#1737 | |
Drives: 2017 BRZ
I haven't found the car tracks badly on road trips, but I think that's often why toe is added. Maybe it just doesn't bother me. I don't drive most weeks though. |
| The Following User Says Thank You to cjd For This Useful Post: | strat61caster (09-26-2015) |
#1738 |
btr.life
Drives: 2022 GR86
So for wheels, the +45mm offset 17x9 should be fine right? I think I heard that you need a 5mm spacer in the rear with the +45mm's...Or go with the +35mm offset wheels and be good?
Also, brakes. I've heard you can swap rotors with a WRX rotor that is a pound or two lighter on each corner. Anyone have info on that or lightweight brake kits?
#1739 | |
Drives: Ultramarine FR-S
| The Following User Says Thank You to 48Spoons For This Useful Post: | justinco (09-26-2015) |
#1740 |
Drives: 2017 BRZ
#1741 | |
Drives: 2013 Red BRZ
I don't think the rotors can be lighter than stock. The weight saving is in the calipers. |
#1742 | |
btr.life
Drives: 2022 GR86
How about the wheels? Specifically looking at the RPF1's of course, just want to get the right offset (+35mm or +45mm).
#1743 | |
Grip>Drift
Drives: FRS
I would recommend et35. Those will fit the AP kit of you ever get there too. I'm running 35. Sent from my iPhone using Tapatalk
#1744 | |
Drives: 2017 BRZ
Front only for the weight savings. I'm sure you can find something for the back that's lighter, but not much.... And not nearly the upgrade either. |
| The Following User Says Thank You to cjd For This Useful Post: | justinco (09-27-2015) |
#1745 | ||
btr.life
Drives: 2022 GR86
#1746 | |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
said post about sways |
| The Following User Says Thank You to drewbot For This Useful Post: | Calum (09-28-2015) |
#1747 | |
That Guy
Drives: 2013 asphalt FRS MT
Hey, I just got linked into this thread. With the addition of a larger front sway bar what are you changing about how the car behaves? |
#1748 |
Less oversteer (but more understeer). (Too much oversteer is slowing you down. On the other hand oversteer is usually an advantage in slow and tight turns. But then again if it's too stiff in the rear, the differential may struggle out of u-turn, especially if you are on race tires (not the case in STX).)
| The Following User Says Thank You to rx3 For This Useful Post: | Calum (09-28-2015) |
#1749 | |
That Guy
The benefits of a larger front bar, that I can see, would be quicker turn in and possibly reducing wheel spin. Is the goal really just shifting the balance toward increased understeers? If that's the only goal, why not just do it with alignment and/or tires? Last edited by Calum; 09-28-2015 at 06:20 PM. |
#1750 |
Drives: 2013 Satin White Pearl BRZ
You really want to negative camber and a front sway bar. I don't think we will need anything in the rear.
Front sway and negative camber took out a most of the understeer for me, that you were describing Calum Sent from my SAMSUNG-SM-G900A using Tapatalk |
| The Following User Says Thank You to jbailey8748 For This Useful Post: | Calum (09-28-2015) |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
