Old 09-28-2015, 02:48 AM   #1
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
OFT Tuning to 8,500 RPM
After some oil related troubles (or some other unfortunate, but unknown issue), my engine is being rebuilt at Moto-East. In addition to a basic rebuilt, the engine is getting upgraded with new valve springs and a Reimax oil pump which will allow the engine to safely rev up to 8,200 RPM or higher.
With that, I am curious if there is any tuning required to let the engine do this safely beyond just setting the fuel cutoff thresholds to higher values. Do I need to tune various parameters that control timing and fueling, or are the tables already in the basic tune good enough? The car will be run on e85 and 93 octane if it makes a difference.
Luckrider is offline   Reply With Quote
Old 09-28-2015, 04:16 AM   #2
swarb
Look at dyno sheets. Power drops off quite a bit after 7k. No real reason to rev that high unless you have cams that might power up there or need that extra couple mph to avoid shifting in a turn etc.
Old 09-28-2015, 05:58 AM   #3
steve99
Drives: FT86
you might want to talk to @celek @Tim Radley and @Element Tuning
the volumetric efficiency seems to fall away after 7000 on NA motors, so your likely going to need head work cams valves ect to produce more power past 7000 rpm as oposed to just reving past 7000
celek (09-28-2015)
Old 09-28-2015, 06:02 AM   #4
Tim Radley
Drives: None
You need to change the intake manifold to make it rev higher. Cams will help a little but increasing peak power rpm point requires a shorter intake runner length.
Tuning of course. Stock knock settings are conservative.
What valve springs are you using and what are the seat and nose pressures on them?
Tim Radley is offline   Reply With Quote
Old 09-28-2015, 07:01 AM   #5
Luckrider
Luckrider's Avatar
I had a whole large post written up that accidently got deleted when I was almost finished typing it because I refreshed the page. It included a part about knowing power dies off hard NA. That's not my concern at all for doing this. I'm simply curious as to what is required to further increase the rev limit safely beyond what the basic OFT tunes do already
Old 09-28-2015, 07:29 AM   #6
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
As far as the tune, nothing more than define the tables for it really. So essentially scale the table axes to cover your desired rev range (and a little over) and tune for the values for timing and fuel. You can't safely just use whatever's in there, when you exceed the table values it doesn't interpolate the next value or anything, it just uses that cell.
Also I don't think anyone mentioned the oil pump, I don't believe any real testing data exists on it out so there's no guarantees it'll solve oiling issues at higher RPMs.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 09-28-2015, 07:41 AM   #7
Tim Radley
Drives: None
Stock pump fine to 8000rpm on 10W/40 oil. I posted the data on the other thread. Anything above that i don't know as I didn't want to push the stock connecting rods beyond that rpm.
The Following User Says Thank You to Tim Radley For This Useful Post:
Luckrider (09-28-2015)
Old 09-28-2015, 07:55 AM   #8
Luckrider
Luckrider's Avatar
Beyond what Tim has said, someone showed that the new Reimax pump is good for an extra 5L of oil flow.
That's what I figured it would be as far as tuning. This will be something I slowly build on over time then. I wan't overhead in the tune and then just drive below that for obvious power reasons.
Old 09-28-2015, 11:52 AM   #9
celek
Resident Gear Head
celek's Avatar
Agree with both statements above.
I think our TQ dip is partially because the head outflows the stock manifold, completely emptying the plenum until it starts to catch back up.
The heads if you think about it, the port design is simular if not the same as the FB25... 2.5ltr Turbo, or the FA20DIT WRX.
They flow enough power to make 750+ HP with minimal or no modification.
That being said on a NA 2.0ltr they outflow the stock manifold. But even with attempts to make an afermarket manifold out there no one is increasing the plenum size enough and the same result occurs.
The head does not need ported its factory flow is fine. The actual bottleneck is the intake itself. @Tim Radley told me he actually gained some power positioning putty in the intake ports to choke it down and gain more velocity. Making it more efficient to the manifold on top.
celek is offline   Reply With Quote
Old 09-28-2015, 12:02 PM   #10
bfrank1972
Drives: 2013 FR-S Argento
Interesting - I'm genuinely curious to this theory, if the intake is a big limiting factor during the torque dip, how is it possible that improving exhaust flow with a header has such a dramatic impact?
Old 09-28-2015, 12:14 PM   #11
celek
Resident Gear Head
celek's Avatar
Its also part of the scavenging of the engine.
The dip is still present after a header "partially" fixes the dip
And most pictured dyno graphs are 3500-4000 RPM and up. The dip is shifted below that.
Old 09-28-2015, 12:27 PM   #12
fika84
fika84's Avatar
Hopefully @NotEric6 can get us an NA manifold one of these days......................
fika84 is offline   Reply With Quote
Old 09-28-2015, 12:57 PM   #13
bfrank1972
Right, better header design increases flow and can be tuned so that the exhaust pulses improve scavenging on the exhaust side, but if the intake is a restriction in the system, wouldn't we still see that dip?
In general the reason you buy headers isn't for massive gains in the upper RPM range (although there are gains), it's to flatten out the torque dip. My intuition would tell me that the intake isn't part of the torque dip, but I know that the many factors affecting VE over a given RPM range are often not intuitive I was just looking for a more technical explanation.
Old 09-28-2015, 01:10 PM   #14
celek
Resident Gear Head
celek's Avatar
You mean these?
Besides the fact they are out of the power band they do not mean much unless you are cruising along double clutching granny shifting.
But they are still present
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 05:02 PM
Feeler: Dyno Tuning Session via Jamesm @ HRI tuning sw20kosh Northern California 27 11-28-2014 08:53 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 04:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 07:33 PM
