#282 | |
#283 |
Drives: Toyota 86
does the Flex Z also need to settle in first before going to preferred height or you can go straight away to preferred height upon installation.
#284 | |
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Same problem here!!! |
#285 |
Drives: Silver FRS
I had a metallic knock in my left front, thought it was the pillowball. I took a video and sent it to Tein, they said it was the damper and sent me a replacement damper. They were right, replaced the damper, kept original pillowball, works fine now, no noise. Good warranty service from Tein!
| The Following User Says Thank You to SilverFRS For This Useful Post: | gtslow (10-04-2015) |
#286 |
Drives: '13 SSM BRZ Limited 6MT
I got my final alignment done after installing SPC LCAs last week but when I went to adjust the dampers yesterday I noticed the front passenger nut below the twist thing was loose. Video is below. Basically, the nut below the knob is supposed to be stationary but when I turned it counter clock wise, it would turn the nut too very loosely. Turningthe knob clockwise would just freely turn the nut not clicking. I had to turn it all the way clockwise and then some to kind of lock the nut in place. That's how it is now but should I be concerned about anything at this point?
[ame="https://www.youtube.com/watch?v=h6iIXmrlg9o"]Loose nut - YouTube[/ame] |
#287 | |
Drives: WRX 2015 Subaru BRZ
This link may help http://teinusa-blog.com/quick-click-fixes/ |
| The Following User Says Thank You to jdiego For This Useful Post: | tracerit (10-06-2015) |
#288 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
So, over the past two weeks i've been trying out the different settings on the Flex Z's, and have come to the conclusion that there's no 'one best setting', since road conditions and preferences vary so much. but having the option to adjust the damping is definitely worth the cost over just lowering springs and the OEM shocks.
For daily driving to work, no highway, i actually find semi-boat mode to be actually quite practical. there are only a couple of aggressive turns that i take on the short journey, but having the setting soft (10 clicks from full stiff for both front and rear) just makes for a smoother ride over rough roads without going 'full bounce/float'. it's slightly floaty/bouncy at 10 clicks, but it's a compromise. same setting for the freeways of los angeles or maybe 10 clicks in the rear and 11 clicks in the front - primarily for reducing road noise and comfort. for twisty roads, it also depends on the quality of the pavement. i'm finding 5 or 6 clicks from full stiff is pretty good for twisty but rough roads. for smooth, twisty roads, the settings can go stiffer. also note that i'm running wider wheels/tires. the fun part is making the adjustments and seeing the differences. coming from OEM shocks with Swift lowering springs, the improvement in ride quality and handling is really quite eye-opening to me. i guess i didn't know any better until i tried it.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#289 | |
I always get weird looks when I adjust dampers before driving away from a meet. |
#290 |
I'm learning, mike. thank you for the guidance - it's much appreciated!
| The Following User Says Thank You to shiumai For This Useful Post: | CSG Mike (10-05-2015) |
#291 |
Drives: Silver FRS
I like playing with the settings depending on the "mission", makes me think about going with the edfc control so I don't have to stop to adjust. @CSG Mike, do you know the part numbers for the complete kit for our cars? Looking for basic version, not the auto sensing adjusting version.
#292 | |
Contents of EDFC Controller Kit Part Number EDK04-K4469 Contents of EDFC Motor Kit Part Numbers: EDK05-10100, EDK05-10120, EDK05-10140, EDK05-12120, EDK05-12140, EDK05-14140 Contents of Strut Kit: Part Number EDK06-K4474 MSRP for everything together is 451. |
#293 | |
Drives: 2013 FR-S Argento
Mike, what's your opinion in the newer EDFC with g sensors - where it stiffens the dampers as they load. Is that actually beneficial at all for handling? I can imagine it would at least help reduce weight transfer during braking. Thanks Sent from my iPhone using Tapatalk |
#294 |
Drives: BRZ Club blanc perle
EFDC pro is easier to install, as you don't need a half din space for the controller neither routing four cables from the controller to the dampers... Just a power needed in the motor bay and in the trunk.
I have EDFC-Pro but I don't do track and I don't have Flex Z but Street Advance. I keep it to the stifness position (16) as base setup for city use or 4 clics less otherwise, and the EDFC-Pro do a damned good job when you turn, brake or accelerate, keeping the car horizontal. The only limit is on big bumps, as it is not a PASM or other dynamic suspension, it only use one G captor in the controller, not on the dampers, so it won't get harder on it.
Collecteur et frontpipe Supersprint full décat - Catback Remus Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons |
| The Following User Says Thank You to banane63 For This Useful Post: | bfrank1972 (10-06-2015) |
| Tein Flex A and Z!!! | breadcrumbz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 05-24-2016 03:44 PM |
| Tein Flex Z | Bigmaxy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 01-27-2015 03:22 AM |
| WTB - Tein Street Flex and some LCA's | Sugi | Want-To-Buy Requests | 1 | 01-25-2015 03:12 PM |
| 25% Off Tein Street Flex's!!! | RallySport Direct | Brakes, Suspension, Chassis | 0 | 12-31-2014 04:52 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 01:10 PM |
