Old 12-06-2013, 07:22 PM   #57
CSG David
CSG David's Avatar
LOL I still think that was a defective rotor. Not saying you guys aren't fast, but that's just too much of a failure to be normal since I'm pretty confident that you guys actually inspect your rotors at least once a day during a DE.
Ryan performed manual ABS with the e-brake after it exploded at 100mph...LMAO!
Old 05-04-2014, 07:25 AM   #58
ja1217
Drives: 2004 Toyota RAV-4 5M
While not on the same level of destruction as the others, I managed to crack my first rotor this weekend. It only took about 16 track days, countless autocross events, and over a year of daily driving. Kind of funny that it happened my first ever session with Hoosiers.
ja1217 is offline   Reply With Quote
Old 05-04-2014, 06:56 PM   #59
CSG David
CSG David's Avatar
Excellent work. Brakes are wear items and glad to know those brakes held up to your level of abuse in such a long period of time.
Old 08-10-2014, 10:08 PM   #60
Sleepless
Drives: 2016 FR-S
How many mm were these worn down?
Sleepless is offline   Reply With Quote
Old 08-10-2014, 10:09 PM   #61
Sleepless
Drives: 2016 FR-S
Has anyone used some brake ducts or GT3 brake cooling scoops to see if the help with the inside wear?
Old 08-11-2014, 12:10 PM   #62
CSG David
CSG David's Avatar
It will help. Ducting will prolong the life of the brake pads, but not the wear of the rotor. Rotor life is the same. With ducting, you thermal cycle your brakes at a higher rate than without ducting. Ducting is great for track use, but not so good for daily use or cold days. Race pads will wear faster if used in the incorrect operating temperature range, which also include driving in cold weather conditions and constantly keeping the average brake temperature below optimal operating temperature of your brake pads.
Old 08-11-2014, 03:56 PM   #63
Sleepless
Drives: 2016 FR-S
Mike, I was referring to the uneven inside vs outside wear on your rotors on the first post. I've not seen such a variance before and you mentioned cooling might make the wear more even.
Also, is the pad wear uneven?
Old 08-11-2014, 03:57 PM   #64
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Mine have very uneven wear from heat. Pad wear is slightly uneven but not that uneven (less than 1mm difference).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-11-2014, 04:04 PM   #65
CSG David
CSG David's Avatar
David here...
We have uneven rotor wear on the inside vs. outside. We wore the J-hooks until they disappeared on the inside. Pad wear on this car was relatively similar with slightly additional wear on the inside.
On the boosted S2000, there is significant wear on the inner pad vs. the outer one. Rotor has a little more wear on the inside vs. outside.
Even then, the brake system lasts longer than factory for our application and we noticed a significant amount of life in our brake pads compared to stock calipers/rotors. For us, the cost of BBK is justified.
Old 08-11-2014, 04:23 PM   #66
Sleepless
Drives: 2016 FR-S
Sorry David ...
So, I'm just trying to understand if cooling would even out the wear. I'm sensing the question is moot if you replace the rotors slightly sooner than you guys pushed yours.
The uneven wear came to my attention mainly because I would typically use the slot/j-hook wear on the outside as a visual clue for when to replace the rotors.
Old 08-11-2014, 05:30 PM   #67
CSG Mike
CSG Mike's Avatar
Sorry David ...
With 2 piece rotors, I've noticed that cracking the inside is more common than the outside. This may be just coincidence, but I habitually check both inside and outside surfaces on cars with 2 piece rotors now.
How cooling affects wear varies by setup. E.g. if you're overcooling the brakes, it may increase wear, whereas if you're bringing the brakes down from borderline overheating to ideal temperature range for the pads, then it may decrease wear.
The *best* way to figure this out is to use temp strips on the caliper, and temp paint on the rotors.
Old 09-30-2015, 01:22 PM   #68
AreteAuto
Racing Enthusiast
AreteAuto's Avatar
Drives: Bone stock 2019 BRZ manual
Of the pads you used with the sprint kit, which were the best? Fade is really getting on my nerves...
“$20 per diddle? I can diddle myself for free and do a fine job”
AreteAuto is offline   Reply With Quote
Old 09-30-2015, 05:34 PM   #69
CSG Mike
CSG Mike's Avatar
"Best" is subjective, as it varies by each setup, particularly the chosen tire compound and power output.
What is your setup?
My personal preference is for the Project Mu 999.
Old 09-30-2015, 06:03 PM   #70
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
What is your setup?
I agree with his preference. Mine was tied between those and the CL RC6.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
This is how much we like our AP Racing/Essex "Sprint" BBK... CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-06-2013 11:30 AM
Question about Long-Term "Garaging" arleewa BRZ First-Gen (2012+) — General Topics 25 01-12-2013 09:13 PM
Some FR-S "news" (pricing update) Sport-Tech CANADA 19 03-24-2012 10:31 PM
Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans vh_supra26 Other Vehicles & General Automotive Discussions 1 02-19-2010 02:53 PM
