen all things included with the kit I was actually pleasantly surprised with the weight. It's not light by any means but with the size of all of the hard parts (manifold, blower unit, heat exchanger, etc..) I had expected it to be heavier. I'm fairly positive the note about having two people drop the unit in together is more intended to avoid damaging any of the wire harnesses or hoses that have been routed to that general area during the install. I can easily pick up the 60 lb unit myself, but maneuvering it into place precisely at that weight is not as simple.
JohnnyP is offline   Reply With Quote
The Following User Says Thank You to JohnnyP For This Useful Post:
BigFatFlip (09-30-2015)
Old 09-30-2015, 06:15 PM   #128
JohnnyP
Originally Posted by djdnz View Post
Thanks for this post, very useful. Can you also measure the stock components you remove? When are you planning on doing the install?
We are trying to do a very thorough install documentation so I would expect it to be completed in 7-10 days. Waiting is the hardest part...
The list of related OE weights should be significantly shorter (Intake manifold, Intake piping and filter, Plastic covers on A/C compressor and Alternator) but I'll get them weighed after for comparison.
The Following 9 Users Say Thank You to JohnnyP For This Useful Post:
Breeeep (10-01-2015), CSG Mike (09-30-2015), Firesnake (10-01-2015), Lunatic (09-30-2015), new2subaru (09-30-2015), NotSoJDM (10-02-2015), Porcupint (09-30-2015), shiumai (10-01-2015), why? (09-30-2015)
Old 10-02-2015, 11:04 AM   #129
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
Oh baby, got this bad boy in yesterday. Will follow suit with install pics as well. So far this kit looks pretty awesome. Even included a binder with documentation, a very nice touch.
NotSoJDM is offline   Reply With Quote
The Following 3 Users Say Thank You to NotSoJDM For This Useful Post:
Avo1789 (10-02-2015), itsibarra (10-02-2015), LucidMomentum (10-03-2015)
Old 10-03-2015, 01:06 AM   #130
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
Attachment 121725
Attachment 121726
I noticed you're going to install a Koyo radiator. I am as well and foresaw a clearance issue that might arise with a thicker radiator. I have measured and you will lose about 1/2" of clearance between the condenser and the crash beam when going to the Koyo. As a result the crash beam will need sectioning. I'm in the process of doing this. Below shows my first initial cut. I will clean it up and cap it.
Btw, this is a badass sc kit!
Pictures:
Nitro22 is offline   Reply With Quote
The Following User Says Thank You to Nitro22 For This Useful Post:
NotSoJDM (10-04-2015)
Old 10-03-2015, 04:06 AM   #131
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Pictures:
Attachment 121775
Attachment 121776
Attachment 121777
Cutting that bumper seriously weakens it's ability to absorb crash energy...
aegisdrgn is offline   Reply With Quote
Old 10-03-2015, 05:22 AM   #132
Nitro22
Nitro22's Avatar
I did state that I was going to cap the cut out. Most of its strength should be restored.
The Following 9 Users Say Thank You to Nitro22 For This Useful Post:
aegisdrgn (10-03-2015), BigFatFlip (10-03-2015), CSG Mike (10-03-2015), Freeman (10-03-2015), GotBRZ1691 (10-03-2015), j123ic (10-03-2015), jmimac351 (12-21-2015), LucidMomentum (10-03-2015), NotSoJDM (10-04-2015)
Old 10-03-2015, 12:36 PM   #133
Irace86
Drives: BRZ + Ducati M796
Yea looks solid
Irace86 is offline   Reply With Quote
The Following User Says Thank You to Irace86 For This Useful Post:
Nitro22 (10-03-2015)
Old 10-03-2015, 01:43 PM   #134
j123ic
Drives: Evo 9
Nitro22, do you think some spacers to move the crash beam forward would've worked?
Perhaps trimming the foam attached to the front may be required after doing this, but I recall that foam being pretty thick. Good work on the clearance cut though. I believe you have restored if not strengthened the crash beam over stock.
j123ic is offline   Reply With Quote
The Following User Says Thank You to j123ic For This Useful Post:
Old 10-03-2015, 05:24 PM   #135
Nitro22
Nitro22's Avatar
Thanks! That's a good point about spacing. For some reason in my head I had a feeling that shifting anything forward would cause headaches with bumper fitment. I knew the method I used kept my boundary conditions the same.
Maybe someone could try the spacer method to make life easier for everyone.
Old 10-03-2015, 06:30 PM   #136
Wraithrider
Wraithrider's Avatar
Drives: 2015 Subaru BRZ Pearl White
Both fitment changes will make a difference in the way the body reacts in a crash. As long as you close the crash bar the change would be less over 5 mph. The cutting of the foam and the shimming of the crash bar would affect the level of damage 5 mph or lower also the moving of the crash bar forward will increase the leverage of an off center hit above 5 mph
Wraithrider is offline   Reply With Quote
The Following User Says Thank You to Wraithrider For This Useful Post:
DannyFRS (10-04-2015)
Old 10-03-2015, 06:33 PM   #137
Wraithrider
Just saying as we would be having these type of problems on the track (no insurance involved ) Haha
Old 10-04-2015, 05:09 AM   #138
NotSoJDM
NotSoJDM's Avatar
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
Just seeing this. Yes I had installed a cosworth and Vortech kit on other cars previously with upgraded radiators and knew this would be an issue.
All I did was flip the grommets in the upper radiator brackets upside down and reinstalled. This allowed everything to line up. Fitment is tight, the welds between core and end tanks do touch the beam but it doesn't look like it'll be an issue.
On the other kits I've done the LTR were not as thick so it wasn't as big of a deal. But ours is massive.
The Following 2 Users Say Thank You to NotSoJDM For This Useful Post:
j123ic (10-04-2015), Nitro22 (10-05-2015)
Old 10-04-2015, 10:41 PM   #139
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
right now... the weight is only thing that really turns me off. I know the power way more than makes up for it in terms of speed, but what about dynamics? There is 60 lb added up high in the engine bay, and 20 lb more spread out in other places.
What's the weight of the JRSC? The JRSC weight is more forward, so maybe it's not much better?
uspspro is offline   Reply With Quote
The Following User Says Thank You to uspspro For This Useful Post:
Old 10-04-2015, 11:27 PM   #140
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
You are correct that there is more weight added up high, but the nice thing is, because of its location, its still mostly between the wheels (ie weight in the "middle" of the car), so at most the center of gravity is not as low, but the polar moment of inertia should be relatively the same. Other kits, like JRSC and most of the turbos, are placed way up front shifting the weight balance forward.
The Following 3 Users Say Thank You to BigFatFlip For This Useful Post:
MaximeT (10-05-2015), Porcupint (10-05-2015), waltco (10-04-2015)
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
