Old 09-27-2015, 05:21 AM   #1
Kdej1
Colten Drew
Kdej1's Avatar
Drives: '13 Fr-s // '95 Civic // '09 Vette
Anyone running 15s in the rear?
Looking around to see if anyone has or possibly knows what offset would be a nice fit. Looking to run 15x8 - 15x9 (not sure what offset would fit best) 235/60/15's or 275/50/15's (both 26.1 est diameter)
Kdej1 is offline   Reply With Quote
The Following User Says Thank You to Kdej1 For This Useful Post:
Tonrogs (11-25-2019)
Old 09-27-2015, 12:31 PM   #2
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I'm not sure 15s will fit over your brakes.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 09-27-2015, 12:41 PM   #3
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I believe there are a few 15s that will fit over the rear brakes, but not the front. 275 is a HUGE tire...are you going to 15s because you want to drag the car? 235 would be plenty of tire for a N/A motor with a drag radial, as would an 8" wheel.
Old 09-27-2015, 12:55 PM   #4
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I've seen a few people already fit 15''.
http://www.ft86club.com/forums/showt...06#post1470606
http://www.ft86club.com/forums/showt...ght=slipstream
I run Enkei RPF1's, 17x9 +45, 275/40/17 Nitto 555R rear on mine, so it's doable.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
The Following User Says Thank You to slicktop For This Useful Post:
Kdej1 (09-27-2015)
Old 09-27-2015, 01:04 PM   #5
venturaII
venturaII's Avatar
I was more referring to the NEED for 275s, not whether they'd actually fit, so much. With a 2JZ, yeah; with an N/A FA20, you'd be wasting money.
Old 09-27-2015, 01:13 PM   #6
Kdej1
Colten Drew
Kdej1's Avatar
Yeah, I know Full-Blown's Bogart's they have are 15's, but I couldn't find the specs on them to get an idea on the offset.. I only plan on running the 15's in the rear, car is going to be used mainly for drag (I probably should have mentioned that) and will not be N/A.
Yeah I know they'll be big, I'd much rather run with the 235's being that they would be about 2" thinner. That way, when the rear comes down on launch it will have less chance of rubbing
Old 09-27-2015, 01:29 PM   #7
Kdej1
Colten Drew
Kdej1's Avatar
Right on. I'll reach out to the OP and see if he had to run any kind of spacer or mod anything. Very glad to see 26" fit very well in there.. I plan on getting 26"x8.5x15 Slicks and then the mentioned sizes above ET Streets for the street. Had them on my Vette and loved them.
Have you tracked your set up as is before? If so, what did the 60ft look like on the 40's?
Old 09-27-2015, 03:49 PM   #8
venturaII
venturaII's Avatar
I think that means they build them to YOUR specs, so, measure carefully...
Old 09-27-2015, 04:26 PM   #9
Kdej1
Colten Drew
Kdej1's Avatar
I think they measured them to stock brakes. To get something out there for us all.
Rear day time running lights gnflanagan BRZ First-Gen (2012+) — General Topics 5 05-13-2015 12:58 PM
Rear running lights BRZoomTX Cosmetic Modification (Interior/Exterior/Lighting) 0 04-13-2015 10:25 PM
Running rear tires with different tread depth on the bad for differential? YouShallKnow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 02-21-2015 09:34 PM
Is Anyone Running TRD Quickshifter AND Perrin Rear Shifter Bushing? Koa Engine, Exhaust, Transmission 5 11-27-2014 01:05 AM
anyone running 18x9 front and 18x10 rear? YDNA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 05-06-2013 01:55 AM
