Old 12-02-2014, 05:02 PM   #85
MAPerformance
Drives: Asphalt FRS
Frightening indeed!
looks like a face hugger lol
MAPerformance is offline   Reply With Quote
The Following User Says Thank You to MAPerformance For This Useful Post:
raven1231 (12-02-2014)
Old 01-27-2015, 12:19 PM   #86
MAPerformance
Drives: Asphalt FRS
Hey everyone! For a limited time, we are offering $250 off our turbo kits! PM me for pricing, or with any questions you might have
Old 08-24-2015, 06:22 PM   #87
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Originally Posted by SmsAlSuwaidi View Post
If only you were in SoCal !, i might be making a trip in this thing to NorCal in a month, i wouldn't mind stopping by and showing it off
How do you like the kit? I'm in socal also and looking into getting it probably with the pt5858 looking for around 350whp starting and something that can easily go 450+
Sent from my SM-N920T using Tapatalk
SoCal80six is offline   Reply With Quote
The Following User Says Thank You to SoCal80six For This Useful Post:
Brzzee (09-25-2015)
Old 09-23-2015, 03:27 PM   #88
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Considering switching over to Turbo from SC, and as I was looking over your kit I noticed that in all your threads on the forum you use the Precision 4854 journal bearing turbo as the base, but on your website it shows the Precision 4831 journal bearing as the base.
Does it change much/at all in the power band?
ScionOfHorus is offline   Reply With Quote
The Following User Says Thank You to ScionOfHorus For This Useful Post:
DarkPira7e (05-20-2018)
Old 09-23-2015, 03:38 PM   #89
MAPerformance
Drives: Asphalt FRS
No, it really wouldn't. This is just the "new" part number that Precision renamed that specific turbo. It's common for them to change part #s frequently. And really it depends on your power goals. For pump gas only, I find that turbo works pretty well, and depending on fuel, should net you in the 300whp range. If you want 350+, (especially on E85) I would upgrade to either the 5558 or 5858.
Old 09-23-2015, 03:51 PM   #90
raven1231
It's crazy how little torque to hp these cars have...that said this has to be one of the best bang for your buck turbo kits out there!
Old 09-23-2015, 03:54 PM   #91
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
I agree did a lot of research before buying a kit and maperformance offered way to many things and to good of a price to pass up. Definitely satisfied!!
Old 09-23-2015, 03:56 PM   #92
raven1231
Congrats man! I love their work! Love to see your kit in action once it's installed if it isn't already ha ha
SoCal80six (09-23-2015)
Old 09-23-2015, 04:01 PM   #93
ScionOfHorus
Aight, because I'm shooting for 300-320ish whp on 93, though I'm budgeting for flex fuel in case I can't find a turbo with the power band I'm looking for. Looking for something that starts spooling around ~2500 rpm, making like 90% of peak torque before 5000 rpm.
Old 09-23-2015, 04:02 PM   #94
MAPerformance
Drives: Asphalt FRS
Most likely due to the little boost these cars can run due to it's high compression. I remember doing tuning on my car before we released the kit, and we had the boost controller set backwards lol. The car hit 21 psi before we let off (luckily the car wasn't mad) and it made pretty damn good torque...
raven1231 (09-23-2015)
Old 09-23-2015, 04:08 PM   #95
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
How much torque do you think the trans can safely handle?
Old 09-23-2015, 04:11 PM   #96
MAPerformance
Drives: Asphalt FRS
I don't think it likes anything over 350wtq. 4th gear seems to be the weakest one, as that is the most common stripped gear I have seen on some big power FRS/BRZ's.
Old 09-23-2015, 04:14 PM   #97
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
I had a feeling around 340-350. How should I be on shifting pretty gentle?
Old 09-23-2015, 04:26 PM   #98
MAPerformance
Drives: Asphalt FRS
That's up to you. I always let the car warm up before I ever beat on it. But when I did, I shifted pretty aggressively.
All TURBO kits compilation thread subatoy Forced Induction 112 04-10-2015 09:14 PM
MAPerformance Turbo Kit Officially Released! MAPerformance Forced Induction 633 07-26-2014 10:42 PM
AVO stage1 turbo kits now at MAPerformance! MAPerformance Forced Induction 37 01-13-2014 09:53 AM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
