Old 09-30-2015, 11:47 AM   #15
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by markitect View Post
Those look awesome!
How do they mount to the car? All I see is the plastic rivets, and I'm concerned about it coming off, or bending the plastic bottom tray when they get dragged through snow.
They attach very strongly using these plastic rivets. We opted to keep the OEM mounting because this wheel well plastic has some give and thus if you end up hitting something (curb), the hope is that the plastic will deform slightly, allowing everything to stay in tact and you making it up/over/past the obstacle. Air pressure isn't strong enough in this area to deform the plastic so it works when it needs to and moves out of the way in the unfortunate case when you hit something.
Hope that makes sense.
Thanks,
Eric
VerusEric is offline   Reply With Quote
Old 09-30-2015, 11:49 AM   #16
adamg
Drives: brz
interesting product. curious how much benefit these would have for cars with the STI front lip already
adamg is offline   Reply With Quote
Old 09-30-2015, 11:52 AM   #17
VerusEric
VerusEric's Avatar
Thanks!
If you look at the OEM unit (hard rubber/plastic type composite), we basically took there idea/design and enlarged/improved on it. It really isn't rocket science or something no one has thought of before. Nearly all OEM cars come with these type of deflectors on them from the factory to reduce drag.
Our unit is wider, deflects air better, and is approximately 0.7" taller (towards the ground when installed) than the OEM unit.
Old 09-30-2015, 11:58 AM   #18
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
sweet! Love seeing R&D for the car
Old 09-30-2015, 04:37 PM   #19
G-awesome
Drives: 2015 Firestorm Scion FRS
bought these suckers just for the hell of it and installed it over the weekend! I didn't even know there were tiny OEM front wheel deflectors until I installed it. I highly doubt it'll make any difference in city driving but I do like the added branding touch on the back of the deflectors! Not sure if I needed to use the washers but I used one to make the fit a bit more snug to the stock underbody.
Now I'm no expert in aerodynamics but since there's a gap above the deflectors on the stock underbody, would covering that hole with an additional plate improve the airflow slightly or would the performance be negligible?
BTW, I'm totally getting your 'tamed' diffuser next!
G-awesome is offline   Reply With Quote
Old 09-30-2015, 07:25 PM   #20
Gunman
Drives: 2019 Mazda Miata RF
That's a small front diffuser. I'm more curious how the tire blocker affects any downforce being generated by that diffuser. I would speculate that leaving it open, would be the best overall gain.
Old 10-01-2015, 11:36 AM   #21
VerusEric
VerusEric's Avatar
We have been under the assumption that those little ducts were to feed a small amount of air to the brakes for the vehicle. Again, you'll see a lot of OEMs do this and they are typically located/pointing right at the inside of the front wheel and we believe the purpose is to deliver a small amount of air to cool the rotor. Granted, we could be very wrong here as we did not design the vehicle but both Paul and I agreed on this assumption from an outside perspective looking in.
A small diffuser does not make sense to us because without an area for the air to vent, we don't see it creating much if any downforce, though it may. To really benefit and create downforce from something in this location, venting the front fender wells would be necessary in our opinion.
@G-awesome , I would personally recommend to leave that gap there without some other supplemental brake cooling. You run the risk of warping the rotors quicker in our opinion.
Old 10-01-2015, 12:18 PM   #22
waltco
waltco's Avatar
Drives: 2013 Subaru BRZ
How much would a rolling wheel in your CFD change your results?
waltco is offline   Reply With Quote
Old 10-01-2015, 12:35 PM   #23
VerusEric
VerusEric's Avatar
We simulate rolling wheels in all of our analysis .
And to answer your question, it definitely changes the results. Some instances quite significantly, others not as bad. We attempt to be as accurate as possible in our analysis so every analysis we do is with all 4 wheels rotating at the speed necessary to obtain the airspeed the vehicle is seeing.
Old 10-02-2015, 03:28 AM   #24
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
Would love these but just a bit pricey for what they are :/ will probably still pick up a diffuser
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 10-22-2015, 01:45 PM   #25
VerusEric
VerusEric's Avatar
I don't think we could get any less expensive, they aren't large but there is a decent amount of work in each unit. Made in the U.S. will never be cheap but we like keeping jobs here in the states.
Old 09-22-2016, 01:41 AM   #26
VerusEric
VerusEric's Avatar
We recently did another run of these; so they are back in stock again! The laser engraver messed up on one of the units.
Please PM/E-mail us for a special price on this slightly blemished unit which is shown below.
Thanks,
Eric
Verus Engineering Brake Cooling Kit VerusEric Suspension | Chassis | Brakes -- Sponsored by 949 Racing 100 07-15-2023 10:18 PM
Modular Hood Louver Kit - Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 276 07-08-2023 04:03 PM
Verus Engineering Air Oil Separator - Information and Release VerusEric Engine, Exhaust, Transmission 127 07-08-2023 07:40 AM
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 09:15 AM
Verus Engineering Carbon Thermoplastic Splitter Components VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 35 11-26-2017 05:23 AM
