Old 09-19-2015, 06:06 PM   #1
40flash
John 1:12
40flash's Avatar
Drives: Pearl white BRZ Limited
maintenance light question
I've searched and cannot find anything that tells me how to turn off the maintenance light. No issues with the car. Just need someone to explain to me how to turn off the light. Is disconnecting the battery the only way? Thanks in advance.
40flash is offline   Reply With Quote
Old 09-19-2015, 11:19 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Ah sorry miss read your question.
Old 09-20-2015, 01:41 PM   #3
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
Our cars have a mait. Light? are you in a 2015?
Old 09-23-2015, 02:21 AM   #4
40flash
John 1:12
40flash's Avatar
It's the engine light that I am calling the maintenance light. Anyone know how to turn it off besides unhooking the battery?
Old 09-23-2015, 02:27 AM   #5
RustySocket
Slow Learner
RustySocket's Avatar
Drives: 15 Halo FRS
You need to pull the codes and figure out why the light came on in the first place.
If you don't have a obd2 scantool take it to autozone and see if they will read it for you.
RustySocket is offline   Reply With Quote
The Following User Says Thank You to RustySocket For This Useful Post:
40flash (09-25-2015)
Old 09-25-2015, 01:33 AM   #6
40flash
John 1:12
40flash's Avatar
With some cars the light comes on periodically as a reminder to tell you to change oil. Do our cars do that?
Old 09-25-2015, 01:45 AM   #7
RustySocket
Slow Learner
Drives: 15 Halo FRS
I can't speak specifically to the BRZ but the FR-S does not.
Old 09-25-2015, 01:56 AM   #8
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
No it does not. I suggest you pull those codes and figure out what's wrong. Never a good idea to ignore CEL unless you know what it's on for....
aegisdrgn is offline   Reply With Quote
Old 09-27-2015, 08:18 PM   #9
Celadrielas
If you're in the Mesa area, I can bring by a code reader to one of the meets and pull / erase the codes for you while at the Wednesday meet.
Old 09-29-2015, 06:58 PM   #10
40flash
John 1:12
40flash's Avatar
Thanks, guys. I dropped by the dealership to have my auto-door lock settings adjusted which they can no longer do. I have a code reader but while I was there they read it for free. It's telling me too much fuel. They suspect it has to do with my unichip or the aftermarket intake system. I'm still averaging 27.8 mpg so I wouldn't think it's very much too rich. No other evidence like a black exhaust pipe.
Old 01-22-2016, 12:31 PM   #11
40flash
John 1:12
40flash's Avatar
My engine code is a PO172. It say that bank one is too rich. Could my Unichip cause this? Do I need to take it to the stealership? Thinking I may disconnect the unichip, clear the code & see if it returns. Opinions?
Old 01-22-2016, 05:28 PM   #12
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
could be a unichip doing it. Disconnect it and reset ECU.
IF it's still doing it, possible issue with the injectors
#TrackDayBro
Kuri is offline   Reply With Quote
Old 03-31-2016, 06:07 PM   #13
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
My Unichip caused the same code. After capturing some data logs and trying many different maps, I finally found one that doesn't do it, 92 octane, all drop ins, fuel in, timing in. My car is stock except for a K&N drop in filter.
It sounds backwards to use a fuel in (rich) map when the code says you're already too rich, but I suspect what happens is that with a fuel out (lean) mapping, Unichip tries to spoof the ECU into thinking it's too rich in order to get it to lean the mixture out. I was seeing long term fuel trim below -40.2%. Any time it got less than -39.8%, I'd get a P0172, usually at idle.
The fuel in map appears to cap the long term trim at -34.4%. Two days now, and I've yet to see it exceed that. Surprisingly, the same mapping except for stock instead of all drop ins still threw a CEL for me. So if you're having this same problem, try the drop in map even if you don't have one.
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 04-03-2016, 11:59 AM   #14
Wyattkb
Drives: 2014 Whiteout FRS
My unichip did this as well, or so I thought. It ended up being my K&N filter had a little too much oil on it and it go onto the MAF.
Took some MAF cleaner to the sensor, cleaned out the filter and LIGHTLY oiled it. Never had the problem again with the unichip. Then I got an OFT and never looked back.
Wyattkb is offline   Reply With Quote
maintenance light ricky rod Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 05-16-2015 05:23 PM
Maintenance plan question? Mr_YUzU_FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 12-30-2014 10:49 AM
Turning off maintenance required light Prowl647 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 03-18-2014 02:01 AM
Maintenance Schedule Question TRD4life Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 02-22-2014 11:56 PM
Question-clear bra maintenance CHOPPER Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 12-26-2013 02:11 PM
