#29 |
Definitely slower, they're barely comparable to an RS3 v2.
Not entirely true... they hold up great for time attack format (warm up lap, 3 hot laps, cool down lap). They won't give you 20 minutes of hot laps without overheating, but if you're running that format you're probably not in the market for an RE71R anyway. You'd be much happier with a durable R compound like an NT01, RA1, etc. Not the fastest possible tires, but they'll last a long time and be super predictable through longer sessions.
#30 |
Drives: 2014 BRZ
I realized I forgot to add the R to AD08R above. So, I just want to confirm that for track days, the RE71R is faster and as consistent as the AD08R. The AD08R has been my favorite "street" tire so far. The last RE11s were definitely slower and the Z2 Star Spec seem between the RE11s and the AD08R. When the Z2SS wear out, I want to go with the AD08R or the RE71R.
Thx
#31 | |
Drives: Yes
#32 | |
*edit - those prices are Canadian, before the dollar tanked.
#33 | |
Drives: 2014 BRZ
When was the last time any serious lapper is not competing at some level.But, to the point, I have several priorities for street track tires : - Good in the rain on and off the track - Reasonably quiet off the track. NT01 loudness get old on a multi hour trip to a track - Grip consistency through out the tire life time and through out a session; even on hot days - Given the above, best grip possible Notice that price nor wear are priorities. So far, the AD08R has been the hands down winner. So, its either going to be the AD08R or the RE71R.
#34 |
Drives: shitboxes
I'm surprised you guys are getting 3 decent hot laps out of the re71r. If I don't nail the first lap with these tires, there's no way that I'm getting a good time on lap #2.
My routine all season has been to do a 3/4 of a lap warmup, 1 flat out hot lap, come into the pits to cool down the front tires, then go back out for 1 more hot lap at the end of the session. The lap times have been great, but for most people it would be more fun to run full sessions chasing down faster cars. |
#35 | ||
From what I've heard, AD08R's fall off pretty bad in grip after enough heat cycles, long before they're out of tread depth. I know a couple people that found a 0.2G difference in peak grip after a few events, with tons of tread left. The data was compared to other cars on different tires at the same events, so the variable of weather and track surface are effectively removed. How long do you expect the tires to last? How many lapping days are you running, and how much street driving? RE71R's will probably not be long enough lasting for most people if they're driving them on the street too. I got about a full summer, with about a dozen track days out of my RS3's (RS3 v2, 225/45/17's), and daily street driving. Another thing to keep in mind is how the tire feels and responds. The RE71R's are like the RS3's in that they like a bit of slip and have softer sidewalls (need more camber). AD08R's are more like ZII's in that they don't like to slip as much for max grip, and will require less camber with the stiffer sidewalls. You'll get better steering feel from the stiffer sidewalls, but if your driving style likes more slip angle, you'll be disappointed. Quote:
#36 | |
Drives: 2014 BRZ
I've been driving on track for 15 years (20+ events per year) and until last year, I mostly drove on NT01s at the track. I decided to see how the fast street tires would hold up and find them to be just fine. I drive the car at the limit so the tires are not babied by any means. The street tires are about 2 sec slower than the NT01s but since there are no trophies to be won, I like the convenience of not having to swap wheels and I find the lower grip to be both entertaining and educational. The tires have lasted about 9 track days with no noticeable grip fall off over their life (but I'm not competing so if they fall off by a tenth or two, I would not notice). I've spoken to others that I've met at the track that drive on the AD08Rs and so far, everyone has had the same experience. Anyway, looks like I'll just have to try the RE71s to see for myself. Thx
#37 |
By the fastest street tires I meant RE71R's and Rival-S. They're both at least a second per lap faster than ZIISS, RS3v2, AD08R, etc.
NT01's shouldn't be any faster than an RS3 or AD08R, unless you're measuring time on the 10th lap, and definitely aren't faster than an RE71R.
#38 |
Drives: 2013 FRS / 2013 427 Vert
Hard to believe an RE 71 is only good for one hot lap when we can get an entire 14 hour endurance race done with one set of RE 11's. Are they really that different?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#39 | |
I've seen a few people get 3 hot laps easily out of them, even on heavyish cars (corvettes).
#40 | |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
I ran Z2 on my BRZ and have fresh RE71R on my S2000 now. The RE71R have about half the life of the Z2 for both street driving and auto x. The RE71R have softer sidewalls and require higher pressures than the Z2 in my experiences. The RE71R have more grip and less squeal much like a R comp compared to the Z2. The RE71R grease much quicker and don't seem to hold up to heat nearly as well as the Z2. I will probably continue to use the 71Rs for auto x and get another set of Z2 or something else for lapping for 2016. |
| New for 2016? | JRCmx | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 09-12-2015 06:45 PM |
| 2016 BRZ | botbs | BRZ First-Gen (2012+) — General Topics | 274 | 07-04-2015 08:20 PM |
| 2016 Subaru STi | tahdizzle | Other Vehicles & General Automotive Discussions | 11 | 06-23-2014 03:35 AM |
| 2016 FR-S vs 2016 MX-5 Coupe | NWFRS | FR-S / BRZ vs.... | 55 | 11-29-2013 11:17 AM |
