Old 09-30-2015, 11:44 AM   #15
smudge
Drives: Supercharged GT86
Originally Posted by Kodename47 View Post
You might find that the Borla is in fact the issue and getting a good manifold will sort it out. You want a good merge collector and the right runners and I bet that running a quality 2.5" system won't hold you back. 3" is really for those running a turbo and will be a PITA daily unless you silence it alot, in which case a freer flowing 2.5-2.75" with less silencing might be the optimal solution.
If standard manifolds aren't up to your requirement you could always get a custom one made that will be optimal for an/your SC application.
Why have you made 3 different suggestions on 3 different forums
Manifold is definitely worth a look, but how am I to know which is best when I have a stock catback in place of my damaged Invidia?
smudge is offline   Reply With Quote
Old 09-30-2015, 11:55 AM   #16
Kodename47
Kodename47's Avatar
Drives: UK GT86
Because I like to be confusing
If you want me to be concise then I'll say this: Manifold is more important than a larger bore exhaust. If you want to go completely custom and need a decent exhaust then speak to H&S about a complete package, they are probably the best to give advice design on the basis that they make exhausts for all types of vehicles and have already made manifold and exhausts for the FA20.
The next option is selecting the best off the shelf components or having a mixture of the two.
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-30-2015, 12:41 PM   #17
thunderlights
I have the nameless 3 inch catback and its simply amazing. Quality and fit and finish is simply the best on the market, and it has the most refined sound for a setup like mine. Im currently all stock header and fp/op with the no muffler option and its loud, but doesnt sound nearly as annoying as the tomei exhausts i hear locally. They also make a 1 peice fp/op in 3 inch that will flow better than two peice options.
Sent from my SM-G850W using Tapatalk
thunderlights is offline   Reply With Quote
Old 09-30-2015, 01:30 PM   #18
fika84
fika84's Avatar
Your catback has no comparison to a full exhaust with built engine and supercharger...... Why did you feel the need to post this?
fika84 is offline   Reply With Quote
Old 09-30-2015, 02:17 PM   #19
thunderlights
Um because its a thread asking about 3 inch exhausts? Does that not make sense to you?
Old 09-30-2015, 02:41 PM   #20
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
We can do 3" with your preference of tip style etc.
You're probably best going to a local fabricator for a 3" overpipe/frontpipe. Clearance is very tight with RHD...I know ours won't work.
Jesse@JDLAutodesign is offline   Reply With Quote
The Following 2 Users Say Thank You to Jesse@JDLAutodesign For This Useful Post:
Chad86 (10-18-2015), wparsons (09-30-2015)
Old 09-30-2015, 03:16 PM   #21
Fastbrew
Drives: 2014 Pearl White BRZ
Just to throw this in -
I have a Perrin 3" in the back but I am AVO 2.5 up front. I have an AVO turbo and run E85/Flex getting 350WHP on 10.5 pounds of boost. We can get even more HP out of it before considering a new fuel pump or the air flow. I was glad NOT to have to go 3" up front or do the fuel pump to achieve this goal.
Just pointing this out so you can consider it with your long term goals.
Fastbrew is offline   Reply With Quote
The Following User Says Thank You to Fastbrew For This Useful Post:
smudge (10-01-2015)
Old 09-30-2015, 04:24 PM   #22
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
For those that don't know, I'm not stock
I'm on a built motor running the Sprintex 335 kit. Currently running her in and we're already seeing 1.2bar of boost at just 5500revs
Unless you're making north of 400whp you really don't need 3".
BRZoomTX is offline   Reply With Quote
Old 09-30-2015, 04:59 PM   #23
DAEMANO
Time Traveller
@smudge
I split the difference btwn 2.5" and 3.0" and upgraded to an Ultimate Racing 2.75" Overpipe and Frontpipe combo (resonated catless). I also run 2.5" CNT catless UEL and TRD USA Catback. The OP/FP make an additional zero WHP and 7 more WTQ on my Phantom ESC at 5 psi (roughly equivalent to 7-9pst SC/Turbo) than another Phantom ESC owner running just a stock Header, OP and a 2.5" High-flow cat Frontpipe (both dyno'd, but on different dynos and days). I'm currently at 223 WHP/207 WTQ.
The OP/FP sounds more bassy and quite a bit louder (which I like, but is not for everyone). A 3" setup would probably net the same. My recommendation would be to save your money unless you really want more sound and just a tad more power.
The Following User Says Thank You to DAEMANO For This Useful Post:
smudge (10-01-2015)
Old 10-02-2015, 03:19 AM   #24
smudge
Heading down to a fabrication shop this weekend. These guys made up the custom centre section on my old exhaust and really know their stuff. Hopefully a custom UEL manifold to catback won't be too expensive...
Old 10-03-2015, 09:17 AM   #25
smudge
Quoted £2000 (about $3500) for a full manifold to catback...ouch
Back to square one
Old 10-07-2015, 11:49 AM   #26
smudge
So, I've gone for the Ultimate Racing 3" catback and I'm in the process of deciding on the manifold, overpipe and front pipe
I think the AVO 3" front pipe and overpipe combination is a good shout for the money, but the OP will need modifying to fit the same way the OEM one would as it's designed for the turbo manifold obviously. I think the AVO 3" OP and front pipe paired with a custom manifold may be my best option here
Old 10-07-2015, 08:42 PM   #27
rmak321
rmak321's Avatar
I'm currently running the Nameless catless header and 3" header-back exhaust (overpipe included). Even with my plans to add a SC in the near future I'm swapping the exhaust for the Nameless 2.5" cat-back mainly due to noise. The 3" isn't really necessary unless you're building a racecar. NA it's super, SUPER loud... a turbo would quiet it but SC won't.
rmak321 is offline   Reply With Quote
The Following User Says Thank You to rmak321 For This Useful Post:
Chad86 (10-21-2015)
Old 10-08-2015, 04:29 AM   #28
smudge
I'm used to loud so it's OK. Although I am tempted to get the AVO 3" front pipe with the 5" high flow cat just to keep it a bit tame for track days
Raceseng Shock Tops Questions - 1" or 2" TrogDor the Burninator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-07-2014 10:12 AM
REQ: Looking for sound clip of Nameless 2.5" "No Muffler" Dual Exhaust Axleback jbsali Engine, Exhaust, Transmission 1 01-28-2014 07:22 AM
FS: j2 quad tip exhaust 2.75" NEED THIS GONE "price updated" FRSex Engine, Exhaust, Bolt-Ons 23 07-28-2013 10:07 AM
How many miles do you have on your "Turbo Kit" + Other's poll questions... NickFRS Forced Induction 40 05-10-2013 01:55 PM
How many miles do you have on your "Turbo Kit" + Other's poll questions NickFRS Forced Induction 0 05-01-2013 07:22 PM
