Old 09-30-2015, 09:40 PM   #15
chas3wba0
chas3wba0's Avatar
Drives: Yes
+1 for camber bolts up front maxed out to approximately -1.5 degrees. That did wonders for fixing my understeer problems
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
The Following User Says Thank You to chas3wba0 For This Useful Post:
Keenercarguy (10-01-2015)
Old 09-30-2015, 11:04 PM   #16
wparsons
wparsons's Avatar
Are camber bolts CStreet legal? Does Scion have a crash bolt set like Subaru does, or are any bolts fine?
flickr
Old 09-30-2015, 11:24 PM   #17
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Crash bolts only. The SPC/Whiteline aren't
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
wparsons (10-01-2015)
Old 10-01-2015, 12:48 AM   #18
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
There are toyota and subaru specific OEM crash bolts, so take your pick. I'll copy and paste the part numbers for you.
Taken from the C Street thread:
http://www.ft86club.com/forums/showthread.php?t=35855
OEM Crash/Camber Bolts. These allow you to add a small amount of front camber. Some cars vary in the amount of camber you can gain. I reached -1.4 while some people could not pass -0.8 and others saw -1.5. Get an alignment after install!. This is likely to throw the Toe off in your front end. Large tire wear, pulling to one side or poor handling can occur from this. OEM part numbers are as follows:
Toyota: SU003-02818
Subaru: 901000394
Keenercarguy is offline   Reply With Quote
The Following 3 Users Say Thank You to Keenercarguy For This Useful Post:
Racecomp Engineering (10-01-2015), SexyPirates (06-21-2021), wparsons (10-01-2015)
Old 10-01-2015, 02:43 AM   #19
Keenercarguy
Mountain Runner
So I've been combing through the forums to look for good alignment specs for just OE camber bolts and so far I've only really been able to find one fairly generic one which was for an FR-S... Which has stiffer rear suspension to begin with so less of my problem. Any have some bulletproof tips/specs?
Old 10-01-2015, 08:27 AM   #20
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
I think you gotta read through the really lengthy C-Street AutoX thread. Tons of amazing details there
The Following 2 Users Say Thank You to drewbot For This Useful Post:
Keenercarguy (10-01-2015), wparsons (10-01-2015)
Old 10-01-2015, 10:52 AM   #21
If you're sticking with C street and can only use the OE camber bolts, you will want to max them out.
For toe, a little rear toe in will help with stability, but you sound like you might prefer 0 toe all around.
- Andrew
Old 10-01-2015, 01:54 PM   #22
wparsons
wparsons's Avatar
- Andrew
If the car doesn't see much street driving, I'd go with a bit of toe out front and tiny bit of toe in rear. Not great for wear compared to 0 toe all around, but would probably turn in sharper.
flickr
Old 10-01-2015, 02:51 PM   #23
Keenercarguy
Mountain Runner
If I was to only do a little toe in the rear (I also daily the car), that would help braking stability, right? I think I'm going to leave he front at 0 for wear... What is a good slight value in the rear?
Old 10-01-2015, 03:25 PM   #24
DarkSunrise
DarkSunrise's Avatar
I'm running 0 toe F/R, along with -1.5 degrees camber in the front. I find 0 toe in the rear actually helps rotate the car a bit under trail-braking. There is some squirm under really hard braking (e.g., 100+ mph into a corner) but I'm not convinced that's due to the toe setting. The ABS systems on these cars is a bit strange to begin with.
Given what you wrote in your first post (and assuming you will be running the same tire compound F/R), I'd start with 0 toe in the rear and see how you like that.
2022 BRZ Build
2013 FR-S Build
The Following 3 Users Say Thank You to DarkSunrise For This Useful Post:
Keenercarguy (10-01-2015), Racecomp Engineering (10-01-2015), strat61caster (10-01-2015)
antiroll bar, help please, perrin, rear sway bar, sway bar
WTB: Rear sway end links or sway bar with endlinks JoeBoxer Want-To-Buy Requests 1 08-03-2015 01:20 PM
gt 86 rear sway bar Scottyp Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 04-22-2015 03:29 PM
WTB: Rear Sway Bar. NorCal_Guy Want-To-Buy Requests 3 11-11-2014 12:28 AM
WTB:OEM BR-Z REAR SWAY BAR Ryeong86 Want-To-Buy Requests 1 09-04-2013 04:40 AM
STI rear sway bar carbonBLUE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-25-2012 12:58 PM
