Old 11-20-2014, 06:06 PM   #155
notout86
Drives: GTS 86 auto
just pull the knee pad off, take the h/u out and you can reach in the hole and down to the knee pad hole and pull the wires up. Do not cut yourself on sharp metal edges inside.
If you send plane tickets I will jet over to Spain and show you
GTS86 Auto (Australia)
Old 11-21-2014, 03:34 PM   #156
pepe
Drives: gt86
hahaha, ok, you are welcome
pepe is offline   Reply With Quote
Old 12-12-2014, 04:22 PM   #157
pepe
Drives: gt86
disassemble backseat as in this post, for the cable of the camera under the seat, directing it towards the center console?
Insert the cable through the top of the console, or put the cable in the vertical side of the center console?
http://www.ft86club.com/forums/showthread.php?t=54181
Old 12-12-2014, 04:55 PM   #158
pepe
Drives: gt86
pic
Old 12-12-2014, 04:57 PM   #159
pepe
Drives: gt86
which is the correct line? Blue or red?
Old 12-14-2014, 03:54 PM   #160
pepe
Drives: gt86
installation completed! ( blue line jeje)
Old 09-28-2015, 06:06 PM   #161
oakbank
Drives: Nissan
I am looking for an easy to install back up camera as well, just purchased a new truck and i am having hard time to park . Do you guys know any online supplier ?
oakbank is offline   Reply With Quote
Old 09-28-2015, 09:14 PM   #162
ChiefG
Skeptic
ChiefG's Avatar
Drives: 2013 FR-S Ultramarine 6A
Google is your friend. You can get them from anyone who sells auto electronics, Ebay, Amazon, etc etc. Just make sure your head unit will accept a backup cam, or else you'll need to get a new system.
"All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business. " - Red Green
ChiefG is offline   Reply With Quote
Old 09-29-2015, 09:25 PM   #163
oakbank
Drives: Nissan
I just ordered this http://www.tadibrothers.com/Catalog/...-Backup-Camera from tadi brothers , they have good reviews and im hoping to receive a high quality product. Let's see!
Old 04-03-2016, 09:25 PM   #164
NativeClan
Drives: 2014 Grey BRZ
Just finished my install with the "Fit Camera". Had to splice the power for the camera into the harness. Two crimps. The rest was mounting the camera and running the cable under the seat to the center console and to the HU. Easy Took a couple of hours. but if I did it again and had everything handy it would take about an hour.
NativeClan is offline   Reply With Quote
Old 12-30-2017, 02:19 PM   #165
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
Can someone update the pics? Photobucket no longer works.
K. Casey | NER SCCA | SSC - '14BRZ For Sale
Imp is offline   Reply With Quote
Old 02-07-2018, 08:59 PM   #166
RBenz13
Custom User Title
RBenz13's Avatar
Drives: '13 SWP MT BRZ Ltd
Use the Chrome extension for Photobucket. Fixes them immediately.
RBenz13 is offline   Reply With Quote
Old 02-12-2018, 01:01 PM   #167
Imp
Bring out your dead
Oh, I have to use Chrome...
Hmm...
--kC
Old 02-13-2018, 12:45 AM   #168
MasterMech77
MasterMech77's Avatar
Drives: 2014 Scion FRS 10 Series
Parts on Market / Easy DIY
Originally Posted by zoomzoomers View Post
I'm personally waiting for the JDM parts to be available here in the US. Then it should be entirely plug and play. Just hope it won't cost and arm and a leg. Here's hoping the wait will pay off. Cheers to you for taking your own route! :happy0180:
The "JDM" parts have been available since early 2014. However if you are considering having the dealership do the install then, good luck with that. I did my own install. It was simple, as long as you can follow instructions and understand simple hand tools, everything is straight forward. Regardless of a shop or a DIY job, everyone is going to have to "tap" in to the reverse signal from the factory wiring harness. Depends on if you go through the trouble of pulling the pin in the factory harness and installing a signal wire with the factory wire. OR just using a simple screw together wire tap (my preferred method, less chance of damaging the factory connectors). If you want the part numbers for the camera and wire harness I used, please feel free to reply and let me know.
2014 Sc10n FRS 10-Series
#655 of 2500
MasterMech77 is offline   Reply With Quote
DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders Nitro DIY (Do-It-Yourself) Guides 42 07-02-2016 11:10 AM
Name that spoiler! (SOLVED) WingsofWar FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 12-06-2014 01:22 PM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
how I solved my gilrfriend's problem with headrest angle alexmotrix Cosmetic Modification (Interior/Exterior/Lighting) 8 08-08-2012 08:00 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
