Old 06-04-2012, 01:26 PM   #1
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
BRZ Front License Plate Custom Mount
Picked up my car Friday night (6/1/12) and drove it home with no front plate. First order of business for Saturday morning was figuring out how to mount the plate without drilling holes directly in to the bumper. I liked the idea of mounting the plate on the grill but the opening on the BRZ was about a half inch short of fitting the plate. After about a half hour of scratching my head I came up with the following idea. To make this work I had to make a cut in the underside of the bumper about as long as the license plate (12") which wasn't difficult at all and without the plate mounted the cut is practically invisible (as thick as the blade used to make it).
I made a bracket using a 12" aluminum ruler (a bicycle spoke ruler to be exact) and drilled the holes in that where necessary.
I took the slip on nuts that came in the original plate bracket and slid them on the new mount. Zip-tied the new mount to the bumper and bolted the plate in place.
So there you go, nice clean look and no holes in the front of the bumper. Also, one less reason to get pulled over.
sure74 is offline   Reply With Quote
Old 06-04-2012, 01:30 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Very nice DIY mount. Clean looking.
Old 06-04-2012, 01:31 PM   #3
luxmn
First FR-S
Drives: Whiteout MT FRS
i like it, kudos
luxmn is offline   Reply With Quote
Old 06-04-2012, 02:53 PM   #4
sure74
sure74's Avatar
Originally Posted by luxmn View Post
i like it, kudos
Thanks guys.
Old 06-04-2012, 03:02 PM   #5
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Looks great. Where did you get that bracket?
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 06-04-2012, 03:26 PM   #6
sure74
sure74's Avatar
Thanks.
I made the bracket out of an aluminum ruler.
Old 06-04-2012, 04:03 PM   #7
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
Looks great, however, looks like you're blocking tons of airflow to the radiator.
RiskyTrousers is offline   Reply With Quote
Old 06-05-2012, 11:19 AM   #8
sure74
sure74's Avatar
Thanks for the compliment and comment.
There is a bit of room under the plate but I can't imagine that my daily driving will create an issue of not enough airflow to the radiator. I will keep an eye on the temp to be sure.
I should be able to move the mount up to the next row in the grill and still have the plate numbers visible. That may even be a better look, have to try that out.
Old 06-14-2012, 02:43 AM   #9
Motopythons
Let it rain!
Motopythons's Avatar
Drives: 2012 Subaru Imprezza
Please do and post pics. Very interested to see if this can work or not.
Motopythons is offline   Reply With Quote
Old 06-14-2012, 03:05 AM   #10
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Looks clean! Definitely beats drilling holes in a new car... I was thinking if I should just get a relocating kit or get a custom vinyl shop to print the plate out in reflective material and stick it in the middle of the 'stache.
DaJo is offline   Reply With Quote
Old 06-28-2012, 02:02 PM   #11
sure74
sure74's Avatar
I moved the mount up one level in the grill. I had to notch out the bracket just a little so the plate would sit low enough for the numbers to be fully visible.
And now there is a little more room under the plate for air flow!
Best part is the side view.
Old 06-29-2012, 05:37 PM   #12
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
I like this! Too bad my bumper already has holes..
rcm47 is offline   Reply With Quote
Old 06-29-2012, 06:57 PM   #13
MRZ415
Drives: 2015 Subaru WRX
I like your idea , now make more of it ,
batch it together along with some simple
picture instructions..... Profit
I'll buy something like that
for $20 and it looks more clean to me than offset plate via tow hook
I saw the bike ruler on amazon for 7 bucks
and I can scrap up the rest of the stuff I guess.
MRZ415 is offline   Reply With Quote
Old 06-29-2012, 07:38 PM   #14
Aetyrno
Drives: 98 Camry
Could you have cut or folded the plate instead?
Also this may be illegal in some states. Oregon says you can't have anything that isn't a plate holder covering any part of the plate :/
Aetyrno is offline   Reply With Quote
Front License Plate Solution? Dillano609 Scion FR-S / Toyota 86 GT86 General Forum 72 03-16-2013 02:00 AM
Another license plate idea.... michaelahess Cosmetic Modification (Interior/Exterior/Lighting) 4 06-07-2012 08:24 PM
Front License Plate Replacements Bonburner Cosmetic Modification (Interior/Exterior/Lighting) 14 05-14-2012 06:25 PM
Front License Plate Location Polish Person Scion FR-S / Toyota 86 GT86 General Forum 44 12-16-2011 11:04 AM
