Old 09-18-2015, 10:57 PM   #15
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
Thanks Steve. I sent them a copy of the stock file and a copy of a file that would load on. The only difference is when they were created. We'll see what they come up with!
you can never overwrite the stock file in oft the only way is to write scock file back to car then erase oft you only need to do this to unmarry device.
if the stock file wont write back to car then something weird has happened, talk to the oft guys.
'14 BRZ LIMITED-OFT (W.W. TUNED)-PERRIN-K&N-WHITELINE-DIODE DYNAMICS-GRIMMSPEED-REXSPEED-FT86-TAPTAP-OLM-GOODYEAR-OSRAM-WEIR-ENKEI-TOMEI EL
MGPAX is offline   Reply With Quote
Old 09-27-2015, 11:24 PM   #16
MGPAX
Still 17!
MGPAX's Avatar
Originally Posted by Shiv@Openflash View Post
Hi guys,
I'd like to use this thread to remind everyone to ALWAYS flash your ECU back to stock (original file) before taking your car in to the dealership if there is ANY chance that they will replace your ECU or update your ECU software. Doing either will essentially divorce your OFT from your car and make it unusable.
...unless your car won't take the .ori file any more...then? Help??
Old 09-27-2015, 11:43 PM   #17
Cole
Not a troll
Cole's Avatar
Then you'll get the privilege of paying to send your tablet back to be serviced.
Cole is offline   Reply With Quote
Old 09-28-2015, 12:27 AM   #18
steve99
Drives: FT86
The oft checks the vin number in the ecu against the vin number in the storred original file in the oft they must match else oft will not write a rom.
sometimes the dealer forgets to write in the vin number to the new ecu or they get it wrong like zero instread of letter o then oft will think it a different car.
if dealer updates your rom to new calid oft will still write but you wont be able to read in the new calid rom so you get stuck on old calid, its not a big drama as oft tuned roms are based on latest calid compatable with your car anyway eg the 700C tuned roms are actually B01C roms inside.
Old 09-28-2015, 12:58 AM   #19
MGPAX
Still 17!
MGPAX's Avatar
My car didn't go to dealer but stopped being able to load .ori file. something about the updates with OFT made it think it was a different car.
Still waiting on Shiv and them to let me know what's up.
Old 09-29-2015, 04:35 AM   #20
steve99
Drives: FT86
sounds like something corrupted in oft hopefully the oft guys can reset it
MGPAX (09-29-2015)
Old 10-11-2015, 11:39 PM   #21
MGPAX
Still 17!
MGPAX's Avatar
Almost a month has gone by and the only response from OpenFlash Tech is that they need me to send them the stock file and one that works.....which I did already 10 days before and then did again last month......
Customer service sure is getting sad these days.
Old 08-02-2017, 11:37 PM   #22
jorgerendonjr
Drives: Frs
I'm currently having the same issue as OP but I just got my OFT and just read my stock ecu on the tablet.
My tablet came without tunes from factory nor did they get saved automatically when I read my stock ecu.
So I used OFM to get the OTS tune files corresponding to my CaliD and when I try to load these tunes onto my car I get the same error message of mismatching ecu and then the other error right after too.
jorgerendonjr is offline   Reply With Quote
Old 08-03-2017, 12:02 AM   #23
steve99
Drives: FT86
send me the original file rom from oft.
Id say your car has been tuned previously and has a calid hacked rom
once I see your stock rom ill know whats going on
Old 08-03-2017, 12:16 AM   #24
steve99
Drives: FT86
of just read out original file from oft with openflash manager and post it up here as attachment, theirs no vin or anything in that section of ecu
Old 06-24-2020, 03:09 PM   #25
Renwick
Drives: Brz
I HAVE THE SAME PROBLEM RN
Hey I was just wondering if you ever resolved this issue ?? And how? Open flash performance has yet to respond to me.. please help
Renwick is offline   Reply With Quote
Old 06-24-2020, 08:49 PM   #26
steve99
Drives: FT86
post up you original rom file from oft ill have a look whats going on
