Old 09-28-2015, 09:22 PM   #1
ionhsmith
Drives: 2014 Brz
oil weight for turbo?
Hey guys i was wondering what oil weight i should be using for my brz with the speed by design turbo kit?
ionhsmith is offline   Reply With Quote
Old 09-28-2015, 09:26 PM   #2
swarb
The Following User Says Thank You to swarb For This Useful Post:
cdrazic93 (09-28-2015)
Old 09-28-2015, 09:29 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
The same oil you put in now.
But really dude, unless the manufacturer of the turbo calls out for a specific oil run that. Read your manual. Read it again. And call your turbo manufacturers tell them you didn't read shit and are a total noob and ask them what kind of oil they recommend.
Old 09-28-2015, 11:14 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
No.
Old 09-28-2015, 11:16 PM   #5
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
edit; see below for better attempt lol
Old 09-29-2015, 12:25 AM   #6
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Originally Posted by cdrazic93 View Post
Oil temp* the thread should read.
Get an oil cooler, you must. Operating temperatures, in danger.
insert your best yoda voice
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 09-29-2015, 12:34 AM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
gimme a sec...
"change, your oil weight does not. Track your temp, you must.
Cool your oil, you should.
hm hm hm..."
Old 09-29-2015, 07:27 AM   #8
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
manufacturer manual would be ideal but sadly the manual doesn't talk about a turbo so.....
All turbo subaru engines run 5w30. But all subaru engines also have the oil cooler/warmers below the filter to.just beat the car up until the damn oil temp is safe.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 09-30-2015, 01:09 AM   #9
justinsstang
I don't think this is an illegitimate question. Oil recommended for the car in the manual is no longer valid once you go FI. It's no longer the car Toyota built and may require a thicker oil to be safe.
justinsstang is offline   Reply With Quote
The Following User Says Thank You to justinsstang For This Useful Post:
NLS8520 (09-30-2015)
Old 09-30-2015, 02:01 AM   #10
aagun
Drives: 86
5w40
aagun is offline   Reply With Quote
Old 09-30-2015, 04:22 AM   #11
xuimod
Drives: 2007 MX-5 Miata, 2015 VW Golf GTI
Use a good synthetic. It can withstand higher temps better.
xuimod is offline   Reply With Quote
Old 09-30-2015, 05:10 AM   #12
ionhsmith
Drives: 2014 Brz
Well the car calls for 0w20 so i have been using mobile 1 0w20 ... a friend said i might want to use a thicker oil because of the oil temp if i go turbo ... thats all i was wondering ... i knew what the manufacturer recommended for a stock engine. Thanks for the info
Old 09-30-2015, 05:27 AM   #13
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@CSG Mike, might want to correct some trains of thought im here...
Old 09-30-2015, 01:17 PM   #14
GsxrMe
GsxrMe's Avatar
5w30 has been great for me. Never seen temps over 230. Average seems to be 217 with my logs in torque pro
2014 Subaru BRZ
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
Weight Reduction vs. Weight Distribution (for track use not for drag..etc) glamcem Tracking / Autocross / HPDE / Drifting 21 07-01-2014 11:38 AM
weight of turbo effect handling Gilwith1l Forced Induction 7 03-28-2014 02:12 PM
More weight to the case that Subaru will release a factory turbo RAN94A AUSTRALIA 25 11-18-2012 10:36 PM
