Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
09-23-2015, 08:56 AM | #1 |
Drives: MR Spyder/GT86
P0087 Low Fuel rail pressure
Hey i have a problem.. My car occasionaly has a P0087 cel while idling 99% at a cold start.. Idle is Little rough when It happens and if cel hits throttle Will NOT respond until i restart the car
CAR drives fine for the rest NO power loss or any problems while driving.. And the cell wil dissapear after soms driving. Fuel rail pressure seems to drop occasionally when It happens but returns To normaal when i restart the car.. I have the latest OFT uel map and while logging the car nothing is out of the ordinary.. Question can a aftermarket header in any way Be responsible for over Time failure of fuel pressure? Ps:sry If My English is hard To Read.written by smartphone.
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter Last edited by GT86meMR2; 09-23-2015 at 11:08 AM. |
09-23-2015, 01:07 PM | #2 |
Drives: 2014 SWP BRZ, MT
Low fuel rail pressure applies only to direct injection, there is a solenoid I believe that can control fuel pressure. At idle the commanded fuel pressure is around 4 MPa or ~580 psi. If you are getting this issue there may be something wrong with your high pressure fuel pump or the solenoid built into it (they are one piece) that is preventing it from maintaining the pressure while the RPM is relatively low. Headers are probably not the reason for this issue.
The answer is racecar. Always.
The Following 2 Users Say Thank You to zkv476 For This Useful Post: | GT86meMR2 (09-23-2015), Sportsguy83 (09-24-2015) |
09-23-2015, 01:14 PM | #3 | |
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter |
09-23-2015, 01:19 PM | #4 |
Maximum puntential
Drives: 2013 DGM BRZ 6MT LTD
Had a similar issue with my car about a year ago and the cause turned out to be bad quality gas (the pump said 93, so I dunno). When I switched to another brand the problem went away after a few days.
The Following User Says Thank You to YMAA For This Useful Post: | GT86meMR2 (09-23-2015) |
09-23-2015, 01:22 PM | #5 |
Did It give the same cel code p0087 in Your case?
GT86
09-23-2015, 06:02 PM | #6 |
Maximum puntential
No, my codes were P0193 and P0191. But those have to do with the fuel rail pressure sensor as well.
The Following User Says Thank You to YMAA For This Useful Post: | GT86meMR2 (09-24-2015) |
09-24-2015, 03:36 PM | #7 |
Question: How come my car only has problems holding pressure at Idle nut has NO problems under heavy load high rpm without power löss?
GT86
09-30-2015, 09:27 AM | #9 |
Well as long that i don't let It idle when cold the cell Will stay away it seems.
GT86
10-07-2015, 12:36 PM | #10 |
Well warranty was denied because according To them My full exhaust produced higher co2 and because of that It was NOT conform anymore with the fluids in the CAR... Whatever that had To do with occasional drop of fuel pressure NOT a clue.. :p the shit part is now im still NOT 100% Sure what the probleem is.
GT86
10-07-2015, 02:18 PM | #11 |
Unfortunately it sounds like the dealer is serving you a load of crap. Not conforming with fluids in the car because of a header, huh? If there is a mechanical problem, it'd be in the high pressure fuel pump assembly, which consists of the pump and solenoid in one unit. My theory is that at low RPM the solenoid has issues controlling the pressure causing it to code out or the pump is starting to go out.
The Following User Says Thank You to zkv476 For This Useful Post: | GT86meMR2 (10-07-2015) |
10-07-2015, 02:25 PM | #12 | |
http://m.benl.ebay.be/itm/2013-Subar...695?nav=SEARCH (Just as example)
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter Last edited by GT86meMR2; 10-07-2015 at 02:52 PM. |
10-07-2015, 03:09 PM | #13 |
I couldn't say for sure. Which regulator do you mean? There is a low pressure 58 psi regulator in the tank. The solenoid controls high pressure fuel pressure and is a single unit with the high pressure pump mounted on the LH head.
I can't say for sure if it's the problem or not, I've never heard of this issue before, but it's what I'd imagine is the problem and not prohibitively expensive so it's worth a shot I'd say.
10-07-2015, 03:39 PM | #14 | |
GT86
Similar Threads | ||||
Point in the fuel rail cover? | manonastick | Engine, Exhaust, Transmission | 5 | 12-11-2016 06:47 PM |
High Pressure Fuel Pump Thread | crazyfrenchbiker | Engine, Exhaust, Transmission | 10 | 09-09-2015 01:32 AM |
direct injector injection/rail pressure? | WHITE | Engine, Exhaust, Transmission | 2 | 07-10-2015 02:06 PM |
Crickets possibly fuel pressure target? | Tromatic | Software Tuning | 1 | 12-16-2014 03:58 PM |
frs low fuel rail pressure ? 15,000 miles | j0hnnybk01 | Issues | Warranty | Recalls / TSB | 10 | 03-04-2014 03:03 PM |
