| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 |
That Guy
Drives: 2013 asphalt FRS MT
| The Following User Says Thank You to Calum For This Useful Post: | dj2020 (08-16-2015) |
#30 | |
I keep a gallon of acetone on hand. Pour a little into a glass/ceramic bowl and use that. Don't contaminate the source.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | dj2020 (08-16-2015) |
#31 |
Drives: Subaru BRZ and VW R36
Hi,
I recently installed a torque solution cam plate in the hope of stopping the oil leak. Unfortunately the leak continues and is now slightly worse. Any ideas as to why it is failing? Thanks in advance. |
#32 | |
Double check and see if the mating surfaces are completely clean? No residue left over. Also, did you lube the plate's o-ring with oil before install? |
#33 | |
A little bit frustrating as I chose this solution to avoid having to go the RTV. |
#34 | |
That's why I chose the Torque Solutions plate instead of the other one. Perhaps they will warranty it since it's a defect. |
#35 |
Drives: scion FR-S MT
used gasket maker instead of aftermarket cam plate. used something called maximum oil resistant. the result was great, so far already been 8 months and had one track day still no leak what so ever.
#36 |
Drives: 2013 Pearl White 6MT
Happens to me I'm going with the after market product. But you did this repair without lifting the engine? I saw other post where you have to lift the engine. Saw a video where the guy does it without lifting but it was extremely tight and he was using a lift
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I
at night and ate at sun rise |
#37 |
Drives: red 2014 FR-S
My cam plate was leaking on my 2014 scion fr-s and finally got it to stop. I wanted to share my experience so it may help others.
I first tried to seal the stock plate. I used permatex red, it leaked. then I tried a cork gasket and permatex red, it leaked. then I bought the torque solutions plate. It still leaked. I am thinking it's the seams on the top and bottom that are leaking, So I tried adding prematex red to the seams. It still leaked. then I tried the same with permatex gray. still leaked. then I tried sealing the entire torque solutions plate with red, leaked then gray and it still leaked. by this time my O-ring on the torque solutions plate was ruined so I contacted torque solutions and the sent me a new o-ring free of change. while I was waiting for the o-ring to arrive I started thinking that the synthetic oil was degrading the sealant and that was the problem. I bought some permatex black and thought I will try the stock plate again. I used brake cleaner to thoroughly clean both surfaces. I used the tube to create a bead of silicone on the mounting surface on the car and then managed to get all three bolts started without touching the sealant. I then lightly tightened the bolts with my fingers. I let it sit for a while and then decided I wanted to check how much sealant was actually on the surfaces so removed the plate. the amount seemed about right so I smeared the silicone evenly on both the mounting surface and the plate and re-installed the plate lightly tightening the plate with my fingers. I let it sit like that for 24 hours and then torqued it lightly the next day. To my pleasant surprise that did it. It has been about a month now and zero leaks. the bottom line for me was, clean surfaces, permatex black, and do not squish all of the sealant out when you tighten the plate. I received my new o-ring from torque solutions but now I don't need it. Last edited by fx1mark; 06-07-2016 at 09:18 PM. |
#38 | |
THANK YOU!
Hey - just wanted to say THANK YOU for your follow-up post on this thing. A LOT of guys post their "first 5-minutes" impressions and reviews of things online and tend to leave off the - "oh crap, the install didn't go as planned."
I followed instructions to a T for [ named cam plate maker ]. The suggested process ended up with a BIG leak as O-ring on the cam plate doesn't REALLY go into the cam opening like it looks it like would. And just a few dabs of silicon didn't do it either. Like you, I ended up going with Ultra-RTV with Synthetic oil resistance... and instead of waiting just a few hours, I followed the Permatex instructions of rtv-ing surfaces (cam plate and cam opening - gooped a full circle around both surfaces), install part with setting torque (eg. enough to set the cam plate in place), wait an hour, tighten to torque specs and then WAIT another 24 hours for RTV to set. Have a feeling this will work better. Will follow-up with story of success or failure. - ExE36M3 Quote:
#39 | |
every previous time I applied sealant I followed the directions "wait an hour, tighten to torque specs and then WAIT another 24 hours for RTV to set. " It was squeezing too much sealant out. Mine is still not leaking. I am certain it never will. |
#40 |
FAILURE - argh
Well the "torque to specs" at the 1 hour mark is too much. You're right, it just squeezes out too much RTV. The good news is that it isn't spewing out like before. So something is working. I may have to do this ONE MORE time, but this time, set it at like 1mm of space and *after* 24 hours, then torque to specs. Yes? |
#41 |
Big in Japan
Drives: turBRZ
I recently used the Velox Motorsports cam cover and it no longer leaks. This was after Subaru attempted the fix twice.
#42 | |
| Oil leak solved - Raceseng billet aluminum cam plate | Clipdat | Issues | Warranty | Recalls / TSB | 156 | 06-17-2020 11:29 PM |
| Raceseng | Cam Plate - Stop your oil leak! | Raceseng | Groupbuys | 63 | 10-18-2013 03:31 PM |
| Raceseng | Cam Plate - Stop your oil leak! | Raceseng | Engine, Exhaust, Transmission | 2 | 09-21-2013 07:47 PM |
| A/T Pan leak | goke186 | Issues | Warranty | Recalls / TSB | 0 | 04-15-2013 10:31 PM |
| Exhaust Leak? | k33n3r | Engine, Exhaust, Transmission | 6 | 08-09-2012 12:59 PM |
